RMF-003-2: 2-Switch Panel (Universal)
Discussion in 'RainMan Fabrications' started by RainMan_PNW, Mar 5, 2024.
  1. Mar 5, 2024 at 6:53 PM
    RainMan_PNW
    RainMan_PNW [OP] "Oz" SSEM #82 RGBA #4 Unofficial Forum Treasurer Vendor?
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    UNIVERSAL 2-Switch Panel
    Part Number RMF-003-2
    ORDER HERE
    Building off of the idea of the 3-Switch panel developed for the Platinum/1794 trim, this 2-switch version can be mounted anywhere that you have a flat spot large enough and with enough depth behind it to house two switches.
    These are printed in BLACK using Ultimaker CPE+ or ABS (based on availability - both are high quality materials perfectly suited for the interior of a vehicle). They a printed face down on a textured bed to produce the texture seen (which eliminates the typical print lines seen in FDM printed items). The top surface is given a couple light coats of SEM Trim Black.
    These will come with a matching “backing ring” that will secure them using some #6-32 set screws (uses a 1.5mm hex key to tighten). This allows for mounting in variable thicknesses.
    NOTE that the set screw threads are cut directly into the backing ring plastic, so they are to be tightened just enough to be snug and lock in the insert, but not so much that you strip the threads out. It is also perfectly acceptable to use your choice of epoxy to permanently secure these into the opening.
    Installation instructions will be the same as the 3-switch panel, but the supplied template will be specifically sized for the 2-switch version.
    Template is attached.
