RESOLVED: ABS kicking in on front passenger side at very low speed
Discussion in '1st Gen Tundras (2000-2006)' started by Weagle, Jul 11, 2024.
  1. Jul 11, 2024 at 11:19 AM
    Weagle
    Weagle [OP] I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    Edit: The right front ABS Sensor was knocked off-line during the front end work. Reinstalling it without the worn out rubber o ring worked temporarily until I can get a new O-ring.
    Orig post:
    I'm not getting any ABS lights but at around 1 to 5 miles an hour I can feel the pedal change and I hear that sound on the front right brake - both are what I observe when the ABS is kicking in. and then it suddenly pulls to the left which supports that theory.
    sounds exactly like what happened in this thread:
    https://www.tundras.com/threads/slow-speed-abs-activation-fixed.131442/
    coincidentally, I just replaced my 2883's with my new dobbies and I had the shop replace the upper ball joints because of some other odd noises. I probably should've done like others and just got new upper control arms with the upper ball joints already installed
    so a lot went on that could've potentially affected the positioning of the ABS sensor
    Anyone else had any experiences like this? I'm letting the shop check this out but not sure how adept they are at troubleshooting ABS issues although I did pass this potential issue along to them
  2. Jul 11, 2024 at 11:26 AM
    455h0le_dachshund
    455h0le_dachshund Tesler Thought Experiment
    Reverend Hotdog
    TX...big surprise
    I had a shop years ago, do my steering rack on my 03 Tacoma and this happened. They refused to do anything about it, so I pulled the ABS fuse. Truck was fine after that.
    More recently me and @Mr.bee changed out my spindles and my ABS started acting up once we put it back together. I think I just need to pull em apart again and try to reseat the sensors. But I'm not sure. If I can't figure it out, I'll look into pulling the ABS fuse.
    Weagle[OP] likes this.
  3. Jul 11, 2024 at 11:30 AM
    Weagle
    Prattville, AL
    thanks
    i'm thinking since they had to pull the spindle off to press in the upper ball joint, the sensor got bumped.
  4. Jul 11, 2024 at 11:42 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Btw, Quantum finally emailed me today for my ECU number.
    Weagle[QUOTED][OP] likes this.
  5. Jul 11, 2024 at 12:16 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I had the same problem after doing suspension work in 2019. Nothing I tried fixed it. I gave up and pulled both ABS fuses.
    Weagle[OP] and 455h0le_dachshund like this.
  6. Jul 11, 2024 at 12:38 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    One under the hood and one under the dash or what?
  7. Jul 11, 2024 at 12:45 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    On my 02 there are two fuses under the hood. On John's 06 there is no way to remove the ABS fuse.
  8. Jul 11, 2024 at 12:54 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Well furk.... I guess I'll be playing with he sensors then
  9. Jul 11, 2024 at 2:06 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    I had a truck previously that had a bad sensor cause this.
  10. Jul 11, 2024 at 4:22 PM
    Weagle
    Prattville, AL
    Looks like it was related to the O-ring. So far so good
    and it was doing it every time you were on the brakes below 5 mph
    455h0le_dachshund and shifty` like this.
  11. Jul 11, 2024 at 7:51 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Was it not seated all the way or what?
  12. Jul 11, 2024 at 8:09 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Mine did that when the tone rings were out of whack, so it's a sensor issue.
    455h0le_dachshund likes this.
  13. Jul 12, 2024 at 3:56 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    How did you fix it?
  14. Jul 12, 2024 at 4:14 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Pulled the abs fuse! We got the tone rings pressed back in right and it stopped doing i when we put the fuse back in.
  15. Jul 12, 2024 at 4:15 AM
    Weagle
    Prattville, AL
    The o ring look old and stretched. I'm thinking it happened when they took the knuckle off to replace the upper ball joints. And then they took it off and cleaned it after I hd the problem and put it back on and Didn't realize they pinched the o-ring which caused it not to seat correctly. The owner took it off and caught that
