Replacing stock speakers
Discussion in 'Audio & Video' started by Tbonz1, Dec 17, 2018.
  1. Dec 17, 2018 at 2:59 PM
    Tbonz1
    Tbonz1 [OP] New Member
    Travis
    2018 tundra sr5
    Looking at replacing the stock speakers in my 2018 sr5 crew max anyone have any suggestions.
  2. Dec 17, 2018 at 3:01 PM
    anthonygan
    anthonygan New Member
    2017 Cement TRD PRO
    7in BDS lift, Spyder Smoked Taillights,
    What's your budget
  3. Dec 17, 2018 at 3:02 PM
    Tbonz1
    Travis
    2018 tundra sr5
    250~400
  4. Dec 17, 2018 at 3:06 PM
    FirstTruck
    FirstTruck New Member
    18 Tundra MGM CM TRD Sport
    Stock, for now
    Replacing the speakers will help the sound. As I understand the worst is that the head unit does not produce good sound so basically you are amplifying noise. Please correct me if Im wrong.
  5. Dec 17, 2018 at 6:42 PM
    dwelter
    dwelter New Member
    Dennis
    2018 Tundra XP package
    spacer lift front and rear, wheel spacers, sound system
    replaced my door speakers x4 and tweeters on the dash with Kenwood Excelon speakers. in addition, put in a 10" sub with custom ported box under the rear seat and Kenwood amp. Kept the head unit. Sounds incredible, have received many compliments.
  6. Dec 21, 2018 at 6:29 PM
    styx
    styx New Member
    Larry
    Knoxville, TN
    2017 SR5 DC TRD Offroad Magnetic Grey
    Raptor OEM Nerf Bars Leer Hard Tonnaeu Weathertech Vents Driver assist handle
    Same here except my system is all Pioneer. Kept original Entune Audio Plus HU. Sweet sounds and no noise.
    Rica25 likes this.
  7. Dec 28, 2018 at 9:31 AM
    FirstTruck
    Stock, for now
    Are you guys buying 6x9? Component? 6 1/2”? 5 channel amp? I would like to improve the sound but no idea what fits. Thanks for yr help
  8. Dec 28, 2018 at 3:38 PM
    styx
    styx New Member
    Larry
    Knoxville, TN
    hi_rawb likes this.
  9. Dec 28, 2018 at 5:58 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Get adapters and put 6.5" in a the doors
  10. Dec 29, 2018 at 9:50 AM
    OleRed15
    OleRed15 New Member
    East Tennessee
    Toyota Tundra 15’ Barcelona Red
    Color match, Nitto Ridge Grapplers, Ridgelander cover, LED hood strip, more to come,
    Asking for advice as I am about to do upgrade the audio. I have the JBL system but the previous owner installed the Alpine Halo9 (ILX-F309), love the head unit but the factory JBL speakers are sub par at best. My plan is to replace all door speakers and add a stealth box for the bass!!
    Why would you choose to do the 6.5" all around and not the 6x9"? What kind of audio are you using overall?
    Thanks
  11. Dec 29, 2018 at 10:06 AM
    Danimal86
    Daniel
    Sacramento, CA
    Are you sure that the previous owner didn't install new speakers too?
    6.5" speakers will give you the best midbass and a tweeter in the sail pannel for the highs.
    Match the speakers with a 5ch amp and get some subs in there and you'll be set.
    If you want some inspiration, check the link in my signature to my audio build.
  12. Dec 29, 2018 at 3:57 PM
    dwelter
    dwelter New Member
    Dennis
    For my Kenwood set up, in the front doors I installed the XR1800P which is a 7" speaker that fits in a 6.5" hole and fit the tweeter in the dash. For the rear doors, put in the KFC-X183c coaxial also with a 7" driver. The sub is a KFC-XW10000F which is a 10" shallow driver mounted in a custom ported box underneath the left side rear seat. The amp is a 5 channel 600 watt XR900-5 mounted under the front passenger seat. Pretty pleased with the overall result.
  13. Dec 29, 2018 at 4:11 PM
    lionix
    lionix The Grey Moose!
    Cape May, New Jersey
    2017 Tundra TRD Pro CM Cement
    BD Lights, Any Time Fog, Coachbuilder, Pelfreybilt, Bakflip, Custom Bed Rack w/ Tent
    Sub'd
  14. Dec 29, 2018 at 4:30 PM
    Jettech
    Jettech New Member
    Jesse
    Nashville, TN
    08' Tundra CM
    TRD Exhaust, DC 305/55/20s, TRD PRO Shocks, HID's, JOBOX, Bully Dog Tuner, TRD sway bar, Shorty FM Int,
    I wonder if I would have as good of luck with quality with my 2008 stock head unit or did they change them a lot in the 10 yr span. I just don't want an aftermarket head unit.
  15. Dec 31, 2018 at 11:50 PM
    hi_rawb
    hi_rawb New Member
    rob
    Bay Area
    2018 CM TRD SPORT 4x4
    2018 Trd Sport
  16. Jan 1, 2019 at 2:58 PM
    styx
    styx New Member
    Larry
    Knoxville, TN
    Very pleased with system. All Pioneer speakers and amp. 6x9's are 4 way coax and 6 1/2 are 3 way coax. Amp is GM-9605 digital. Dash corners are 3 1/2 2 ways. Sub is a 10" shallow and came with it's own box. The box fits inside the factory under seat storage face up which works well for my DC. Small package but hits quite hard. This is not a competition system and it's not a system that will shake the mirrors of other cars at the redlight. But if you like clean full spectrum sound with a good solid bottom and enough volume to run you out of the cabin this system will deliver. My HU is quiet, no noise whatsoever. I also have AudioControl load generators between the HU and LC7i which maintains a constant impedance of 4 ohms to the HU through out the audio spectrum. Each speaker has it's own tweeter and midrange. You would be hard pressed to tell the difference between this setup and a component system.
    jmdaniel and Rica25 like this.
