Retrax bed cover
Discussion in 'Tonneau Covers, Caps and Shells' started by redryder, Feb 17, 2019.
  1. Feb 17, 2019 at 11:52 AM
    redryder
    redryder [OP] New Member
    Ryder
    Louisiana
    2018 Limited Cement CM
    I'm seriously considering retrax bed cover because it can lock in any position. But I'm curious as to how much bed space it takes up. And is it something that I can install myself? Any help from you guys would be appreciated.
  2. Feb 17, 2019 at 1:03 PM
    tubal
    tubal New Member
    SLC, UT
    The container takes up about a foot on top of your bed and is about 10" deep. I installed mine myself. It's a little bit awkward and would have been easier to have someone help set it on top but it wasn't a big deal.
    I have a retrax pro xr.
    I really like it.
  3. Feb 17, 2019 at 9:30 PM
    Black Tundra TRD
    Black Tundra TRD New Member
    Go with the Retrax and don't look back. Ive had diamondback hard covers, several versions of back flips, etc. The Retrax is light well made and functional. I have the Powertrax Pro MX model which is all aluminum and motorized with a push button remote. A great leak proof cover. The cover mentioned is the exact same less the power functionality. I did a solo install. Was not an issue for me. Best of Luck!
    ScarWars likes this.
  4. Feb 18, 2019 at 6:10 AM
    redryder
    Ryder
    Louisiana
    is the only difference between the ONE and the MX the finish?
  5. Feb 18, 2019 at 6:15 AM
    ScarWars
    ScarWars New Member
    2019 Toyota Tundra TRD PRO Super White
    Does the retrax rattle around when you hit bumps or rough roads?. Seems like it would have a little bit of play in the cover and make some noise. Looks good though and convenient without have to fold.
  6. Feb 18, 2019 at 6:23 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    If concerned about bed space check out the revolver X2 / X4. Rolls on top, cannot lock multi position but like my X4 on work truck.
    Had a retractable, that function seem to not work so well after a few years.
    equin likes this.
  7. Feb 18, 2019 at 8:09 AM
    tubal
    tubal New Member
    SLC, UT
    Mine doesn't. It's pretty tight. I have the Pro, so it's aluminum and fairly heavy.
    ScarWars[QUOTED] likes this.
  8. Feb 18, 2019 at 8:15 AM
    Black Tundra TRD
    I'm not familiar with the "one" so couldn't answer that.
    My Retrax has Zero rattles as the cannister box is self contained and secure. The arms or bed brackets on each side utilize solid all aluminum clamps that lock the unit in place. Doesn't move or rattle at all. The opening and closing is smooth. Retrax Really is the standard by which all retractables can be measured and made in the USA.
  9. Feb 18, 2019 at 8:38 AM
    madmatt
    madmatt New Member
    Ocala Florida
    2018 Crewmax 4x4. TRD
    I’ve only had my retrax for about 4 months or so (that’s how long I’ve had the truck!) but I absolutely love it. It was expensive but worth the money in my opinion.
  10. Feb 18, 2019 at 9:14 AM
    jnelas
    jnelas New Member
    2019 Magnetic Grey TRD Sport
    I'm thinking through bed cover options... could you guys post a pic of what it looks like when fully retracted? Or maybe a pic underneath from the tailgate?
  11. Feb 18, 2019 at 10:36 AM
    Cfincke
    San Antonio
    My 2014 tundra came with the poly-carbonate Retrax cover installed and I have had issues with it.
    The locking clamp part has broken (retrax shipped me a new one)
    It constantly binds on me when trying to open it (I have completely remounted it with no improvement)
    it shifts at the tailgate and lets water in
    I just noticed 2 cracks in the poly-carbonate cover that are also letting water in
    equin likes this.
  12. Feb 18, 2019 at 3:08 PM
    Black Tundra TRD
    Yeah I would advise against any Poly or plastic cover. Anyway here are a few requested pics.
