Ridiculously loud wiper slap
Discussion in '1st Gen Tundras (2000-2006)' started by Jonny Rotten, Oct 10, 2021.
  1. Oct 10, 2021 at 9:21 AM
    Jonny Rotten
    Jonny Rotten [OP] New Member
    2002 SR5
    This can't be right.. it's slamming against the bottom of the windshield grill. Or at least it seems like it
    I'm wondering if I can take the wipers off and rotate them one notch up?
    Is that possible?
    Is the wiper blade post like a star where you can put it on at different angles?
    If not any other ideas?
    Unbearable
    Tried to post a video but apparently I have to post it to You Tube first which is crazy
  2. Oct 10, 2021 at 9:25 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    You should be able to pull it and re align it. Flip up the cover and see the bolt where the wiper attaches to the stud. I just glanced at this, might have to remove the cowl.
    https://youtu.be/JNpvwMZfD8c
  3. Oct 10, 2021 at 9:33 AM
    alb1k
    Left Coast
    It's good
    oh you have an 02. Just pop the caps off the end of the arm
    Jack McCarthy likes this.
  4. Oct 10, 2021 at 9:56 AM
    Your bushings may be toast. You can try the readjustment, but there's some poly bushings between parts that can get old, dry and brittle and fall apart.
  5. Oct 10, 2021 at 10:35 AM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    Unlikley. If you rotate the wiper arm upwards to avoid hitting the bottom sill, you'll probably end up now striking the window sill on the side when the wiper is a the other end of its arc. That's what I was experiencing. Either slap the bottom or slap the side. My solution was to install a wiper blade that was one inch shorter.
    alb1k likes this.
  6. Oct 10, 2021 at 8:44 PM
    I replaced my factory wiper "transmission" which is the arms under the cowl from the wiper motor to the blades. I have slap both directions now. Should have went OEM.....
  7. Oct 21, 2021 at 8:21 PM
    alb1k
    Left Coast
    It's good
    What was it?
