Rock Warrior Wheel Clicking, Ticking Noise Solved!!!!!!!
Discussion in 'General Tundra Discussion' started by csuviper, Apr 26, 2016.
  1. Apr 26, 2016 at 12:00 PM
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Ok i have been hearing this dang clicking noise for a while. It is an inconsistent clicking that sounds much lounder/worse at slower speeds or when coming to a stop.
    I searched and read lots of posts on alot of forums. Could not find an actual solution. Some suspected the rock rings or a rock rolling around in the ring or a rock rolling around in the center caps or the brake pads or the lug nut two piece design. Well non of these were the problem.
    Well I figured it out and and much happier without the clicking......
    Its the dang rings they put on the center caps to help hold them in place. They end up falling off and bouncing around in there. To solve the problem, just remove them.
  2. Apr 26, 2016 at 12:09 PM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    Nice find!
    Nothing worse than that little annoying noise you cannot find.
  3. Apr 26, 2016 at 12:13 PM
    csuviper
    Broomfield, CO
    Exactly. Was pissing me off so much. Had to get to the bottom of it. Finally did.
  4. Apr 26, 2016 at 2:42 PM
    robie56
    robie56 New Member
    Steven
    New Hampshire
    2011 white cm rock warrior
    mbrp exhaust, afe dropin filter, stubby antenna, Readylift leveling kit, ICI magnum RT sidesteps, weather techs front & rear
    Thanks for the heads up CSUViper, thats the kind of thing that would drive me crazy!
  5. Sep 1, 2016 at 7:18 AM
    650h1
    650h1 New Member
    2013 Rock Warrior C/M
    @csuviper I bought new centercaps because mine are looking like shit- I also have the loud clicking sound. Before I put the new ones on, I'm planning on taking the metal clips out of them. I was just wondering if it affected their retention at all? at like $35/ea I don't want them to fly off the wheels driving down the road...
  6. Sep 1, 2016 at 7:25 AM
    bandit
    bandit New Member
    2011 Supercharged Mazzulla Long Travel Rock Warrior
    Duh Tundra
    That sur clip keeps extra pressure on the keeper lips of the caps so they don't fall out when driving like we do lol. I replaced mine with C clips.
    650h1 likes this.
  7. Sep 1, 2016 at 7:27 AM
    bandit
    bandit New Member
    Duh Tundra
  8. Sep 1, 2016 at 7:38 AM
    650h1
    650h1 New Member
    hmm...
  9. Sep 1, 2016 at 8:13 AM
    csuviper
    Broomfield, CO
    650h1 and bandit[QUOTED] like this.
  10. Sep 1, 2016 at 8:16 AM
    csuviper
    Broomfield, CO
    I removed all of mine and have not had any problems with them falling out. They seem to be in there tight.
    I currently do not have center cap retaining rings or wheel rock rings installed. Have the stock lug nuts installed. No clicking.
    650h1[QUOTED] likes this.
  11. Sep 1, 2016 at 8:16 AM
    bandit
    bandit New Member
    Duh Tundra
    LOL I posted the link as a reference. Hell, even ace hardware carries them.
    650h1 likes this.
  12. Sep 1, 2016 at 8:17 AM
    csuviper
    Broomfield, CO
    I will have to check at ace. Couple bucks for a solid way to ensure they don't fall out might be the way to go.
    bandit[QUOTED] likes this.
  13. Sep 1, 2016 at 8:18 AM
    csuviper
    Broomfield, CO
    Where did you buy your center caps at? Thought i saw them for $20 each. Was going to pick some up actually when i get my rock rings painted i will get the caps painted as well.
