Right jack for lifted tundra...
Discussion in 'General Tundra Discussion' started by MaddenMaster, Oct 25, 2021.
  1. Oct 25, 2021 at 11:37 AM
    MaddenMaster
    MaddenMaster [OP] New Member
    Sal
    17' Tundra "Colossus"
    Hello from SA, TX. Just wanted to share something I discovered. I have a 3/2 lift level kit and some 35's on my 2017 4x4 Crew Max truck. Figure that gave me 5 - 6 inches in total. Thought I should probably do some research on a decent bottle jack to replace the stock. I ended up going with BIG RED T91203B Torin Hydraulic... https://www.amazon.com/dp/B000234ISU?ref=ppx_pop_mob_ap_share. Read good for lifted trucks. However, fact is, it's actually an inch shorter! Lol. It does fit in the same factory location under the back seat as the original, and is built much more solid and faster to jack truck up with, so I kept it. Just wanted to share that with you guys. I do have a nice hydraulic floor jack at home that I use to change brakes, but needed one for the road.
    Kgfit85 likes this.
  2. Oct 25, 2021 at 11:44 AM
    2mchfun
    Wood blocks are a beautiful thing.
    Kgfit85 likes this.
  3. Oct 25, 2021 at 11:45 AM
    MaddenMaster
    Sal
    Ain't that the truth! :thumbsup:
  4. Oct 25, 2021 at 12:11 PM
    Sunnier
    Sunny
    San Diego, CA
    This works, and it’s inexpensive. And has that extra lift. Plus, if you pay a bit more for insurance, they’ll do a straight swap out if it breaks. Tractor Supply:
    Kgfit85 likes this.
  5. Oct 25, 2021 at 12:12 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Stock Toyota jacks have a very good expansion ratio. If you're jacking to the axle or A arm (and probably to the diff mount/front crossmember) you should have plenty of travel with the stock jack.
    Kgfit85 likes this.
  6. Oct 25, 2021 at 12:38 PM
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
