Resetting YAW sensor.
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundraguy12, Jan 8, 2019.
  1. Jan 8, 2019 at 9:12 AM
    Tundraguy12
    Tundraguy12 [OP] New Member
    David Myers
    2015 Black Tundra TSS CrewMax
    Winjet Tails 5% Tint all around
    Who has done it themselves and is there a DIY thread? I’ve tried looking. Just lifted my truck and now having traction control light pop up on some sharp turns.
  2. Jan 8, 2019 at 9:31 AM
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    osidepunker likes this.
  3. Jan 9, 2019 at 6:35 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    I just did it yesterday to reset my default Steering Angle. what do you want to know?
    I did a google search and found the TSB on one of the forums. Basically you stick a paper clip on pin 4 and 12 of the OBD connector under the steering wheel. Do it while the truck is on (not started, but in the on condition), and tap those pins 4 or 5 times until the VSC light blinks or turns on (can't remember). then turn the truck off. Then stick the paper clip in 4 and 12 and leave it there and turn the truck on (not started, but in the on condition). then wait until the VSC light blinks or turns on (can't remember). then turn the truck off. Then disconnect the negative battery terminal for 10 seconds. Finished.
    Before I did this my steering angle showed 27 degrees when centered. After I did this it showed 0.0.
    that procedure is for resetting the steering angle after an alignment. It will also zero the calibration data and deceleration data. There are variations on this procedure if you need to reset for replacing the VSC actuator or yaw rate sensor.
    tundra_20, SprinterAE86 and Berkdawg like this.
  4. Jan 9, 2019 at 6:36 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    I do care to
    831Tun and tundra_20 like this.
  5. Jan 9, 2019 at 6:39 AM
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    Do these instructions help?
  6. Jan 9, 2019 at 6:41 AM
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    The dash screen shows the steering angle?
  7. Jan 9, 2019 at 6:50 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    No I connected a laptop and used techstream to read the steering angle. It also shows the X Y and Z axis reading too so you know if your sensor is reading level or not. You can also do the reset procedure using techstream, but it was too difficult to figure out so I just used the paperclip
    Vr0ck[QUOTED] likes this.
  8. Jan 9, 2019 at 6:52 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Thats the procedure I used, only the one I found was for a 2011. I have a 2013.
    They're probably all the same though.
  9. Jan 9, 2019 at 6:53 AM
    Greybeard
    Greybeard Retiree in training
    Forsyth Georgia
    2014 SR5 Double Cab
    Geez...ya'll too high techy for me. Lol
  10. Jan 9, 2019 at 6:56 AM
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    @osidepunker ive heard people doing a shim on the yaw sensor. Is that the alternative to correct the issue rather than do the reset?
  11. Jan 9, 2019 at 6:57 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    This shim is the dumbest idea ever. If your sensor is not reading level because you changed your suspension, then reset the calibration data and it will read level.
  12. Jan 10, 2019 at 6:29 AM
    Tundraguy12
    David Myers
    Thanks I will try the paper clip. Is there a video on it? Do I use just one paper clip and bend it the shape of a “U” or do I use two separate clips?
  13. Jan 10, 2019 at 6:31 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    just bend it
  14. Jan 10, 2019 at 7:01 AM
    Tundraguy12
    David Myers
    Ok, thanks
  15. Jan 15, 2020 at 10:47 AM
    Garcia2350
    Garcia2350 New Member
    2016 Sr5 tundra
    8 inch ready lift 5.29 nitro gears 22x12 hostile rage wheels -44 37x13.5x22 nitto rigdegrapplers
    I’m having that issue and leaning towards not doing the shim idea and having it properly calibrated...would the dealer be the only way to go? I’m in California haven’t started looking around local shops.
    thanks for any help.
  16. Jan 19, 2020 at 8:40 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Do not go to the dealer. Get a laptop and techstream cable and do it yourself. Or do the paperclip method (google it)
    Or if you are near Temecula or Moreno Valley I have techstream and I zero point it for you and show you how to do the paperclip method
    Also, see this thread: https://www.tundras.com/threads/veh...ely-sensitive-advanced-troubleshooting.38094/
  17. Jan 19, 2020 at 1:03 PM
    Garcia2350
    2016 Sr5 tundra
    Me and my buddie tried the paper clip method yesterday,still couldn’t get rid of the sound. We tried it 3 times and still the truck has the problem. I’ll look into that program and thanks for the offer but I’m in San Jose ca.
    Thank you for the help,hopefully can figure it out soon it’s driving me nuts lol
    osidepunker[QUOTED] likes this.
  18. Feb 24, 2020 at 4:51 PM
    Longtimecoming07
    Longtimecoming07 New Member
    Rick
    2012 Toyota Tundra
    Here are some diagrams
    Vr0ck and pickeledpigsfeet like this.
  19. Feb 24, 2020 at 4:52 PM
    Longtimecoming07
    Rick
    2012 Toyota Tundra
    And instructions
