Rich start during cold(<20f).
Discussion in '2.5 Gen Tundras (2014-2021)' started by Hank461, Dec 13, 2024.
  1. Dec 13, 2024 at 2:19 PM
    Hank461
    Hank461 [OP] New Member
    Henry
    2018 Tundra SR5
    Hi All,
    Just got a new to me 2018 tundra5.7 sr5 crew max, fav.
    Just got all fluids changed and am learning the truck.
    Runs absolutely fine with one exception.
    On cold days, first start in morning it sort of stumbles and I get a super rich smelling bluish cloud out of exhaust. I put a new Napa pvc valve in gave it a new engine filter etc.
    Once started cloud clears and it runs fine. Only stumbling is for about 3-4 seconds till it varooms normally.
    Doesn’t have any antifreeze smell, just rich gas/oil.
    I’m checking fluid levels to see if I may have extreme oil consumption or head gasket antifreeze leak.
    Any thoughts are appreciated as I’m sure this is not new.
    I do have a 12 mo warranty on it now down to 11!
  2. Dec 14, 2024 at 4:37 PM
    Sunfish
    Sunfish New Member
    17 4X4 CM Limited
    Is it a Flex Fuel?
  3. Dec 14, 2024 at 5:28 PM
    Hank461
    Henry
    2018 Tundra SR5
    It is. Only run regular 87 octane in it.
  4. Dec 14, 2024 at 5:48 PM
    303Gen3
    303Gen3 Old enough to know better. Young enough to try
    Golden Colorado
    '23 MGM SR5 CrewMax 4x4
    Nitrogen filled tires!
    ??? Do you know if the previous owner had it "tuned"? I had a similar experience with my prior truck - found out the "Tune" had a bug in the patch for the AFR table that only caused the issue when the temps were sub freezing. Once the software patch was fixed the issue went away. ??
  5. Dec 15, 2024 at 3:39 AM
    Sunfish
    Sunfish New Member
    17 4X4 CM Limited
    You need a scan tool with the capability of re-setting the fuel trims and alcohol density. It is pretty common. Mine was doing the same thing and it's gotten now to where the fuel pump is on its way out. If you can get this done under warranty it would be a real blessing
    HulkSmurf14 likes this.
  6. Dec 17, 2024 at 7:10 PM
    Hank461
    Henry
    2018 Tundra SR5
    Thanks for the tips.
    I just got the Blue Driver scan tool but am not savy on it yet.
    It’s blue tooth to the smartphone.
    Not sure if I can reset things that are whacked.
    Not sure if it was tuned but I don’t think so. Seems like a normal V8 truck.
    That said, I’m turning into slow go since I retired. No need to be anywhere till I have a need.
  7. Dec 26, 2024 at 12:34 PM
    Hank461
    Henry
    2018 Tundra SR5
    Well, took truck to range for requalification 40 miles in snow storm last Friday and check engine and all sorts of messages came up. Drove fine but no cruise control forward crash sensors and no trailer brake controls.
    Anyhow, scanned it and had 14 codes misfires to lack of comms. Toyota rolled up with wrecker and been in shop since Friday. Valve stem seals plugs wires plugs and coil pack or three. I have a free loaner and repair and parts all covered…. Hope this is it because my “Oh what a feeling” moment is fading fast.
    Won’t be ready till after the new year. Hey all fluids are new and working! Stuff happens and ya got to go with the flow!
  8. Dec 27, 2024 at 6:59 AM
    Sunfish
    Sunfish New Member
    17 4X4 CM Limited
    Hope you have better luck with the Toyota dealer than I did. A good way to tell if they are lying is if their lips are moving
    batman900 likes this.
  9. Dec 27, 2024 at 9:26 AM
    AZBoatHauler
    So.Arizona
    These trucks don’t have plug wires but okay!!
  10. Jan 7, 2025 at 1:22 PM
    Hank461
    Henry
    2018 Tundra SR5
    Ha! Showing my age! Should have said “stuff” instead of wires. How about 8 fire sticks!
    Anyhow, estimate to have it back this Thursday. Cab off repair. Thank God it’s all covered…. I really need the truck for mental health. Highlander loner is nice but not for me.
    AZBoatHauler likes this.
  11. Jan 7, 2025 at 1:26 PM
    AZBoatHauler
    So.Arizona
    Love it so much I’m stealing it.
    :bowdown:
