Rims and Tires Thoughts?
Discussion in 'Wheels & Tires' started by tinman10101, Jun 5, 2018.
  1. Jun 5, 2018 at 9:41 AM
    tinman10101
    tinman10101 [OP] Ah cha cha cha
    Tinman
    2016 MGM Crewmax
    Hello all
    i was looking into getting a set of these Havok M101 with the following specs:
    18x9
    305/60R18
    0 offset (i think please see photo)
    5x150 bolt pattern (edited .... please ignore the bolt pattern stamp .. sorry)
    They came off a 2003 Toyota Landcruiser and was wondering if you guys think i will need a CMC? I am trying to avoid that since the removal of the mudflaps front and/or rear with heat gun mod to accommodate if necessary is so much easier.
    Also what do you guys think of these rims? I cant find very much on this brand nor see them on very many Tudras.
    Please let me know what you all think. Thank you in advance as always.
    Cheers
    PS here are the photos the seller sent to me with pics of the specs stamped on the rim.
  2. Jun 5, 2018 at 9:47 AM
    Your Tundra lug pattern is 5X150mm... 5 lug... not 6
  3. Jun 5, 2018 at 9:49 AM
    tinman10101
    Tinman
    2016 MGM Crewmax
    Sorry i forgot to add that it is a 5x150 bolt pattern. Thank you for looking out.
  4. Jun 5, 2018 at 9:49 AM
    tinman10101
    Tinman
    2016 MGM Crewmax
    meaning it does accomodate for a 5x150 bolt pattern. :)
  5. Jun 5, 2018 at 9:50 AM
    Borgs
    Borgs New Member
    PA
    womp... womp... womp... wommmmpppp...
  6. Jun 5, 2018 at 9:51 AM
    tinman10101
    Tinman
    2016 MGM Crewmax
    i believe he did not send me a pic of the other bolt pattern stamp. and it is mounted on his landcruiser at 5x150 bolt pattern.
  7. Jun 5, 2018 at 9:54 AM
    tinman10101
    Tinman
    2016 MGM Crewmax
    i was wondering what that 6x139.77 was and now i figured out that it is the other bolt pattern on the rim.
  8. Jun 5, 2018 at 10:06 AM
    Borgs
    Borgs New Member
    PA
    Assuming that is his Sequoia in the pic, looks like more than 5 lugs.
  9. Jun 5, 2018 at 10:09 AM
    tinman10101
    Tinman
    2016 MGM Crewmax
    its a 2003 Landcruiser and thats just the center cap. ;) i actually got a pm from him stating that he has no rub on his landcruiser but he does have a 3" lift which i am getting done this month ... 3/1 bilstein lift from darren at boss 4x4.
  10. Jun 5, 2018 at 10:11 AM
    Borgs
    Borgs New Member
    PA
    I see. Makes sense but is deceiving. God deal.. Those wheels are hot.
  11. Jun 5, 2018 at 10:12 AM
    tinman10101
    Tinman
    2016 MGM Crewmax
    so no "womp... womp... womp... wommmmpppp..." LOL. Thanks man!
    Black Wolf likes this.
  12. Jun 5, 2018 at 10:18 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    That tire is only 'bout 32.5" tall. It's gonna look small if you do a 3" lift. I like the aggressive look of the Mickey's though. If it is a 0 offset I think you'll rub but I'm far from sure about that. Your caster will have something to do with it too.
    tinman10101[OP] likes this.
  13. Jun 5, 2018 at 10:22 AM
    tinman10101
    Tinman
    2016 MGM Crewmax
    thanks man. i was thinking that too. about the size of tire vs the lift. ill have to dig for some photos of that setup of 3" lift with 32.5" tires.
    831Tun[QUOTED] likes this.
  14. Jun 5, 2018 at 10:46 AM
    I did some checking online. For the 2003 LC all rim sizes listed are 5X112. Good to go!!!!! :thumbsup:
    Edit....Brain farted...Not good to go!!!
  15. Jun 5, 2018 at 10:48 AM
    tinman10101
    Tinman
    2016 MGM Crewmax
    Thank you so much MR GREY WOLF!!!! :bananadance:
  16. Jun 5, 2018 at 11:01 AM
    Whoaaa!!!! You need 5X150mm. 5X112's won't fit! :(
  17. Jun 5, 2018 at 12:03 PM
    tinman10101
    Tinman
    2016 MGM Crewmax
    I found this on the net and the guy swears they are 5x150. He said i can even try them on before i purchase. i hope he is correct.
  18. Jun 5, 2018 at 12:08 PM
    Only one way to find out!
