Resistors
Discussion in 'Lighting' started by rons23, Jul 13, 2015.
  1. Jul 13, 2015 at 3:22 PM
    rons23
    rons23 [OP] Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    What's the general consensus on installing resistors for your led turn signal upgrade. Also would that be the only bulbs that need that. Reverse and parking should not need anything right. Just plan on changing all bulbs out. Thanks
  2. Jul 14, 2015 at 2:14 PM
    Mike Tread lightly.
    south carolina
    Dont use resistors for your blinkers. If you can get a led flasher use that. You will thank me later you did it.
  3. Jul 14, 2015 at 2:15 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    They make signal flashers for that these days, might be less hassle. Pull, plug in and done.
  4. Jul 14, 2015 at 4:07 PM
    rons23
    Ron
    Kill Devil Hills
    Ok, thanks guys. Seems resistors can put off some heat. Hopefully I can switch out flasher with led.
  5. Jul 14, 2015 at 4:32 PM
    Mike Tread lightly.
    south carolina
    I have heard reports of a few burn wires to small fires with resistors.
  6. Jul 14, 2015 at 4:38 PM
    rons23
    Ron
    Kill Devil Hills
    Yeah that's not good. I just read another article about led flashers, and unfortunately they don't have them for 2nd generation. there's a diy mod on the factory flasher about grinding down the loop, haha, on the flasher. I don't think so. So guess I will leave turn signals as is and change out back- up lights. Gonna research some more.
  7. Jul 15, 2015 at 2:10 PM
    Mike Tread lightly.
    south carolina
    That very strange that aftermarket hasnt pick it up unless there is some kind on patent thing going on with the unit.
  8. Jul 15, 2015 at 4:26 PM
    rons23
    Ron
    Kill Devil Hills
    I just emailed Diode Dynamics, they have a big selection of Led Flashers. Hopefully they have one with my name on it. Thanks for your help
  9. Jul 15, 2015 at 5:34 PM
    Mike Tread lightly.
    south carolina
    Let me know what you find.
  10. Jul 15, 2015 at 7:15 PM
    rons23
    Ron
    Kill Devil Hills
    Yeah man
  11. Jul 22, 2015 at 4:14 PM
    rons23
    Ron
    Kill Devil Hills
    No led flasher for 2nd generation Tundra. I talked to support over at Vleds and they actually have a kit that's plug n play. It's pricey, but no splicing or pulling oem flashers out. At least we have options. They supposedly have the brightest leds on the market. I'm gonna get leds for my back-up lights, and go from there.
  12. Jul 22, 2015 at 5:04 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I'm genuinely surprised, but you've done the homework. Thanks for sharing your findings.
    rons23[QUOTED][OP] likes this.
  13. Jul 22, 2015 at 5:48 PM
    Mike Tread lightly.
    south carolina
    This sounds like a patent issue. Great. Toyota at its finest.
    rons23[OP] likes this.
  14. Jul 22, 2015 at 6:53 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    In addition to looks, some of the benefits to LEDs is lower power draw (which is what causes the hyper flash), and lower heat generated. Adding resistors completely cancels out these benefits. Best to get a replacement flasher.
  15. Dec 22, 2015 at 6:42 AM
    lotsos2015
    lotsos2015 New Member
    Richard
    '15 White Crewmax SR5 4WD
    TRD exhaust, Tailgate mod, 5% tint all the way around, front window 35%, interior LED's, license plate LED's, Front Swaybar removed.
    Any links for this??
  16. Feb 8, 2016 at 12:23 PM
    alalmcgrath
    alalmcgrath Old Fart at Large!
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    Just a thought, would the first gen flashers work in the second gen trucks (if they make led type flashers)? Someone should compare part numbers. I can't imagine tundras uslng unique flashers for just one model.
  17. Feb 8, 2016 at 1:09 PM
    Mike Tread lightly.
    south carolina
    Different design in the base. The internals should be the same tho. Tho I have not looked at the wiring diagram on the 2gens to confirm it.
