Replacing shock absorbers
Discussion in '1st Gen Tundras (2000-2006)' started by New Mexico guy, Sep 3, 2020.
  1. Sep 3, 2020 at 4:46 PM
    New Mexico guy
    New Mexico guy [OP] New Member
    Hello, I am the original owner of a 2005 Tundra SR5 with 235,000 miles. I have never had the shocks replaced. I don't off-road at all. I often drive on rural highways, far from any service station, and I would like to maintain my truck well, so as to avoid problems. Right now the shocks don't show any signs of trouble (tires wear evenly, no fluids on my driveway, truck handles well). But I would like to keep using my truck until the engine goes, so I'm wanting to replace the shocks.
    Could anyone suggest a manufacturer and model of shock absorber that would be a good fit? And, what would be a reasonable labor charge to replace all four shocks? Thanks very much.
    Thanx Pa RIP likes this.
  2. Sep 3, 2020 at 4:50 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Bilstein4600. Quality trd replacement
    bmf4069 and N84434 like this.
  3. Sep 3, 2020 at 5:10 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    If you plan on driving until the engine fails, you're only about 1/4th of the way there!
    You cant go wrong with Bilstein shocks. I'd be really surprised if you have a failed or failing shock now, even after 235K miles. You're definitely in the right part of the country for vehicle longevity
    oh and welcome to the club!
  4. Sep 3, 2020 at 6:12 PM
    shifty` In South Dakota Trouble ain't hard to find
    If not lifted, go Bilstein 4600. If lifted, leveled or you plan to lift, Bilstein 5100.
    bokch0y and GeezePlease like this.
  5. Sep 3, 2020 at 6:20 PM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    Bilstein 5100’s. Should be $2-3 hundred for install and alignment
  6. Sep 3, 2020 at 6:23 PM
    Professional Hand Model
    Hand Protectors
    I feel a shock war heating up. :rofl:
    bmf4069 and flyfisher like this.
  7. Sep 3, 2020 at 6:27 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Yup. I run them on my 1997 T100. Rides great. Bib boobs bounce nicely.
    Hbjeff[QUOTED] likes this.
  8. Sep 3, 2020 at 6:45 PM
    No need for war, whurld peas :D
    But seriously, 4600 of 5100, all the same internal/tech. If it's stock height and no possibility of lifting later, OP should save $100 or whatever and just get the 4600. No need to pay for something that won't be used when you could have something from the same vendor that's like OEM+.
  9. Sep 4, 2020 at 1:40 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I did a bunch of searching on that and never really found a straight answer. Are the 4600 and 5100 the same inside? I'm going lifted, but using OME coils so I don't need the adjustable perch of the 5100. Would rather save the money if they are the same internally.
  10. Sep 4, 2020 at 2:49 PM
    Hand Protectors
    The 5100’s are are great value and a nice shock. They are firmer than the 4600’s (OEM), and then the KYB’s, I had on my truck prior. I recco them for mostly street driving/tow/haul. Great all around on the street. You’ll drop$$$ if you want the Pure Off Road Shocks all the Pros have around here.
    Research Progressive and Digressive Shocks.
  11. Sep 8, 2020 at 7:23 AM
    According to the FAQ page I quoted above with the teeny-tiny print, both "share many of the same components", "same technology internally", "same internal valving ... will ride exactly the same at stock height", "outer construction is identical", "4600 is designed for stock height ...5100 designed for lifted trucks". Seems like the main difference is, simply, the outer coating and rubber boot, and the adjustability of the 5100, which is catered to lifted trucks.
    I'm no expert, but if a company is telling me there's minimal-to-no difference between two of their products and they're laying it out that clearly, I'm not going to listen to anyone trying to tell me I need to go with a more expensive product containing features I don't need and won't use. In this case, if the OP is staying at stock height, I'd buy the 4600, per the FAQ page up there.
    EDIT: The FAQ above is from ShockWarehouse @ https://www.shockwarehouse.com/news/bilstein-5100-vs-bilstein-heavy-duty.cfm - I trust they did their research w/the manufacturer on it. There are a number of supporting similar write-ups out there, like this ...
    Stuck in the '00s and Hbjeff like this.
