Replacing the hose for the windshield wiper fluid
Discussion in '2.5 Gen Tundras (2014-2021)' started by satinhorseswon, Sep 8, 2023.
  1. Sep 8, 2023 at 4:47 PM
    satinhorseswon
    satinhorseswon [OP] New Member
    Nancy
    2018 Toyota Tundra
    none
    Does anyone have any tricks to changing this hose for the windshield washer fluid in my 2018 Toyota Tundra.
  2. Sep 8, 2023 at 5:02 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Which hose, or are you meaning all the way from the tank to the spray nozzles?
  3. Sep 8, 2023 at 6:19 PM
    satinhorseswon
    Nancy
    2018 Toyota Tundra
    none
    Crazy wood rats.! I made a clean cut about 20 inches from the reservoir. Spliced into it. Couldn't get under the hood so did a work around. Took of the hose at the reservoir and plugged the spliced one in. Works so I guess that is all that matters. I am lucky it wasn't more. Had to order a new cabin filter too. Had the machanic put it up in the air and checked under the guard plate and in the dash. I think I caught it in time from further damage. Put all kinds of sticky traps out. Caught one so far.
    Wynnded likes this.
  4. Sep 8, 2023 at 6:26 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Cool. Sounds like you got it sorted. You probably want to figure out what works for you to keep your unwanted guests out of the truck, they tend to really like the wiring insulation. You think that not having windshield sprayers suck, think about then getting into the wiring. Folks have tried a number of things, I sprayed some diluted peppermint oil all over in the engine compartment.
  5. Sep 9, 2023 at 4:30 AM
    satinhorseswon
    Nancy
    2018 Toyota Tundra
    none
    I started with peppermint spray. Then upped the ante with moth balls. Silly rat rebuilt his nest on top of the moth balls. So I now have sticky boards everywhere and am leaving the hood open. Maybe will get some string lights as well. It is war time!
  6. Sep 9, 2023 at 4:55 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Bait the spring traps on each wheel well overnight…..guarantee you get them. Maybe get some other critters attracted too though
  7. Sep 9, 2023 at 5:56 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Wow, that's pretty crazy...
