Retainer clip help
Discussion in '2.5 Gen Tundras (2014-2021)' started by arkhomer, Dec 20, 2018.
  1. Dec 20, 2018 at 8:02 AM
    arkhomer
    arkhomer [OP] New Member
    Tyler
    2024 Limited
    Hey folks, I have a couple of retainer clips that have popped loose on drivers side wheel well. One secures the liner extension and the other the fender liner. I can't track down the right part number. I have already spent $10 on the wrong size clips and figured I would reach out. Hoping this is what is causing my slight rattle around 30mph! Thanks!
  2. Dec 20, 2018 at 8:03 AM
    Go back to dealer grab em, shudnt b that much for em or PM @Roman he parts guy
  3. Dec 20, 2018 at 8:08 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    I despise those clips, all plastic clips like that to be honest.
    When I can, I replace them with a nylon/neoprene washer and a black ziptie. You can't see it unless you're looking for it, it will not come loose, and if you need to access that area again just cut the ziptie and replace.
    joonbug likes this.
  4. Dec 20, 2018 at 8:08 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I lost like 5 of the clips holding the plastic piece. Just ended up zip tieing it.
    dcsleeper408 and NewImprovedRon like this.
  5. Dec 20, 2018 at 8:09 AM
    arkhomer
    Tyler
    2024 Limited
    Yea I thought about a zip tie. I have plenty of those, however I cannot access the back of the holes to feed through
  6. Dec 20, 2018 at 8:10 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I curl the zip tie and put it through the hole right under it.
    OBXTundra and NewImprovedRon like this.
  7. Dec 20, 2018 at 8:36 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
  8. Dec 20, 2018 at 9:44 AM
    cjscinta
    cjscinta New Member
    Nashville TN
    Roman’s “The Man”.
    Roman likes this.
  9. Dec 20, 2018 at 10:33 AM
    arkhomer
    Tyler
    2024 Limited
    Thanks!