  13. Feb 19, 2019 at 6:49 AM
    jnelas
    jnelas New Member
    cool thanks!
  14. Feb 19, 2019 at 9:49 AM
    goldldr
    goldldr New Member
    Andy
    Spring,TX
    2019 SR5 CrewMax (Cavalry Blue)
    I really wanted a retrax, but I have the short bed on my crewmax and I just couldn't bring myself to give up a foot of bed space. If I had a full bed, I would have done it in a heartbeat.
  15. Feb 19, 2019 at 10:03 AM
    SullyMoto19
    SullyMoto19 New Member
    Tyler
    Houston, Texas
    2017 Magnetic Gray SR5 5.7 4X4
    8" ReadyLift w/ ReadyLift and Bilstein Adjustable Coilovers w/ Reservoirs, 3" PA Body Lift, Fox 2.0 Shocks, 24x14 RBP Atomics (custom powdercoat Gloss Black), 40x15.5r24 RBP Repulsor, Relentless Fabrication Stealth bumper, N-Fab side steps, Bedlined/Paintmatched Honeycomb Grill, 2019 LED Headlights, 4 Backlit RBG Cubes, 16 RGB PlashLight Rocklights, 5% Tint & Brow, 2 10" Kicker CVT Subs with Kicker Amp in custom sealed box, Husky all weather floor mats, LED White interior bulbs
    I really liked mine for the time I had it... eventually, the tracks started falling off/out of the rails. I would tighten and adjust the rails, but couldn't keep the tracks in. I drive a couple shitty roads on the way to work, but not sure if that could work as an excuse.
    other than that, it was awesome and didn't really notice it in the bed
  16. Feb 19, 2019 at 10:23 AM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    Taking up the 10" up front, combined with the constant adjusting to keep it flush to the tailgate got me to buy a cheap BakFlip to replace it. The side with the lock stayed just fine, but the cover would twist and eventually not be waterproof on the other side, if I left it long enough I could even see into the bed. Since I care about security more than waterproofing that gap was a huge issue. Getting the cheap BakFlip was just a temporary solution until I can get enough money to buy a Diamondback
  17. Apr 25, 2019 at 6:41 PM
    bigshark88
    bigshark88 New Member
    2018 SR5 cement
    N-Fab Nerf Step; Retrax; B&W
    Has anybody with the retrax found a product that could be used as a toolbox underneath the canister in the front of the truck bed? I have a retrax and would like to use that space under the canister for tool storage Is there anything out there on the market short of buying a custom tool chest? Running a Husky toolbox from Home Depot now. Won't slide under the retrax cannister and eats up a lot of bed space
  18. May 7, 2019 at 8:17 PM
    BlueDream
    BlueDream New Member
    2015 Tundra Dbl cab SR5 5.7
    6" procomp stage 3 lift, Method NV 18x9, Cooper STT pro 305/70R18, AFE air cleaner, LED fogs, Ranch hand Grille guard, Rhino liner, retrax bed cover, Flowmaster Duals, 15% Tint, vinyl chrome delete
  19. May 20, 2019 at 5:17 PM
    88nitro305
    88nitro305 New Member
    Tom
    2015 Tundra CrewMax TRD Off-Road
    How did that happen?
  20. May 20, 2019 at 5:19 PM
    Cfincke
    San Antonio
    Mine is starting to crack like that as well and i maybe roll the cover in once a month.
  21. May 20, 2019 at 5:21 PM
    88nitro305
    Tom
    How long have you had the cover? Just got one installed today
  22. May 20, 2019 at 8:20 PM
    BlueDream
    Not sure. The cover got brittle from the sun, then cracked down the slats on both sides in several places. It would get stuck when trying to unroll, and that would make it worse. Tried repairing and lasted a little while. Got stuck, and gave up. Out it went. Contacted Retrax and they offered a replacement cover without other parts for $300. Didnt want to bother trying again.
    88nitro305[QUOTED] likes this.
