Review: Griots Ceramic Headlight Restoration Kit, Severe
Discussion in 'Detailing' started by Danimal86, May 16, 2021.
  1. May 16, 2021 at 1:37 PM
    Danimal86
    Danimal86 [OP] Looks clean even when its dirty!
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    I've got a 2006 Toyota Matrix as a commuter car and its headlights have been abused! At one point i put Lamin-X film on them and when i took it off, it left a layer of glue on the clear lenses. I tried every product to get the glue off, but ended up scraping the shit out of them with a credit card and goo-gone. They have been wet sanded using the 3M kits probably 3 times, and used polishing compound and a polisher to try to keep them clear. Guaranteed there isn't any UV coating left.
    I've had the Cerakote headlight kits in my Amazon cart for a while but never pulled the trigger. I was walking through pepboys and scored 2 of these bad boys that use Cerakote.
    vI-VbyEnI8tIVgAHxv2IS3znWkFhcd6sxLzla2YK_99b39ddbae424be36ea60970afaa479f373df295.jpg
    I thought that i would try it on the Matrix first before i attempted to use it on the tundra.
    There's a good video on the Griots site on how to use it.
    https://www.griotsgarage.com/produc...oration+kit+severe.do?sortby=ourPicks&from=fn
    I started out by masking the light
    KMB6sBVku5_86LGXCIWjm14bInFQDPHR7J29WzoR_8361f0d294c3358af7b1c602f27b1b0c80977ff3.jpg
    Then i used the Oxidation remover in a hatch pattern, and that wipe was orange by the time i was done.
    JGfujBwjdzJJzIeT4MasAriMgS88k8PIp9DmSwXt_7720a2d742adf59d26474c118699a4014def157e.jpg
    Then did a wet sand with 1000 grit. In the video they said to use passes that run in the direction of the longest part of your headlight, so i used diagonal passes. I ended up sanding until the water coming off was clear, about 3-5min for each grit.
    QyYzkh-2ZBicGJEE_AT8ZV82F0JkvItxTE_hn1xH_c7e11fa48199b12ac93d1293f0d783f200bf348f.jpg
    Then did the same with 2000 and finally 3000
    6CXI8oMkkX73na6hWYGm0vvtcu67oizJihLm8vz1_6254278e2fbfa59c745d47b91eceaa23f3cdafab.jpg
    Now it was time for the magic. While wearing gloves, pull the Cerakote wipe out and do the same direction passes using a 50% overlap with each pass. Its really tempting to go over the lens multiple times, but dont, it will leave streaks. One and done.
    SL__wlNB6yBB5NZYKf1AgQ9KHGr5xg_i5Vzn5dJH_996ddf631d0ce80260a6eaa4f24941b954f80692.jpg
    Now it is in no means perfect, but like i said these headlights have been abused. I'm happy with the results, so i'll go ahead and use the other kit on the Tundra.
    The left headlight turned out better
    R2aBM2PIXqbla_33XnQL0HapvSfwz9Mr74SA4Q9U_89478b87a47525051fc39b97f355857c3fd68891.jpg
    Now with the tundra, i was getting some bad oxidation on the tops of the headlights. It didn't really feel rough to the touch, but running a microfiber over it you could tell it needed some TLC.
    IQOVJ5UZv1fN36_Hif3BVLJsbl48dznGaubtGkLl_a328e6dbf9580274d2ccbe650f2769a049928c06.jpg
    01ffAVW4ky15dp_gbaqVBOuhkChfoREXB-ecZGKn_267a75520d22e6c2b2cd14035bd6d787b3462ebd.jpg
    Same process as before. Started off with the oxidation remover. I didn't pull nearly as much oxidation off the tundras headlights as i did on the matrix. I didn't get a picture of after the oxidation remover, but it didn't really make a difference.
    After 1000 grit
    rzYUz1SOMUdJB_jg4QEbIltO62fSChnvt9AQO2V-_013bdfda43bd75ba405ca981fa8bb2b184f6211d.jpg
    Then the 2000
    F4yRzr8-q6HRqnOkDMPjwuhSCMiK9NBDY38DZr9z_0f2a5390d7ee0d6655ad591173ac60ca34410541.jpg
    and finally the 3000
    nBfvte4NW960QnKFaKJIKDSu0Pv29QXsybDKCINK_385586186da3275a3ef3bb3bf36d7da606d56384.jpg
    Its amazing how well the Cerakote does with filling in the scratches and making it nicely clear. Before you throw away the Cerakote wipe, go through and make sure you have 100% coverage. On both of the tundra's lights i had missed a small spot and had to pull the wipe out of the garbage can quickly.
