Retrax One any good?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mamba, Mar 5, 2020.
  1. Mar 5, 2020 at 10:53 AM
    Mamba
    Mamba [OP] New Member
    Manny
    2020 Tundra Limited 4x4
    None
    Guys was ready to pull the trigger but started reading something’s about the slates cracking. You guys have any installed an can chime in? Thanks in advance
  2. Mar 5, 2020 at 11:28 AM
    Cfincke
    San Antonio
    i have the plastic slat Retrax, the plastic has hairline cracks that allow water into the bed and it never has stayed tight against the tailgate - it always twists a little and lets water in along the tailgate as well. Since it twists a little, it will also bind when trying to roll it up. The large drum for the slats to coil up into also takes up bed space. My truck came with it when i bought it used. I would rather have the bakflip to have full use of the bed under the cover
  3. Mar 10, 2020 at 7:03 PM
    Taofouajarodeve
    Taofouajarodeve New Member
    Tao
    2021 Voo Doo Blue Crewmax
    None
    0DA75759-B9E7-44D7-92B3-1604032D0A77.jpg I have the retrax pro and I love it.
  4. Mar 10, 2020 at 8:14 PM
    TaquitoBandito
    Joel (AKA Bif)
    I also have the RetraxPro XR and I like it. I had a RetraxPro MX on my last truck and it was great. Not waterproof but I think the only totally waterproof cover you are going to find is something like an Undercover. The ability to lock the cover in any position is a definite plus.
    JimboSlice413 likes this.
  5. Mar 10, 2020 at 8:16 PM
    TaquitoBandito
    Joel (AKA Bif)
    What bars are those?
  6. Mar 10, 2020 at 9:41 PM
    Fastestcolor
    Fastestcolor New Member
    Blue Ribbon Limited CM
    Roll n lock
  7. Mar 11, 2020 at 6:59 AM
    tech1208
    tech1208 Old Salt, New truck
    Orlando, FL
    2023 Tundra Platinum 4X4 Blueprint Blue
    I have the Retrax PRO XR, and installed myself and Love it. The metal holds up great so far down here in sunny land.
    YardBird likes this.
  8. Mar 20, 2020 at 5:21 AM
    Taofouajarodeve
    Tao
    None
    Yakima HD.
  9. Mar 20, 2020 at 6:46 AM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    2017 Tundra 5.7L 4WD DC TRD
    2020 GD 2670MK Travel Trailer
    I see that you have installed the UnderCover SwingCase. How was the install on the Tundra?
    Buckaroo
  10. Mar 20, 2020 at 10:17 AM
    Tundra 2019 tss
    Tundra 2019 tss New Member
    Jerry
    2019 tundra TSS
    following tread looking at getting cover myself.
  11. Mar 20, 2020 at 10:52 AM
    Mamba
    Manny
    None
    Hello I actually went with tha Retraone Mx and I am happy I did.
  12. Mar 20, 2020 at 11:47 AM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    I have a Retrax One MX and like it very much. One handed retractable cover and super low profile. The plastic slats are not really slats, it's one piece that folds up. Water does not get in. Water may get in near the tailgate, but every tonneau can do that. I actually don't have a problem with water. It's not 100% dry, but it's not a problem. No water gets in on the sides.
    The top is pretty strong for being plastic too. And the front rail is rigid aluminum. I wouldn't stand on the center of the cover, but the front part is definitely capable.
    My only negative feedback is the stop, when you pull the cover closed, there is a plastic dowel screwed into a hole that stops the cover at a specific location. The dowel seems to come loose often. I fixed it with loctite on the metal screw. I also added some very thin metal shims so it closes more snug.
    Great cover, definitely would recommend.
  13. Mar 21, 2020 at 4:57 AM
    Taofouajarodeve
    Tao
    None
    Three screws and it was ready to go. All of 10 minutes. Get one, you’ll love it.
  14. Mar 23, 2020 at 1:53 PM
    Ron_Pro
    Ron_Pro New Member
    California
    2020 Tundra TRD Pro CrewMax
    I have the RetraxPro XR and Yakima HD Bars combo. So far it’s been great! I debated between getting the One and Pro, but the longevity of the aluminum cover and the lifetime warranty on the Pro was worth the extra cost.
    iWoosa likes this.
  15. Mar 23, 2020 at 1:56 PM
    yellowrider
    yellowrider New Member
    San Diego, CA
    2016 White Tundra DC TRD 4x4
    Bilstein 5100s, Tuff Country AAL
    I personally purchased the truck covers usa one and i love it. no issues and if youre local to socal theyre in San Diego.
  16. Mar 23, 2020 at 2:19 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    I like that integrated rack system. I don't think that was an option when I bought mine 4 or 5 years ago
    Ron_Pro[QUOTED] likes this.
  17. Mar 23, 2020 at 2:21 PM
    JimboSlice413
    Bakersfield
    I have the same cover and I get a little water by the tailgate seam, nothing under the cover itself. Checking out their website I just noticed they sell a gasket for that exact area, I might check it out.
  18. Mar 23, 2020 at 2:37 PM
    Bporter09
    Bporter09 Oregonian. Fisherman. That’s all.
    Brandon
    Pro XR. Planning on putting a rooftop tent on it eventually. Wouldn’t do something like this without the lifetime warranty. Love it so far, very easy to operate and live with. Don’t know anything about the One, but I do know I trust the heavy, metal aspect and feel of this one. Expensive buy either way, wouldn’t cheap out on this. Our Tundras deserve the best...
    GGODON and TaquitoBandito like this.
  19. Mar 23, 2020 at 2:53 PM
    TaquitoBandito
    Joel (AKA Bif)
    I ended up buying one off of Amazon - https://www.amazon.com/gp/product/B00IPQWXZQ/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1
    I keep forgetting to install it. Damn, it looks like earliest delivery is late April.
    JimboSlice413[QUOTED] likes this.
  20. Jun 17, 2020 at 2:02 PM
    trd.james
    trd.james New Member
    James
    2020 TRD PRO | Westcott Lift | 35" KO2's
    How hard was this to install?
  21. Jun 17, 2020 at 2:49 PM
    Taofouajarodeve
    Tao
    None
    It took 45 minutes because I like to take my time. It’s really easy. Just need another helping hand to lift it onto the truck. YouTube has a tutorial.
    YardBird and trd.james like this.
  22. Jun 17, 2020 at 3:14 PM
    trd.james
    James
    Thank you!
  23. Nov 6, 2020 at 6:35 AM
    70 FJ40
    70 FJ40 New Member
    Max
    '16 Tundra SR5 TRD 4X4 Double Cab
    I'm considering this exact same setup on my 2016 DC. Had a Leer topper with Yakima round bars on my last truck but I don't need to keep anything dry that is taller then the bed rails and I want to keep the versatility and looks of the open pickup bed. I occasionally need to haul something long for work on top like lumber or a ladder. but hate the look of normal ladder racks. the Yakima looks so much more sporty. I saw a couple reviews of this setup where guys had trouble with the side rails on the Retrax bending when mounting the Overhaul HD.(See video.) I had heard Yakima was working on a fix for this but don't know if that's true or if they've done it. Is this just from not paying attention and over tightening? You have any trouble with this?
    Yakima Overhaul HD & Retrax Pro XR - Installation WARNING - YouTube
