Roadmaster Active suspension review
Discussion in 'Suspension' started by thedonn, Feb 25, 2022.
  1. Feb 25, 2022 at 4:02 AM
    thedonn
    thedonn [OP] New Member
    I went with the HD version and it is set at 25%. i hadnt heard about this product until I posted about the sag i saw with a load after getting my front level done. I loved the look at +1.9 in front (i did 6112s) and stock in back.....then i parked it on a small incline with 400lbs of salt bags on the back and hated the squatting. Boats are harder to get than cars right now but at some point next year i hope to have a 5-6k boat to tow. My first impression is the RAS does the impossible - the ride is smoother and it handles better. i will measure the clearance but to my eye I think I picked up a little less than an inch of rake. overall I am very impressed withthis product and I look forward to no squat! this is with the salt bags - i will take another pic this weekend with the new setup and try to get loaded and unloaded.
  2. Feb 25, 2022 at 4:44 AM
    Mobeyk
    Mobeyk New Member
    Oshawa Ontario Canada
    2012 Tundra TRD pro, 2018 SR5
    Vland headlights, LED fogs, Rough country lower bumper LED bar, third light switch to LED, ICL ceramic coating, hood fender
    Yeah, best investment in my opinion if you tow or load heavier. Even empty the ride is so much smoother.
    woods, KingsAustin and 2mchfun like this.
  3. Feb 25, 2022 at 5:02 AM
    For those that have the RAS, what it he final lift height after it has settled? I would like to get one but I'm level with my 4/2 and don't want a rake unless in is minimal enough that it isn't noticeable.
  4. Feb 25, 2022 at 9:45 AM
    thedonn
    ....someone called them and posted what they said for lift vs the tension rate but i dont see the post. i want to say .75 for 25% but im not sure about that at all
    Tundra234[QUOTED] likes this.
  5. Feb 25, 2022 at 10:05 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    I will be installing mine in the next few weeks and will post up before and after measurements.
    What I found in my research ( I did research on Tundra as well as Ford, RAM, GM half tons) was the HD set at most tension, black disk I believe, would net about an inch higher ride height. The thinner desk would lift .25 to .5. Some used a quarter for setting, which was in-between the two setting discs provided. This is based on the truck having good suspension vs sagging leafs, if the truck is sagging a little the lift would be more.
  6. Feb 25, 2022 at 10:12 AM
    I have new Alcans and my lift is a 4/2. Following for your follow-up measurements.
  7. Feb 25, 2022 at 10:43 AM
    Mobeyk
    Mobeyk New Member
  8. Feb 25, 2022 at 2:31 PM
    frichco228
    how long did it take to install, hour or two?
  9. Feb 25, 2022 at 2:51 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    I'll be installing my HD set this weekend. I'll post pictures when it's done.
    Viclava likes this.
  10. Feb 25, 2022 at 2:52 PM
    r1-superstar
    DB
    UTAH
    They told me 1-1.5". depending on variables as each truck is different.
  11. Feb 25, 2022 at 3:29 PM
    r1-superstar
    DB
    UTAH
  12. Feb 25, 2022 at 3:40 PM
    DiamondW
    DiamondW Stockblocker
    Kent
    CenTex
    ‘17 CM
    For anyone running RAS currently, how much restriction on droop are you seeing? They almond seem too good to be true so I’m doing my best to talk myself out of them lol.
    User170512 and AggiePhil like this.
  13. Feb 25, 2022 at 4:24 PM
    Mobeyk
    Mobeyk New Member
    1.5 hr in freezing cold and sliding around on snow. So in ideal dry warm conditions max an hr. No need to take the wheels off.
  14. Feb 25, 2022 at 4:31 PM
    Mobeyk
    Mobeyk New Member
    Before RAS I could see the back sagging quite visibly towing my fully loaded 7000 lb trailer. I didn't measure how much at that time. Now its going down 2-3" but is much less than before and most notably the ride is smoother with the trailer on, less sway and where in extreme bumps my bumps hit the frame there is no such thing with RAS. I use a weight distribution hitch when I have tools and supplies in the truck as I don't want to overload the axle and tires. Definitively RAS is great. One just has to still keep an eye on the weight limits.
    DiamondW[QUOTED] likes this.
  15. Feb 25, 2022 at 5:07 PM
    DiamondW
    Kent
    CenTex
    ‘17 CM
    I tow regularly, but my trailer is only 3800 lbs loaded, but 650 tongue weight, plus’s I keep adding tools to the bed since I put the retractable style cover on lol. I prefer to run without weight distribution for articulation, so I’m looking at all options right now.