    39b6fmQV4s4C4HPw7tmACSq3ZbyuCUS3nru1P2sC_5ccdc42679b771c4fa874794c7c6814c9ef95998.jpg
    I think the tundras lights came out better, but they hasn't been as abused as the matrix's had. Very happy with the results. Its supposed to last a lifetime, but i'll keep updating as time goes.
    7JhvUXsXyZSwCvbuGUZiCZXMGbgcoXI5LMc6qLES_37a333fed1cc462030bdf532641d31c64e2a8ce0.jpg
  2. May 16, 2021 at 1:42 PM
    81 TOY
    81 TOY New Member
    Larry
    Vermont
    2008 Limited Crew Max
    Nice write up.
  3. May 16, 2021 at 5:31 PM
    Danimal86
    Daniel
    Sacramento, CA
    Thanks. I'll be interested to see how this holds up over time.
    KarmaKannon likes this.
  4. May 16, 2021 at 6:58 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Thanks for doing this. I was looking at a similar ceramic headlight kit. My plan was much like yours. I was going to do my tundra before my wife's gx. I'll sand down and polish my mostly flat tundra headlights any day before redoing the gx lights that are more like your tundra. Just in case I screw it up.
  5. May 16, 2021 at 7:17 PM
    Danimal86
    Daniel
    Sacramento, CA
    In reality, the only things you need to watch out for is not sanding in a circular pattern, and only doing one pass with the cerakote. It's really tempting to try to coat the piss out of them, but after you do one pass it really wants to streak.
    KarmaKannon[QUOTED] likes this.
  6. May 16, 2021 at 7:58 PM
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
  7. May 16, 2021 at 8:04 PM
    Danimal86
    Daniel
    Sacramento, CA
  8. May 16, 2021 at 8:09 PM
    French Avocado
    Utah / Wyo
    It did come with 8 oxidation removing wipes. It has held up fabulously in the 24 hours since I did it. We will see long term.
  9. May 16, 2021 at 8:12 PM
    Danimal86
    Daniel
    Sacramento, CA
    Ohh, I didnt see the timestamp, thought you did it a while ago.
    Thats a crazy amount of wipes.
  10. May 16, 2021 at 8:15 PM
    French Avocado
    Utah / Wyo
    Cerakote includes 2 grits of sandpaper (2000 and 3000 I think). I spent lots of time on the sanding because I did not think it would work very well on those old headlights. $20 was a lot cheaper than new lights.
  11. May 16, 2021 at 8:36 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Dang, they turned out great. Nice retrofit jobs too. :thumbsup:
  12. May 17, 2021 at 4:15 AM
    War Machine
    War Machine SSEM # 5 3MW
    Great write up Daniel! Thanks for sharing your results. The Tundra lights do seem to show better results than the Matrix. Maybe the Matrix ones were too far gone to get perfect?
    I’ve tried a couple of different techniques over the years. While the restoration went well, they always went back to looking foggy again within a year. Looking forward to seeing how long the Cerakote lasts. Hopefully it holds up better than others I’ve tried.
    If it works as well as their trim kits do, then I’m definitely on board to try it out next time I get some bad headlights. Great work!
    ToyoMafia likes this.
  13. May 17, 2021 at 4:18 AM
    War Machine
    By the way, have you looked at putting some decals on your Pro grill letters? I think they add a nice pop to the grill.
  14. May 17, 2021 at 7:29 AM
    Danimal86
    Daniel
    Sacramento, CA
    Thanks!
    I've tried the 3M sanding/coating kit, the Mothers polishing one that comes with a ball attachment and some compound, and some other random coatings that i found (on the Matrix, hadn't done anything to the tundra)....none of them lasted very long at all....maybe a month or two. The drivers side of the matrix has always looked a little foggier than the other after polishing, i think it may have some dust on the inside of the lens when i did the retrofit. I'm waiting to see how things settle with permanent or semi-permanent working from home to see if i even need a commuter car anymore. Would be sad to see her go, we've been through a lot together. lol
    They say that's it guaranteed to last as long as you own the vehicle, part of me thinks that's just marketing bs, but I'm optimistic that it will last a long time. I'll try to post an update after every few washes to get some data points.
    Have you used the Cerakote Trim wipes on a pro grille? It seems like its made of a different type of plastic than the plastic on the front/rear bumper or the bed runners. My pro grille is still fine, but my front/rear bumper trims and bed runners could use a little tlc, and i'm worried if i use it on everything but the pro grille it will make it look bad.
