Resolved: Coolant flush - only a few drops from driver side block drain
Discussion in '1st Gen Tundras (2000-2006)' started by Weagle, Jun 16, 2024.
  1. Jun 16, 2024 at 11:51 AM
    Weagle
    Weagle [OP] I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    I'm doing multiple flushes to get rid of the bad green antifreeze
    I've got the heater valve open. I drain the radiator fully. Then drained from the passenger side block drain. Next when I did the driver side block it only dribbled for a minute
    it only held about 7 (edit must have been closer to 10 since I have flushed twice and used 5 gallons) quarts of fluid counting the reservoir. I know you can't get it all, but that is much less than I was expecting (sounds more normal after rechecking after the 2nd flush)
    I ran the engine for a while with the heater running at full operating temperature. Still a lot of green, but overall mostly pink
    So on my second drain, I did the radiator then I did the driver side first expecting more than before instead I got the same drip. Then on to passenger side which did the same as before
    This just doesn't seem normal. Could I have some sort of blockage on the driver's side?
  2. Jun 16, 2024 at 2:17 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    I feel your pain. Those block drains are hard to get at. They almost didn't feel worth it to me, since I was just trying to get as much old coolant out as possible without doing a full flush. My truck at least has had regular changes/flushes and always used red coolant. But multiple times while I was working on those block drains I considered "is this really worth it?"...
    Unless you're parked on a slant, it seems like they should drain more or less equally. Mine mostly did. Not sure how you check those things for obstructions. It's hard enough to see them, get a wrench on them, much less inspect them.
    Weagle[OP] likes this.
  3. Jun 16, 2024 at 4:22 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    10mm socket on an extension makes it fairly easy
  4. Jun 16, 2024 at 5:34 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    Mine drained fairly quickly in both sides. Maybe jam a small screwdriver into the drain and see if there’s some sort of dirt blockage?
  5. Jun 16, 2024 at 6:39 PM
    Weagle
    Prattville, AL
    mine were shockingly easy to get to. Of course I have taken my skid plate off. Really was not an issue at all. I was able to access both of them directly under the engine Especially easier now that is lifted 2 inches so it doesn't have to be jacked up to get it under there
    I could have been at a slight angle. I wouldn't think it big enough to cause this But I may reverse the way I park for the next flush to confirm one way or the other
  6. Jun 16, 2024 at 6:41 PM
    Weagle
    Prattville, AL
    Yeah, mine were very easy to get to
  7. Jun 16, 2024 at 6:42 PM
    Weagle
    Prattville, AL
    I am definitely going to try that thanks.
    whodatschrome[QUOTED] likes this.
  8. Jun 17, 2024 at 4:06 AM
    bfunke
    South Carolina
    Try pushing a pipe cleaner up the drain spout.
  9. Jun 17, 2024 at 4:44 AM
    Weagle
    Prattville, AL
    Great idea.
    Do they even make pipe cleaners anymore? Lol probably for arts and crafts projects because I don't think I've seen someone smoke a pipe in 30 years or more
  10. Jun 17, 2024 at 7:11 AM
    MT-Tundra
    Montana
    Huh. Could just be me, could be you're 2wd and have less obstructions up there. My skid plate was definitely off. I had to work my arm over/through/under multiple obstructions, and could never both see and touch the drains at the same time. I'd have move around to find the angle I could see them from, then jam my arm in there in the direction I saw them and fumble around blindly, trying to get a socket or wrench on them.
    Anyway glad you don't have the same trouble.
  11. Jun 17, 2024 at 9:43 AM
    Weagle
    Prattville, AL
    thanks yes must be because I'm 2WD. I was absolutely dreading it, and it turned out to be for absolutely no reason
  12. Jun 22, 2024 at 6:33 AM
    Weagle
    Prattville, AL
    RESOLVED
    I ended up using several Q-tips. Tried with no success from the drain spout. Had to unscrew the bolt to get to the blockage due to sludge
    This time I did the driver's side first. I got a pretty fair amount from both sides, so I'm sure that kept my flush from being quite as effective, but I'm doing multiple flushes anyway due to the green coolant that was put in previously
  13. Jun 22, 2024 at 8:19 AM
    3bears
    3bears New Member
    Joshua
    fairbanks alaska
    2002 acess cab
    none yet
    glad you got it, i have to do mine this summer
  14. Jun 23, 2024 at 5:39 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    Lol 4x4 can suck it!
    Weagle[QUOTED][OP] likes this.
  15. Jun 24, 2024 at 9:35 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    If you're not a bot say potato.
