Reverse Pod Lights
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by SuperWhitePro19, Feb 4, 2022.
  1. Feb 4, 2022 at 8:33 PM
    SuperWhitePro19
    SuperWhitePro19 [OP] New Member
    2019 Trd Pro Tundra CrewMax
    Sitting on 275/65r18 duratracs, truxedo sport soft roll topper, home install bed lights
    Howdy y’all, just wanted to share with you the newest project!
    I installed some cheap Amazon pod lights in my rear bumper. With tinted windows and Toyotas sh*t reverse lights, this was my solution.
    Cutting the hole in the bumper was a lot harder than anticipated, ended up using a Dremel. Then drilled holes for the hardware. After exposing all that fresh steel I painted over the cuts. Wiring the lights was relatively easy. I purchased a universal two led lead wiring harness that came with switch and relay. All I had to do was extend the harness and run the wiring to the lights. I ran my wires for the switch through the driver side rubber grommet. I also purchased an OEM style switch. The way I wired it was Black to Black, Green to Red, Red1&2 to white. This keeps the switch off (no backlight) unless engaged (full backlight on when pod lights on).
  2. Feb 7, 2022 at 5:26 PM
    cran2
    cran2 New Member
    Folly Beach, SC
    07 Crewmax 4x4 and 03 Sequoia 4x4
    Nice work!
    SuperWhitePro19[OP] likes this.
  3. Feb 8, 2022 at 7:11 PM
    Akaklutz
    Akaklutz New Member
    Alan
    2021 Tundra
    New stock
    Excellent post. Where did you get the OEM style switch? Man I like this.
  4. Feb 14, 2022 at 12:24 AM
    SuperWhitePro19
    I got the switch, wiring harness, and the lights all from Amazon. I just typed in “tundra OEM style switch” and checked review photos to make sure previous owners installed it in a blank spot of a tundra.
    The only down side to these switches are the backlights on them are very bright! Hence why I wired it so the backlight of the switch only comes on when activated.
  5. Feb 14, 2022 at 5:19 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I mounted in the plastic. Plastic won't rust and easier to cut. I tied in to the reverse light circuit behind the taillight. I have Leds in the reverse lights in the tails. They do a decent job to the sides but not straight back.
  6. Feb 14, 2022 at 7:23 AM
    Cthulhu
    Awesome. Tied mine into the reverse wire.
  7. Feb 14, 2022 at 10:11 AM
    SuperWhitePro19
    what lights did you use? Looks great.
  8. Feb 14, 2022 at 12:11 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    I don't recall. I have had them for several years. Just some 4" pods I got on Amazon
  9. Feb 14, 2022 at 12:25 PM
    Cthulhu
    BlueRibbon4x4 likes this.
  10. Feb 14, 2022 at 12:30 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Did the exact same. I didn’t want another switch, just for them to come on automatically. Them $30 Amazon lights work great for this stuff. 137B2578-7A28-49B8-AACC-EB273F4A9B27.jpg
    hANNAbONE and Cthulhu like this.
  11. Feb 14, 2022 at 1:30 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    I did not have a blank for another switch and even if I did I would not switch them. If for some reason you want them on when not backing up just turn key on and put shifter in reverse. Of course use the emergency brake.
    BlueRibbon4x4[QUOTED] likes this.
  12. Feb 14, 2022 at 3:41 PM
    BlueRibbon4x4
    Geno
    Yep. :thumbsup:
