Road Trip- what should I look for before taking off
Discussion in '2nd Gen Tundras (2007-2013)' started by Gunner90, May 23, 2017.
  1. May 23, 2017 at 8:40 AM
    Gunner90
    Gunner90 [OP] New Member
    09 Tundra limited
    Hey guys, taking a road trip in my 09 With 92k miles on it. Getting the oil changed today (200 miles overdue), and checking the battery at the local autozone, other than that y'all got any ideas on any preventive measures I should take? Little nervous, never taken one of my vehicles on this trip. Usually take the ladies civic or rent something. Trying to be as tedious as possible. Thanks in advance!
  2. May 23, 2017 at 8:43 AM
    How far? What about emergency supplies?
    Gunner90[OP] likes this.
  3. May 23, 2017 at 8:47 AM
    Gunner90
    09 Tundra limited
    It's only a 12 hour trip, just going from Florida to north ga and Birmingham, AL. Ya I'll have the 1911, flashlight, water, snacks... jack is in good condition. Spare tire is golden. Just trying to think of anything else. Truck hasn't given me any issues but never to early to worry I guess
    Noodle and zcarpenter92 like this.
  4. May 23, 2017 at 8:48 AM
    650h1
    650h1 New Member
    2013 Rock Warrior C/M
    I have a '13 with 60k miles, 3" lift, and 35/12.5/17's... I just drove it 700 miles one way to Virginia loaded down with shit, with my wife and our 10 month old, 14hrs one way down I95... truck did awesome. You won't brag about your gas mileage, but it is a really comfortable ride at least.
    Noodle, PR_02, T-Rex266 and 1 other person like this.
  5. May 23, 2017 at 8:52 AM
    Spare serpentine belt.. jumper cables...hand tools jack work ok all rods for jack all fluids topped off spare has proper air filled flashlight grease up all grease zerks on drive shaft
  6. May 23, 2017 at 9:01 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Just make sure you check the front of your truck and if the grill says Toyota or has the Toyota symbol your good to go. ;)
  7. May 23, 2017 at 9:02 AM
    Tomcat
    Tomcat Ever see a motorcycle outside a shrinks office?
    2010 SR5 4X4 5.7 20" wheels Metallic Gray
    Bakflip
    Might not hurt to check out all your lights and blinkers.
    Y0TA PR0, DalTee and Gunner90[OP] like this.
  8. May 23, 2017 at 9:24 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Check fluid levels, lights, tires, pack up on snacks and drinks, and enjoy!
  9. May 23, 2017 at 9:32 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    This right here ^^^ If you're travelling major interstates, you'll be able to find help or at least have a cell phone signal to call someone. No need to over think it; you're not in the desert or mountains in the middle of nowhere. As long as the truck is in good operating condition, you're fine.
  10. May 23, 2017 at 9:47 AM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    if you've not recently changed your transmission fluid - it wouldn't be a bad time - similarly, what does your coolant look like?
    Road trips aren't that strenuous if things are cooled & lubricated.
  11. May 23, 2017 at 9:52 AM
    Gunner90
    09 Tundra limited
    That's a good point. I'll make sure everything's topped off and the coolant looks solid. Thanks
  12. May 23, 2017 at 9:53 AM
    ej63090
    ej63090 New Member
    Eric
    McHenry, Illinois
    2017 White Crewmax SR5
    Have you changed yours before? I think it is not a roadside job unfortunately. It's not bad on a lift, but definitely one of the most difficult. However the spare would help keep you from getting ripped off somewhere.
    I would definitely check this for major cracking or damage - these are some tough heavy duty belts that I have very rarely heard of breaking.
    Spare tire, jack, jumpers, mobile air compressor and tire plug kit.
  13. May 23, 2017 at 10:16 AM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    This^^^ and bring cash. It's amazing how easy it is to fix problems on the road with green dollar bills.
    Seriously, just give it a once over (tires, fluids, wiper blades, etc.) and as long as you have kept up with maint. a 12 hour trip in a 90K truck is no big deal.
