Rigid A pillar lights
Discussion in '2.5 Gen Tundras (2014-2021)' started by peps01, Jan 23, 2023.
  1. Jan 23, 2023 at 6:00 PM
    peps01
    peps01 [OP] New Member
    Ontario, Canada
    17 tundra sr5 cm
    3” level , mbrp cat back exhaust,
    Hey all pretty new here. Has anyone installed rigid industries A pillar light kit with DSS flood with bracket? Wondering how good the bracket that comes in the kit is? I’ve looked through other posts and cannot find anyone talking about the rigid A pillar light kit. Any help
  2. Jan 23, 2023 at 7:04 PM
    Redline870
    Redline870 New Member
    Ian
    Central NY
    2021 Super White TRD Pro
    I didn’t use the exact setup you speak of but I recently did A-pillar Rigid D Series Pro in a spot pattern with SDHQ brackets. The brackets are AWESOME. Super solid!
  3. Jan 23, 2023 at 7:07 PM
    Redline870
    Ian
    Central NY
    And FYI, I bought both flood and spots. Flood didn’t have nearly adequate throw. They would be fine if you aimed them to the side and used them to see down side roads before making turns, but that’s not what I was going for. The 20deg spot pattern spreads out quite a bit down the road and makes a big difference in confidence driving at night. Those tiny little light pods blow the high beams out of the water.
  4. Jan 24, 2023 at 4:36 AM
    peps01
    Ontario, Canada
    17 tundra sr5 cm
    Thanks for your input :)
  5. Jan 24, 2023 at 5:40 AM
    Redline870
    Ian
    Central NY
    No problem! Here’s a picture for reference. I like that they sit nice and low. The top of the brackets sits just a little higher than the hood rather than super high like some other offerings.
    clarkritchie likes this.
  6. Jan 24, 2023 at 5:52 AM
    peps01
    Ontario, Canada
    17 tundra sr5 cm
    Awesome, thanks for reply and pic.
