Right side lighted sun visor
Discussion in '2.5 Gen Tundras (2014-2021)' started by b183, Jul 13, 2019.
  1. Jul 13, 2019 at 1:48 PM
    b183
    b183 [OP] New Member
    South MS
    2019 Tundra Barcelona Red TSS
    Bed Step, Driver pull Handle, Camlocker LP Toolbox, Bed Rails, Rubber Bed Mat TRD rear sway bar, front camera AVS window deflectors window tint
    I have a 2019 sr with stock sun visors. Is it possible to order a OEM lighted right side illuminated mirror sun visor. Does anyone know if wire is already available if I remove the stock one. This would make the wife very happy.
    Milamber likes this.
  2. Jul 17, 2019 at 6:58 PM
    b183
    South MS
    bump
  3. Jul 17, 2019 at 7:31 PM
    P-Factor
    P-Factor New Member
    Easy to check... Remove the two Phillips head screws and drop down the visor and if it is pre-wired you will see the plug inside the cavity.
    Good luck and be safe!
    texasrho83 likes this.
