Retrax won't stay even
Discussion in 'Tonneau Covers, Caps and Shells' started by JackE5.7, Apr 23, 2024.
  1. Apr 23, 2024 at 12:50 PM
    JackE5.7
    JackE5.7 [OP] New Member
    Jack
    San Antonio, TX
    Cavalry Blue 2020 tundra
    Icon 2.5 Resi Coilover, Icon 2.5 resi rear, Total Chaos UCA, Morimoto XB headlights, Alpharex Luxx Tailights, SS Built front bumper, Baja Designs squadron fog lights, Fittipaldi 17" wheels, Mickey Thompson 35x12.5 baja legend, 5% tint all around with 5% brow, DD budget exhaust, OTT Tune
    Have had a retrax tonneau on my truck for a little over a year now and have recently found that after I go for a drive the right side of the cover moves towards the cab and leaves the whole thing at a slight angle and won't seal properly. Has anyone else dealt with this issue and possibly know a fix?
  2. Apr 23, 2024 at 12:57 PM
    SD Surfer
    Bruce
    So Cal
    Interesting that it's always the right side shifting... I would probably loosen all the clamps on that side, square it up, then re-torque everything and see if it persists.
  3. Apr 24, 2024 at 7:15 AM
    JackE5.7
    Jack
    San Antonio, TX
    I’ll try that this evening thank you
    SD Surfer likes this.
  4. Apr 29, 2024 at 11:26 AM
    SD Surfer
    Bruce
    So Cal
    Well, any luck? :)
  5. Apr 29, 2024 at 12:06 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Is it attached/clamped to the bed edge or do you have the deck rail system?
    My undercover flex would never stay clamped to the bed edge, I got a deck rail system and the proper clamps and it hasn't moved since.
    2ijovf08_ae658cae2c6f14f79402addafba036afad330169.jpg lkpv9wze_cad991b3fa5bbe9d0bc79581977e64579e537c18.jpg
    Good luck..
  6. Apr 29, 2024 at 12:14 PM
    Florida AF
    Logan
    North Florida
    Mine was having an issue and when I looked in to it, I bent the rode on the passenger side on one of more full loads. I bent it back and it locks like it is supposed to and has ever since.
    My guess is the track is fine, but the bed cover is slipping because the rod that applies tension is bent which prevents it from getting a good grip
  7. Apr 29, 2024 at 12:42 PM
    JackE5.7
    Jack
    San Antonio, TX
    I do have the bed rail system. I haven’t tried retorquing it yet been busy and just haven’t had time. Gonna try to look into it this week and will attach some pics. Thank y’all for the responses
    1lowlife likes this.
  8. May 1, 2024 at 8:02 AM
    SAGE63
    San Diego County
    BZ to Retrax...
    I called them yesterday about the rails and mounting clamps on my retrax XR cover. The grooves on the clamps and rail mounting points both had stripped flat due to offroad vibrations, Yes I did tell them that too as well as That I have my bed rack with RTT mounted in the track system. I asked if I could get replacements and what the cost would be. They asked for my address and said they will ship out this week I should have them by next Friday...
    No cost to me. now that is standing behind your products.
    now about the bent rods... call them they can replace that mechanism also.
  9. May 1, 2024 at 8:07 AM
    SAGE63
    San Diego County
    Retrax has longer alignment screws availabe which can help with that. your rails are likely a little to wide and the right side clamp is not making good contact on the rail. the pin on the clamp is also adjustable.
  10. May 1, 2024 at 8:36 AM
    JackE5.7
    Jack
    San Antonio, TX
    I think I found the issue. Crawled under last night and one of the silver clamps had completely fallen off. Took it out and gonna reinstall tonight
  11. May 1, 2024 at 8:39 AM
    SD Surfer
    Bruce
    So Cal
    Ha! Yeah, that could probably do it! That'd be a pretty easy fix, hope it works.
  12. May 1, 2024 at 8:42 AM
    JackE5.7
    Jack
    San Antonio, TX
    Saw the spot where it fell from so should be able to put it back up. Gonna make sure all others are tight. Thank yall again for all the help!
    1lowlife and SD Surfer like this.
  13. May 1, 2024 at 8:45 AM
    SD Surfer
    Bruce
    So Cal
    I would suggest taking some measurements to make sure it's nice and square when you torque everything.
  14. May 2, 2024 at 8:39 AM
    JackE5.7
    Jack
    San Antonio, TX
    Got the bracket put back on and measured everything to be square. Went for a drive and I think it’s actually worse than it was before. Think I’m gonna end up calling the shop that installed it as it should still be under warranty. Thank y'all again for the help!
