Resurrection from the deep, starting problems.
Discussion in '1st Gen Tundras (2000-2006)' started by sailinlee, Mar 17, 2020.
  1. Mar 17, 2020 at 3:17 PM
    sailinlee
    sailinlee [OP] New Member
    Lee
    2006 2 wheel drive 5.7 automatic
    Truck went for a swim in the Santa Fe River and sunk about 10' under. It took 45 minutes to get it out. My friend and I worked on it for the past 6 months and have it mostly back to normal. Intermittent starting problem and a tick in the top end.
    Hello,
    I sank my Tundra last year, and with the help of a friend, after 6 months it's been resurrected. But I still have some small issues. My friend did the hard stuff (the brain, anti-theft module, throttle housing and a zillion other details) and it's time for me to deal with the little issues. So today I'm dealing with intermittent starting issue. The battery is fully charged. So rule out battery and alternator. what it does is: Turn key sometimes nothing for about two seconds then a click, sometimes a click, sometimes cranks right up. Lately it's been cranking on the third try but the weather has been very dry. We haven't replaced the wires coming off the battery and that is my first thought. Anyone replaced the wire from positive terminal to the fuse box? Getting to the starter is horrendous. And that is my last fix. Why did they put the starter in such a horrible position to get to? Next would be the negative wire, any suggestion where it comes out of the harness to ground?
    First of many questions to come.
    Lee
  2. Mar 17, 2020 at 3:26 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck
    Please see signature!
    A 2006 (1st Gen) would not have the 5.7L...
    You mean the 4.7L?
  3. Mar 17, 2020 at 3:30 PM
    Welcome from NY.
    Good luck.
  4. Mar 17, 2020 at 3:54 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
  5. Mar 17, 2020 at 5:17 PM
    Professional Hand Model
    Hand Protectors
    Sounds like the starter, but most vehicles never fully recover from swimming and boating accidents. You can buy a reman’d one from the Stealership for around $250-300 vs. $500+ new. Choose the heavy duty version.
  6. Mar 17, 2020 at 5:56 PM
    SuperWhite20
    SuperWhite20 New Member
    Robert
    Georgetown TX
    2020 Tundra Crewmax SR5 4X4
    TRD Sway bar. Deck Rails, Maxliner rear floor mat, Driver side grab handle. Dee Zee bed mat
    Same contacts I put in many Chrysler mini vans.
  7. Mar 17, 2020 at 6:21 PM
    sailinlee
    Lee
    We took it out already and sent it off for a total rebuild of the starter and put it back in. But it's always possible they did a shitty job. I'm going through ever contact first before I have to go and deal with the starter again. It's a pain in the butt to get to.
    Lee
    speedtre and SuperWhite20 like this.
  8. Mar 18, 2020 at 4:15 AM
    Hand Protectors
    Let us know how it goes once you get it figured out.
    speedtre likes this.
  9. Mar 19, 2020 at 6:42 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Could be the ignition switch if the starter seems fine
