Road Active Suspension, CB Drop Needed?
Discussion in '2.5 Gen Tundras (2014-2021)' started by jcic22, Dec 22, 2023.
  1. Dec 22, 2023 at 7:11 AM
    jcic22
    jcic22 [OP] New Member
    I'm considering RAS for my 2021 Tundra Crewmax. At the moment it is sitting on 6112 a 1.25" and 5160 in the rear. I think I have a .5"-.75" rake. Looks great, rides great. Just have a bit of squat when I haul stuff (concrete, dirt bikes, wood, tow, camping gear, etc). So considering RAS HD.
    I'm not necessarily going after a rear lift though .5" wouldn't hurt. Just looking to reduce squat when loaded up. Will a CB drop be needed? I had a lift on a tacoma years ago that had the take-off shudder and even with a CB drop I couldn't fully get rid of the shudder. I'm really hoping not to mess with the CB and a drop, so hoping someone can advise on if one will needed based on current specs.
    AggiePhil likes this.
  2. Dec 22, 2023 at 7:18 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    If you're not getting shudder now, the addition of the RAS system will not be the culprit for it. You should be good. We don't generally battle with takeoff shudder as bad on Tundras as we do with Tacos.
    Also, when the time comes to pick up your RAS we'd love to help over here at Hotshot Offroad. I've got them on the shelf and at the ready too. If you find yourself waffling between SD and HD definitely go HD. You can turn it down to act like standard duty, but you can't turn standard duty up to act like HD!
    https://hotshotoffroad.com/products/active-suspension-kit-14-21-tundra-1?variant=44056876974299
  3. Dec 22, 2023 at 7:20 AM
    jcic22
    But RAS will (or could) lift the rear, and thats what puts the drive line out of whack causing the shudder, right? How much lift can I expect? I see folks talking about up to an inch even, but then they have their truck on shackles or blocks and all other stuff so I cannot determine what the impact will be simply adding RAS to stock rear (other than shocks, but stock height).
  4. Dec 22, 2023 at 7:21 AM
    On that note, would they work with aftermarket leaf packs and lift shackles such as the Alcans? This question has come up a couple of times in the last 2 weeks.
  5. Dec 22, 2023 at 7:25 AM
    This post might help answer some of your questions.
    https://www.tundras.com/threads/roadmaster-active-suspension-review.103453/
  6. Dec 22, 2023 at 7:46 AM
    memario1214
    Colton
    Missoula, MT
    Completely understand the concern! The driveline angle/vibe issues ALMOST always comes with manipulating the front suspension. Your rear axle will generally stay in its same position when you put on a lift whereas when you lift the front suspension, everything else comes up with it contributing to that angle.
    Yes, a RAS will work with Alcans and the like. The only "issue" with that combination is that the RAS system, when used in conjunction with a longer pack like an RXT, Deaver, Alcan, etc will kind of act as a limiting strap. It's maximum "droop" is much lower than what those leaf packs are capable of. For daily driving use it's not a problem though, and the nice thing is that they can be taken off quickly.
  7. Dec 22, 2023 at 7:55 AM
    jcic22
    Duh, that makes sense. Appreciate the input.
    memario1214[QUOTED] likes this.
  8. Dec 22, 2023 at 8:01 AM
    memario1214
    Colton
    Missoula, MT
    No sweat. Happy to help.
    That said, I've only ever installed them on OEM, Deaver, and Icon RXT. Can't personally speak to Alcan. Don't see why it would be fundamentally different though.
    RobertD likes this.
  9. Dec 22, 2023 at 8:05 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Based on how I set it, RAS lifted my rear an inch and I did need to spacer the carrier bearing to stop shudder on take off. Install RAS, if you have any shudder just get a CB spacer kit.
  10. Dec 22, 2023 at 8:08 AM
    jcic22
    Yeah. That is my concern. I get the CB Spacer kit is there to address that but back to my experience with my tacoma, I could never really get rid of it. Just trying to avoid back and forth with a spacer kit and chasing down a shudder.
  11. Dec 22, 2023 at 8:11 AM
    memario1214
    Colton
    Missoula, MT
    I still support this advice. With the CB drop kit being only ~$25 it's an easy add on later if needed. Like I mentioned, addition of an RAS "shouldn't be cause for driveline vibes. However, you are changing how load is applied to the leaf pack which may have an impact on how the axle sits at rest.
    RobertD likes this.
  12. Dec 22, 2023 at 8:31 AM
    frichco228
    The CB drop is no biggie and super easy ( 5 minutes) to add anytime if you need it. And you may not need it, not all Tundras get shudder when lifting the rear. Or like me, it can happen with as little as an inch of lift. For RAS, you do want the HD version. And RAS does exactly what they say it does, I have been very happy with it on my truck.
    jcic22[OP] likes this.
  13. Dec 22, 2023 at 6:08 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    What size carrier bearing drop did you install to stop the shudder?
    My HD RAS is set to the thicker black disc and has the shudder on takeoff. I’ve tried both the 0.75” and the 1.25” Coachbuilder carrier drop kit and STILL have this annoying shudder from takeoff to about 20 mph.
    Got any ideas?
  14. Dec 23, 2023 at 6:20 AM
    frichco228
    I actually had some aluminum spacers in leftover parts. No idea what they came from but I tend to keep little odd parts like that in case I ever need them. I would guess they are about an inch. They worked great and appeared to be very similar to any CB spacers I would purchase so I just used them. You can also use stainless washers and stack them.
    I used a quarter to get my RAS HD, quarter is in between the white and black disk sizes and it raised the rear an inch.
    Do you have stock height leaf springs or aftermarket with some lift or different load rating? Are you only running RAS or do you have any blocks or shackles for some lift?
  15. Dec 23, 2023 at 6:41 AM
    ZPhilip
    Philip
    West Chester, PA
    Stock leafs with 78k miles on them. TRD rear sway bar, stock shackles and no other lift parts in rear besides RAS set to black disc, which resulted in 1.5” lift.
  16. Dec 23, 2023 at 8:21 AM
    frichco228
    Same set up for the rear as me then. There are some dedicated threads for RAS, you could search RAS and also active suspension and find them. Could be some nuggets of into on the CB drop. There will also be some thread on CB drop in shackle lift threads here.
    Look for any details/threads on CB drops for use when the rear is lifted 1.5 to 2 inch. You might find something worthwhile. My only suggestion would be to play with the amount of CB drop, maybe use some washers to try out different drop heights and see what reduces the vibration the best.
  17. Dec 23, 2023 at 3:36 PM
    ZPhilip
    Philip
    West Chester, PA
    Thanks. I searched all RAS and driveline vibration threads I could find. I’ve been chatting with David at Coachbuilder who also finds it odd that I still have the shudder with either drop kits and stacked combinations of fender washers.
    I’m going to dial back the preload on the Ras so that it’s at a quarter thickness and see what happens.
    Saltyhero13 likes this.
