Rigid Radiance Fog Lights
Discussion in 'Lighting' started by Sting Ray, Mar 10, 2018.
  1. Mar 10, 2018 at 6:52 AM
    Sting Ray
    Sting Ray [OP] New Member
    Ray
    Vegas
    2017 SR5 Crewmax
    Not enough space here...
    Picked these Rigid Radiance white frog lights up brand new for cheap from a guy. May get a chance to install this weekend or next. I'll take come pics along the way. Should look good with the rest of the lighting in front. IMG_6683.jpgIMG_6657.jpgIMG_6681.jpg
  2. Mar 10, 2018 at 6:52 AM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Reserved
  3. Mar 10, 2018 at 8:25 AM
    Tundra4us
    Tundra4us New Member
    "D"
    Sting Ray that grill is saaweeet! Here is a little tip on those Rigid fog light brackets, have a "gusset" welded to the mounting tab of where the light mounts to. Because you will not be happy once you mount them and see your lights shacking when you go down the road. Rigid, does not = "Rigid" when it comes to those brackets.
    Sting Ray[OP] likes this.
  4. Mar 10, 2018 at 5:37 PM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    ^^^^^^^^^^This times 100,000,000.
    Had I known ahead of time, I so would have done this, but alas I found out after they were installed and I was to lazy to take them back out and had to come up with a bolt in support option.
  5. Mar 11, 2018 at 12:28 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Good to know. I don't have a welder unfortunately.
  6. Mar 11, 2018 at 12:54 PM
    Cuzican
    Cuzican New Member
    Louisiana
    This is the option I used, just some 1" wide aluminum flat bar you can pick up at Lowes/Home Depot, bolted to the bracket with the same bolt that mounts the light to the bracket and just a nut and bolt I had laying around to mount it to the bumper support. It stopped 95% of the jiggle.
  7. Mar 11, 2018 at 1:05 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Awesome! Thanks!
  8. Mar 11, 2018 at 1:13 PM
    Tundra4us
    "D"
    That is a smart set-up! I am not a welder either, I took it to a local metal shop and showed him what I wanted, made a cardboard template. He did it in metal.Then had it powder coated.
  9. Mar 11, 2018 at 1:52 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Curious, if you also have the radiance style, what wire did you tap into for the backlighting?
  10. Mar 11, 2018 at 3:00 PM
    Cuzican
    Cuzican New Member
    Louisiana
    No radiance here, I went with the SAE pattern so I could actually use them on the street and not blind on coming traffic or get flashed all the time.
  11. Mar 11, 2018 at 3:03 PM
    Cuzican
    Cuzican New Member
    Louisiana
    I'm still waiting on the 19 TRD PRO fog light mounts, since they will be coming stock with Rigid SAE fogs, I would assume that Toyota will do a better job with the mounts than Rigid did.
    jtav2002 likes this.
  12. Mar 11, 2018 at 5:55 PM
    94slowbra
    94slowbra New Member
    john
    new orleans
    2016 TRD pro
    ^^^ this is high on my list too. Hopefully the opening is the same size and they mount the same as regular rigids
  13. Mar 16, 2018 at 12:22 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Decided to go a different route, won't be installing these after all.
  14. Mar 16, 2018 at 3:41 PM
    94slowbra
    john
    new orleans
    2016 TRD pro
    Go with the dot saw ones. Couldn't be happier with their output
