Rim Specs
Discussion in '3rd Gen Tundras (2022+)' started by Homer, Feb 1, 2022.
  1. Feb 1, 2022 at 4:54 AM
    Homer
    Homer [OP] New Member
    2022 CrewMax SR5
    I'm looking to purchase aftermarket rims. I know the bolt pattern is 6x5.5, but what about the hub bore?
    Most sites don't let you pick 2022 Tundra to confirm fit. Is there another vehicle that has the same bolt pattern and bore size?
  2. Feb 1, 2022 at 6:25 AM
    BlueprintYota
    BlueprintYota New Member
    Ryan
    22 Blueprint TRD Offroad
    discount tire has a bunch on their site. most that I've seen fit were around a 120mm hub bore or higher
  3. Feb 1, 2022 at 6:30 AM
    Homer
    2022 CrewMax SR5
    So, you don’t have to match the hub size on aftermarket rims?
  4. Feb 1, 2022 at 6:36 AM
    TunnyNurse
    TunnyNurse New Member
    2022 Tundra Limited TRD Offroad
    Hub bore is same as the 4runner, 106.1
  5. Feb 1, 2022 at 8:41 AM
    Rwaters
    Rwaters New Member
    2022 Tundra TRD SR5 Crewmax
    Look up wheels by the bolt pattern and size you’re looking for. Or use a Silverado, Ram or Titan, and pay attention to the offset. Make sure you’re not to negative. Most folks have been staying within a +18 range (9” wide wheel or approximately a 5.75” backspacing) plus or minus some mm. The smaller the offset number the further the wheels go out. The lug nuts are 14x1.5
    I’m probably going to run a 20x9 +10 with a 275/60
    KroppDuster likes this.
  6. Feb 9, 2022 at 4:29 AM
    Homer
    2022 CrewMax SR5
    So … I measured the wheel hub to be 100mm.
    Am I correct in assuming as long as the bore of the rim is bigger than 100mm, I’m good? I.e. lug-centric not hub centric. Or do I need to find wheels with 100.1mm bore?
  7. Feb 9, 2022 at 4:45 AM
    WXman
    WXman New Member
    Kentucky
    2016 Tundra SR5 Crew Max 4x4 5.7L
    Seems odd that they'd make the hub exactly 100mm. The 106.1mm figure a member posted above seems probable.
    If your new wheels are 106.1mm you'll not need the hub centric rings. If the bore on them is larger, the tire shop can usually get you hub centric rings to use with the wheels. I know from experience that these rings make a big difference in balancing/ride quality.
  8. Feb 9, 2022 at 6:38 AM
    Rwaters
    Rwaters New Member
    Most of the 6on5.5 will have a 106.1mm bore or larger, which our trucks use. Some companies make a smaller bore for Titan, Ranger and Bronco.
    You don’t need hub rings since we use lug centric lugs. Some people are adamant on using the rings but if the lug nuts are properly torqued you won’t have a centering issue. They’re obsolete for our trucks.
  9. Feb 9, 2022 at 6:24 PM
    Versus78
    Versus78 New Member
    Will pickup my 2022 Crewmax Offroad in the next few days and I also looking for steel rims for my winter tires.... Can't seem to find a website that list the specs for the new Tundra.
    Manual says 18 X 7 1/2 J, but no mentions of bolt pattern, offset or hub....
    Also, lug nut size is M14X1.5?
  10. Feb 9, 2022 at 10:42 PM
    Rwaters
    Rwaters New Member
    6on5.5 (6on139.7) with a 14x1.5mm lug
    My new wheels and tires will be here this week and then my TRD 18’s will be up for sale
    bigjuice likes this.
  11. Feb 10, 2022 at 12:04 PM
    KroppDuster
    KroppDuster A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    You're going to like the wheels! I got mine last night since I'm in the state. It was basically overnight shipping since I was so close. For a "Garage Sale" item...I'm impressed. They're indeed "new in box!"