  14. Sep 1, 2016 at 8:20 AM
    650h1
    650h1 New Member
    I actually got a set of four on eBay for $50/free shipping- Toyota OEM parts. Here is the link, I had to buy a set of 3 and then 1 from the seller, for some reason they advertise a set of 4 for $53, but you can buy a set of 3 for $35 and 1 for $14...
    http://www.ebay.com/itm/321905465511?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
    http://www.ebay.com/itm/221925733493?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
  15. Sep 1, 2016 at 8:25 AM
    csuviper
    Broomfield, CO
  16. Sep 1, 2016 at 12:32 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Reminds me of the days when we used to put a few rocks in our buddy's wheel covers. Or tie a few washers to his driveshaft with a length of wire and listen to it whack the floorpan as he drove off and see him pull to the curb half a block away to crawl under the car.
  17. Sep 29, 2016 at 9:51 AM
    650h1
    650h1 New Member
    I took out the clips, but I still have the clicking... any other ideas as to what it could be?
  18. Sep 29, 2016 at 10:37 AM
    csuviper
    Broomfield, CO
    Weird. I have heard it could be the lug nuts being two piece. Also hear it could be something with the rock rings.
    You could also lift the truck and spin the tire to see if you have a broken TPS rolling around inside. Also see if the wheel bearing is good.
    Remove caps and rock rings and see if it still clicks. If so then replace the lug nuts.
  19. Sep 29, 2016 at 11:56 AM
    650h1
    650h1 New Member
    Hmm... I'll just have service look into it at an oil change
  20. Sep 29, 2016 at 11:58 AM
    buckeyes1975
    Kevin
    OH-IO
    2008 Limited Double Cab
    Mine noise was the tire pressure sensors that some idiot taped to the wheels since they didn't fit my aftermarket wheels. Tape held it in place and would kinda swing around in the tire and wheel.
  21. Sep 29, 2016 at 1:37 PM
    csuviper
    Broomfield, CO
    Lol thats funny. The dang shorcuts people take.
  22. Sep 29, 2016 at 1:37 PM
    csuviper
    Broomfield, CO
    Let us know if they find anything.
  23. Sep 30, 2016 at 2:28 PM
    Broncorm
    Broncorm New Member
    Vermont
    25 limited
    I had the clicking noise for years. What my fixed mine was cleaning the corrosion off the back side off the rims around the lug holes where the rim sits against the rotor. I now do it every time I rotate the tires haven't had the noise in couple of years.
    650h1 likes this.
  24. Sep 30, 2016 at 7:42 PM
    csuviper
    Broomfield, CO
    That could explain my fix too actually. When I pulled the wheels off to add the wheel spacers I think is when the noise went away. I just attributed it to the metal rings because those were discovered at that time to be loose and rolling around.
    With the wheel spacers it's a softer material to eliminate noise like that.
  25. Oct 1, 2016 at 3:45 AM
    Broncorm
    Broncorm New Member
    Vermont
    25 limited
    I forgot to add do not put any anti seize on the hub. I tied that once when I rotated them and that made the click even more.
  26. Jul 3, 2017 at 7:17 PM
    csuviper
    Broomfield, CO
    Anyone still clicking? I have been 100% click free since doing this.
    Tundracollector likes this.
  27. Aug 31, 2018 at 12:22 PM
    dustyrhodes
    dustyrhodes New Member
    I had clicking and a grinding noise on the passenger side. The grinding ended up being the rear bearings. The clicking was the fake bead lock around the wheels. Just a couple screws were loose.... the noise was driving me nuts!
  28. Aug 24, 2019 at 3:38 PM
    Dendo508
    Dendo508 New Member
    Dennis
    2011 Black Rock Warrior
    Black out tail lights, Tyger tube steps, 1.25" wheel spacers
    I had the same situation, front driver's side tire made one click per revolution. I rotated my tires at home, and when I plopped the tire flat on the ground I could hear a rattle. I tapped on the bead lock ring and around a few screws it would sound different when I knocked on it. I used my impact, removed the bolt closest to the rattle and blew the debris out of the hole, then screwed the bolt back in. Continued around the ring for any similar sounds.. did this to all 4 wheels and after tightening the "loose" bolts, it didn't rattle after plopping in on the ground. Drove it about 4 miles so far without one click.