    Those do look good! I hadn't really thought of doing that.
  15. May 17, 2021 at 10:34 AM
    War Machine
    I haven’t tried it on a grill yet, for no other reason than I almost never clean them thoroughly enough to try it.
  16. May 24, 2021 at 5:13 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    Curious why you took off the Lamin-X.
  17. May 24, 2021 at 7:07 AM
    Danimal86
    Daniel
    Sacramento, CA
    It didn't really turn out that well, and then i wasn't getting a clean cutoff from the projectors so i pulled them off.
  18. Sep 9, 2021 at 11:04 AM
    CowboyTaco
    CowboyTaco New Member
    Michael
    2011 Tacoma DCSB
    The top of my Tacoma headlight has the same oxidation that yours had. When I was polishing last weekend, I just let the polisher dip down onto the headlight a little and it cleared it right up. Now you got me thinking I need to do this like ASAP.
  19. Sep 9, 2021 at 12:15 PM
    Danimal86
    Daniel
    Sacramento, CA
    Do it! My headlights are still looking great!
  20. Sep 9, 2021 at 2:02 PM
    CowboyTaco
    Michael
    2011 Tacoma DCSB
    4 months isn't that long of a sample, but I suppose you would likely have seen some return of the oxidation on the top of the lights otherwise.
  21. Sep 9, 2021 at 2:27 PM
    Danimal86
    Daniel
    Sacramento, CA
    Yeah i plan on doing a 6mo/12mo follow up with some good post wash pics, but we aren't there quite yet.
    The matrix's headlights would start to haze/yellow after about a month before, they are still lookin good!
    CowboyTaco[QUOTED] likes this.
  22. Sep 9, 2021 at 2:31 PM
    Kratos
    Kratos Woof
    2021 MGM Limited Nightshade
    Griots makes some nice products, appreciate the write up.
    Danimal86[OP] likes this.
  23. Dec 12, 2021 at 4:23 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Its about 6 months. Any update?
  24. Dec 12, 2021 at 5:16 AM
    Danimal86
    Daniel
    Sacramento, CA
    Once it gets light out, I'll take some update pics
  25. Dec 22, 2021 at 12:10 PM
    CowboyTaco
    Michael
    2011 Tacoma DCSB
    10 days and no light.
    ...sorry, I struggle to disable the sarcasm sometimes.
  26. Dec 22, 2021 at 12:25 PM
    Danimal86
    Daniel
    Sacramento, CA
    Haha. My bad, have had some cold rainy weather here.
    Gimme a min and I'll snap some picture.
  27. Dec 22, 2021 at 12:36 PM
    Danimal86
    Daniel
    Sacramento, CA
    Headlight look pretty good, some light pitting/scratching on the top corners.
    Vang530 and CowboyTaco[QUOTED] like this.
  28. Dec 26, 2021 at 10:52 PM
    Confused_02_base
    Confused_02_base New Member
    2003 Base V6 - various nicks and dings
    STOCK
    Ahhh, I miss the good ol' glass headlights. I too have used various products with varying results. As you've described, some lasted a couple of months (I have had better luck with tooth paste than some name-brand goodies) to just about 18 months before hazing was enough to annoy me. Polycarbonate is going to haze no matter what unless the vehicle spends its entire life in a UV protected garage. Prep work and taking the time to do the job right will yield longer lasting results but not a 'as long as you own the vehicle' result. Unless of course you plan on selling within 18 months ;)
  29. Aug 2, 2022 at 7:56 AM
    Danimal86
    Daniel
    Sacramento, CA
    Well after about 13ish months, i'm starting to see the same oxidation/fade on the tops of the headlights like before.
    96fA05_LfA9xMf8fGgmeiF0r9M6vFBQiwsH2UQLk_92bd935bd627170995af11cc86ab2e58b032fcff.jpg
    eo540i2cYgbrwcsNA5Rm1BTNDJ8Lx8AXgdSIFIss_226d2f922bb49f588e85a6155a8b2173adb3dfd7.jpg
    I'll probably reach out to Griots and see what they say.
    Edit: Griots responded ridiculously fast and are sending another kit out. I'll keep updating this thread with the re-do
    CowboyTaco and T-Rex266 like this.
  30. Aug 2, 2022 at 4:09 PM
    Ace96
    Ace96 New Member
    Western KY
    2021 Voodoo Blue TRD Sport
    That doesn’t surprise me. I would expect similar results with the new kit. I have tried different ceramic coatings on headlights and always end up in the same place.
