Rock Auto 02 sensor
Discussion in '1st Gen Tundras (2000-2006)' started by 2003DC, Feb 20, 2023.
  1. Feb 20, 2023 at 3:35 PM
    2003DC
    2003DC [OP] New Member
    Can anyone confirm that the Denso sensors that Rock Auto sensors are comparable to OEM parts? Their price ($40) for the front sensor is more than half the cost of the dealer price. I'm willing to pay dealer prices if it makes a difference (especially since I'm haunted by this CEL problem), but if these parts are identical then I will go with Rock Auto.
    Thanks
  2. Feb 20, 2023 at 3:36 PM
    2003DC
    correction - "the Denso sensors that Rock Auto sells..."
  3. Feb 20, 2023 at 4:37 PM
    ya_boi_vince
    ya_boi_vince New Member
    Vincent
    2000 Black Access Cab 4.7L
    They work. Save the money. I bought them myself cause I had the check engine light on my 2000 4.7L and the light's gone. The shop did have to take 4 hours to weld in new exhaust pipes cause of how bad the old sensors were rusted in so that's always fun.
    FrenchToasty likes this.
  4. Feb 20, 2023 at 5:07 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    I replaced two on my 2000 with RA Denso units and they worked fine
  5. Feb 20, 2023 at 5:13 PM
    Spread5150
    Spread5150 New Member
    Dave
    2000 Tundra 4x4 SR5 V8 2019 Tundra TRD Pro 1994 Toyota Pickup 4x4
    So far so good w Denso on my 2000. Both front and rear
  6. Feb 22, 2023 at 2:40 PM
    tundrainsc
    tundrainsc Happy Tundra 1st Gen
    06 Limited 4.7 2WD
    Here are the Denso sensors at Rock Auto for my 06 4.7. Did not see a Denso front sensor for~$40.00. The front sensor is much higher than the rear sensor. Are they not the same. My plan is to order them after I rule out vacuum leaks and maf sensor. Anyone know if a faulty maf could cause the po138 code? Also, running a can of Seafoam in tank of fuel to see if that helps with the po138 code that comes on every 50 or so miles.
    TOYOTA > 2006 > TUNDRA > 4.7L V8 > Exhaust & Emission > Oxygen (O2) Sensor
    Price
    DENSO 2344260 Info [​IMG]
    Downstream
    $43.79
    NTK 24594 Info
    Fits Downstream Right; Bank 2 Sensor 2
    or Downstream Left; Bank 1 Sensor 2
    DENSO 2349051 Info
    Upstream
    $115.79
  7. Feb 22, 2023 at 7:18 PM
    Spread5150
    Dave
    There are different ones for different years.
    Go to Mcgeorge Toyota or Toyota parts deal. Put in your vin and search the part.
    You will get two part numbers
    Upstream and downstream. You need two of each.
    Then get that number and enter into rock auto and you will get the right Denso part.
    you will need 2 different ones. (4 total). Two upstream and two downstream.
    I just did mine. So far working great
  8. Feb 23, 2023 at 2:07 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Denso is the OEM manufacturer for Toyota
    https://www.densoautoparts.com/
    Enter the details about your truck, and it will identify the applicable parts including O2 sensors. Buy them at Rock Auto, Summit Racing, or another Denso authorized reseller. Do NOT buy from sites know for counterfeits (ie. Scamazon, Fleabay, et al).
  9. Feb 23, 2023 at 2:24 PM
    bfunke
    South Carolina
    Before you replace clean the MAF sensor and TB with some throttle body cleaner spray
    disregard - use CRC MAF cleaner spray
  10. Feb 23, 2023 at 2:36 PM
    tundrainsc
    06 Limited 4.7 2WD
    Will do.. Thanks
  11. Feb 23, 2023 at 3:49 PM
    w666
    Maryland
    Only use MAF cleaner on the MAF. Throttle body cleaner will damage your MAF sensor
    bfunke and BubbaW like this.