  14. May 23, 2017 at 11:36 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Get the oil changed since it's overdue, check fluids and tire pressure. Insert key, turn key, drive.
    tomsinamerica likes this.
  15. May 23, 2017 at 11:40 AM
    TXMiamiFan
    Jose
    And crank the radio. Vacation is on!
  16. May 23, 2017 at 12:00 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Fix a flat in case of emergency.
  17. May 23, 2017 at 12:09 PM
    SlickRick2013Tundra
    SlickRick2013Tundra #10
    Rick
    Mandeville, LA
    13 TRD CM MGM 4x4
    Toytech Boss 3in Lift kit Iron Cross side step TRD Sway Bar TRD Cold Air Intake Blacked out Badges Blacked out front and rear bumpers
    I'm going on a 25 he road trip from MO to CA and I usually bring snacks water first aid kit lights knife blankets and the usual fluids topped off spare and tires and wiper blades check
  18. May 23, 2017 at 12:20 PM
    Changed mine out to a Gates serpentine belt (K080948) for 5.7 V8 all ya need is 14mm socket 3/8 drive with a 18" breaker bar and a 0.24 inch drill bit use as a dowel pin took me 20 min change out had diagram of belt routing downloaded to phone
  19. May 23, 2017 at 12:22 PM
    millerstone
    millerstone New Member
    2017 TRD Pro DC Cement
    Love this advice!
    Y0TA PR0[QUOTED] likes this.
  20. May 23, 2017 at 12:27 PM
    Other helpful tool is the lug wrench i bought at local auto store one that extends out for better leverage 1495567615200815158218.jpg one that comes with truck is crap
    DalTee and Viper3G like this.
  21. May 23, 2017 at 12:29 PM
    Not reliability related, but all of my vehicles have an oh-shit bag. Reflective vests, flashlights, waterproof matches, emergency blankets, water, food, hand cranked radio, parachute cord, compass, collapsable hand shovel,knives, etc etc.
    MatthewPTguy, DalTee, Patriot and 8 others like this.
  22. May 23, 2017 at 12:47 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    I've got something similar to these. I got it mostly in case I'm somewhere isolated and need a jump as opposed to a road trip. It also charges phones, laptops, etc. I haven't needed it for me (yet) but have helped a couple of people in parking lots. Works great, much easier than jumper cables.
    https://www.cnet.com/roadshow/news/pocket-sized-jump-starters/
    lehminh and Gunner90[OP] like this.
  23. May 23, 2017 at 12:48 PM
    Thata pretty cool!
  24. May 23, 2017 at 1:15 PM
    JMB
    Chesapeake, VA
    I like it. My son in law is a mechanic and he uses one almost daily. He did say that if you try to turn over a seized engine, the thing will overheat and swell up like a balloon.
  25. May 23, 2017 at 7:08 PM
    ej63090
    ej63090 New Member
    Eric
    McHenry, Illinois
    Color me impressed.
  26. May 23, 2017 at 9:44 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    To know which way is north if headed from FLA
  27. May 24, 2017 at 1:21 PM
    Frkypunk
    Frkypunk "If a man is to be a street sweeper"
    2010 Tundra limited...2015 highlander limited
    Duck tape, coathanger, pair of vise-grips....that's all MaGuyver would need.
    Gunner90[OP], BlueBottle and Y0TA PR0 like this.
  28. May 24, 2017 at 1:38 PM
    MatthewPTguy
    MatthewPTguy Not a new member
    Eugene, Oregon
    2017 Tundra 5.7 DC TRD MGM
    Borla dual cat back exhaust system, K&N replacement air filter, Headlight Revolution 40" Stealth LED light bar, Headlight Revolution LED fog light replacement bulbs, Line X bed liner, de-badge
    Me too...
  29. May 24, 2017 at 1:56 PM
    PMG
    PMG New Member
    Thanks for this. I just ordered off Amazon. $68 isn't bad even. Though I have roadside for 3 yrs it might just come in handym
    JMB[QUOTED] likes this.
  30. May 24, 2017 at 2:17 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    And a pack of chewing gum. Lol
