Rock Warrior Wheel Lug Nuts
Discussion in 'Wheels & Tires' started by k9shag, Apr 8, 2019.
  1. Apr 8, 2019 at 3:15 PM
    k9shag
    k9shag [OP] New Member
    Tony
    Midland, NC
    2017 Tundra DC SR5 MGM
    Can anyone put me in the right direction for RW wheel black lugs. I have an opportunity to by the wheels and center caps but no lugs.
    Thanks
    Tundra Fan likes this.
  2. Apr 8, 2019 at 3:22 PM
    Faht Nocker
    Faht Nocker Platinum Member
    Woody
    Milky Way
    2016 Super Fast White Platinum 4x4 Faux PRO Tundra
    Roman likes this.
  3. Apr 8, 2019 at 3:24 PM
    k9shag
    Tony
    Midland, NC
    not yet wanted to see what other have used. But will contact Roman to see if my current TRD lugs will work.
    Faht Nocker likes this.
  4. Apr 9, 2019 at 8:20 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    Black Wolf and 831Tun like this.
  5. Apr 9, 2019 at 11:08 AM
    k9shag
    Tony
    Midland, NC
    Thanks Roman. I have the current TRD wheels will those lugs fit on RW wheels?
    Roman likes this.
  6. Apr 9, 2019 at 12:08 PM
    Roman
    Roman
    Franklin, TN
    No sir. The TRD wheels use stock lug nuts and will not work on the Rock Warrior wheels.
    Toyotoholic likes this.
  7. Apr 9, 2019 at 12:23 PM
    k9shag
    Tony
    Midland, NC
    ok got it
    thanks
    Roman likes this.
  8. Apr 9, 2019 at 12:24 PM
    Pat
    Pat Sorta-new Member
    Pat
    Virginia Beach
    '16 MGM SR5 DC
    CAI, 5100's
    I've been using stock lug nuts on my rock warrior wheels. Should I not be?
  9. Apr 9, 2019 at 12:48 PM
    Roman
    Roman
    Franklin, TN
    Stock lug nuts for aluminum wheels have a flat washer like so:
    The Rock Warrior wheels take these type of lug nuts:
    If your lug nuts look like the first one, I would definitely not be using those. I didn't even think they would fit in the Rock Warrior wheel. If they look like the second type, you're good.
    MacCTD likes this.
  10. May 8, 2019 at 6:42 PM
    CaptSpaulding
    CaptSpaulding ...ain't nothin but nothin
    Jake
    2010 White DC 4x4
    Sorry to jump onto this thread, but it's somewhat related. Mr @Roman , can I order RW center caps from your parts dept directly? If so, can you provide a link?
    Thank you sir
  11. May 9, 2019 at 7:48 AM
    Roman
    Roman
    Franklin, TN
    Looks like the center caps have been discontinued.
    CaptSpaulding[QUOTED] likes this.
  12. May 9, 2019 at 8:19 AM
    CaptSpaulding
    Jake
    2010 White DC 4x4
    Shucks. I appreciate the effort, thanks for checking
    Roman[QUOTED] likes this.
  13. May 9, 2019 at 8:30 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    You don't need to buy toyota lugs if you don't want to. Any 14x1.5 lug with a 60 degree conical seat will work. Check McGard
    The toyota OEM RW lugs are the best because they have a conical seat washer which provides a proper lug torque, but solid lugs work just fine.
  14. Sep 7, 2019 at 11:07 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    Like these?
    https://www.amazon.com/McGard-64014...=McGard+64014&qid=1567922608&s=gateway&sr=8-1
    or these in black? Cost more, but..................not chrome
    https://www.amazon.com/McGard-64074...automotive&vehicleId=1&vehicleType=automotive
  15. Sep 8, 2019 at 6:53 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
  16. Sep 8, 2019 at 9:12 AM
    Tundra Fan
    Toby
    Thank you sir. :hattip:
    osidepunker[QUOTED] likes this.
  17. Sep 21, 2019 at 8:00 PM
    Tundra Fan
    Toby
    Just a heads up for people reading this later and are looking for lugnuts for their RW rims. The ones I linked above won't work. They do not leave enough room to get a lug wrench around them without damaging the wheels.
  18. Sep 21, 2019 at 10:03 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    Yeah you need a spline drive lug like what Roman posted. The use a very small diameter to fit in wheels like the RW or practically every aftermarket wheel.
    You can get these at Autozone or damn near any parts store.
    We also carry Bimmec lug kits at Discount Tire.
    https://m.autozone.com/suspension-s...llation-kit-65557bcc/361390_514164_16562?aqs=
    Tundra Fan[QUOTED] likes this.
  19. Sep 22, 2019 at 9:20 PM
    Tundra Fan
    Toby
  20. Sep 22, 2019 at 9:32 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    Awesome man!
  21. Dec 26, 2019 at 11:18 AM
    recomr
    recomr New Member
    Looking at lug options for RW wheels. Must the lugs have rotating collars? Or is that just an added expense?
    Thanks in advance.
  22. Dec 30, 2019 at 6:06 PM
    Kanobi13
    Kanobi13 New Member