  16. Feb 25, 2022 at 5:16 PM
    Mobeyk
    Mobeyk New Member
    RAS is perfect fit for you.
  17. Feb 26, 2022 at 3:56 PM
    r1-superstar
    DB
    UTAH
    I just finished the installation and it went pretty smooth. Here are some before and after pictures. I gained exactly one inch setting the HD springs at 25% (white disc 1mm). I have @BOSS4x4s shackles set at the highest setting (third hole 2" lift). If the RAS makes the rear sit too high for my liking, I will need to drop the shackles to the middle hole. I will post pictures later when I get the truck outside.
    GODZILLA and Chucho like this.
  18. Feb 26, 2022 at 4:22 PM
    r1-superstar
    DB
    UTAH
    So you would rather be level and squat like crazy with four passengers than have some rake and be closer to level when hauling something or someone other than yourself? haha
    Terndrerrr, AggiePhil and Mobeyk like this.
  19. Feb 26, 2022 at 4:41 PM
    thedonn
    my top pic in this thread was all I needed to cure my fears of too much rake lol
    r1-superstar[QUOTED] likes this.
  20. Feb 26, 2022 at 4:44 PM
    r1-superstar
    DB
    UTAH
    LOL!!!
  21. Feb 26, 2022 at 5:17 PM
    Lol. I just put in some Alcan springs and Timbrens.
  22. Feb 27, 2022 at 4:36 PM
    04rktaco
    04rktaco New Member
    Lee
    California City
    2014 SR5 TRD crewmax 4x4
    All-pro rocksliders RCI aluminum skidplates TRD pro suspension TRD pro exhaust coachman 1inch lift shackles cooper tires
    If these solve my wheel hop problem or actually shuddering problem when towing I will be happy especially if it keeps the stock ride.
    DiamondW likes this.
  23. Feb 28, 2022 at 2:16 PM
    r1-superstar
    DB
    UTAH
    Before and after...
  24. Feb 28, 2022 at 2:20 PM
    RegGex
    RegGex I noticed you copied my beard
    Oregon
    2021 TRD Pro CM
    How many inches are you from ground to wheel well on front and back if you don't mind me asking? Is your total front lift 3" with the 6112's and the Boss Shims? I'm looking to do a similar setup and was curious of the overall difference. Truck looks great!!
    User170512 likes this.
  25. Feb 28, 2022 at 2:58 PM
    r1-superstar
    DB
    UTAH
    Front = 40.5" Rear = 41.875"
    Yes, correct; 3/3. Build specs are in my signature below.
    And thank you!
    bulldog93 and RegGex[QUOTED] like this.
  26. Mar 5, 2022 at 8:57 AM
    frichco228
    Installing my RAS tomorrow. I found the leaf spring bolt torque, 77lb, however what size socket for the leaf spring shackle in the rear that you need to remove to install?
  27. Mar 6, 2022 at 6:50 PM
    thedonn
    front then back drivers side then passenger side....basically have about 3/4" rake but a little more on drivers side for the known tundra issues. i need to do more measurements when loaded but my goal was lever and this rake isn't noticeable at all
    Chucho and DiamondW like this.
  28. Mar 6, 2022 at 7:03 PM
    Does the lift from the RAS settle?
  29. Mar 14, 2022 at 11:18 AM
    tlpru
    tlpru New Member
    trent
    Southlake, Texas
    2016 Trd Pro
    added power mirrors, auto fold mirror, 2019 TRD head and FOG lights, FORTIN remote start, retrax tonneau cover, 18" fuel BFGK02, TRD sway bar, TRD intake
    sold..... just purchased........
    mostly tow a boat and utility trailer... hate the squat.... still factory suspension and added the TRD sway bar..
  30. Mar 14, 2022 at 3:21 PM
    Chucho
    Chucho New Member
    Rob
    Salem, OR
    2017 MGM DC Tundra SR5 TRD 4X4
    Tuff Country 2" Level spacer Kit up front Paired with KYB Mono Max shocks all around. Roadmaster Active Suspension HD kit 1mm gap 275/70R18 Falken Wildpeak A/T3W mounted on some MB352 18X9 + 25 Cobra 19DXIV CB radio.
    I'm also SOLD! Just ordered mine last night!
    Thanks for the reviews & feedback!
    Been looking at these for a while.
    Also there is a Special for $60 off & free economic shipping going on right now.
    https://activesuspension.com/