  12. Feb 10, 2022 at 5:14 PM
    Rwaters
    Rwaters New Member
    I can’t wait! Mine will be here tomorrow and the tires showed up today. I’m glad you like the wheels. Makes me feel a little better
  13. Feb 12, 2022 at 12:46 PM
    Mrconnsmythe
    Mrconnsmythe New Member
    Saskatchewan, Canada
    2025 Tundra Ltd TRD OR WCP
    How do they look?
  14. Feb 12, 2022 at 7:35 PM
    Rwaters
    Rwaters New Member
    I just picked it up and it’s dark already. I’ll have pictures tomorrow. From what I can tell, it looks great and I’m really happy with the setup!!
  15. Feb 12, 2022 at 8:10 PM
    KroppDuster
    Bilstein 5100s
    Ohhh…stoked to see it!
  16. Feb 13, 2022 at 7:22 AM
    Rwaters
    Rwaters New Member
    18x9 +18 with 275/70
    F236A3BF-7659-4F73-BCCF-4C311CC2D9E9.jpg 2BAB37F5-9BAA-4440-A2D4-63D24E76AF66.jpg 351DC640-EAAA-4F0A-B485-1B007FD97767.jpg E976A9B8-EB32-4D56-8F08-E363B743577F.jpg CB99FA36-D5A5-40FC-9287-56C09E9F63A2.jpg
    z-man, Solo707, =JSG= and 2 others like this.
  17. Feb 13, 2022 at 7:48 AM
    Rwaters
    Rwaters New Member
    Little shine on the tires....
    7CFC0F75-57F0-4531-A059-75431383A57E.jpg BE256D74-1897-4967-82F5-786D79C0F64D.jpg
    =JSG=, porterbc and Bradanglin22 like this.
  18. Feb 14, 2022 at 11:28 AM
    21CGtundra
    21CGtundra New Member
    Robbie
    SLC, UT
    2022 Midnight Black Tundra SR5
    2" front level, 1" Cornfed rear spacer, Rally Armor flaps, Method Con-6 wheels, 285/75 Duratrac
    Those look killer! I ordered the bronze spokes. Still undecided on them or my methods but yours looks very nice!
  19. Feb 14, 2022 at 11:40 AM
    Rwaters
    Rwaters New Member
    Thanks
  20. Feb 14, 2022 at 11:43 AM
    KroppDuster
    Bilstein 5100s
    Looking good @Rwaters! Looks like we're going the same route on tires. The pricing on the Cooper Evo M/Ts is hard to beat. Looks like I'll be going the same route but in 295/70/18. Hopefully, I'll do the leveling kit this holiday weekend and then have Discount Tire do the wheels/tires with an alignment soon after.
  21. Feb 14, 2022 at 12:42 PM
    Rwaters
    Rwaters New Member
    Thanks!! I contemplated going bigger, but I figured aesthetically it’d look great. Plus I didn’t want the mpg to tank too much. I wanted to do the level kit this weekend but that has changed. You’ll definitely have to post pictures ASAP
  22. Feb 14, 2022 at 1:29 PM
    Woodman427
    Woodman427 New Member
    Post-22 owner. Back to reliable Tacoma
    I ended up ordering some American Racing alloys for some studded winter shoes. Was approx. $50 more per rim than steel and looks way better.
    Went with 18 x 8.5. 6 x 139.7. 106.1 CB and +35 offset. Yes M14 x 1.5 lugs. Stock offset is +60.Tundra Winter.jpg
    =JSG=, Versus78[QUOTED] and Rwaters like this.
  23. Sep 2, 2022 at 7:08 AM
    2022-1794-4x4
    2022-1794-4x4 New Member
    95mm is the new bore hub on our tundras. FYI
  24. Sep 2, 2022 at 6:24 PM
    Solo707
    Solo707 New Member
    Ryan
    2022 Mag. Gray Tundra SR5 TRD Off-Road
    Lifted?
  25. Sep 30, 2022 at 4:49 PM
    Rwaters
    Rwaters New Member
    This picture was before the leveling kit. So it’s completely stock height here
  26. Nov 30, 2022 at 9:38 AM
    Henandhunt
    Henandhunt New Member
    2022 Tundra Limited TRD off road
    Where are you seeing 95mm?
    I keep seeing 106.1 online but nothing official from Toyota
