Replacing OEM JBL subwoofer with aftermarket question
Discussion in 'Audio & Video' started by V10Ace, Sep 12, 2018.
  1. Sep 12, 2018 at 6:00 PM
    V10Ace
    V10Ace [OP] New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    Hello all,
    First off I did try searching the forums but could not find the answer I needed.
    I want to simply put a better sub into the stock enclosure/system. Which shallow mount sub do you guys recommend? Can I run a dual voice coil sub with the factory wiring?
    I was looking at these two...
    2ohm dual voice
    https://www.amazon.com/Kicker-CompRT-Shallow-Subwoofer-43CWRT82/dp/B01BLVEXH2
    1ohm dual voice
    https://www.bestbuy.com/site/kicker...1-ohm-subwoofer-black/5190205.p?skuId=5190205
    Appreciate your guys input!
  2. Sep 12, 2018 at 6:09 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I think it depends on how you wire it. You can make it 2 or 4 ohm, then with the 1 ohm you can wire it for 1 or 2 ohm. Something about wiring in parallel or in series. Someone will be much more helpful than I am
    I'm interested in this as well so subd for ideas
    V10Ace[OP] likes this.
  3. Sep 12, 2018 at 9:28 PM
    Badbadleroybrown
    Badbadleroybrown New Member
    Eric
    2007 Black Tundra Limited
    I just replaced the sub in my 2007 DC Limited this week with the dual 1 ohm Kicker here: https://www.crutchfield.com/p_206CWRT81/Kicker-CompRT-43CWRT81.html?tp=111&omnews=7843632 and I wired it in series for 2 ohms to this amp: https://www.crutchfield.com/p_206CXA3001/Kicker-43CXA300-1.html?tp=115&omnews=7843632
    I clipped the blue and white speaker wires about 10 inches from the sub and taped off the blue wire. The white wire I connected to the white and the gray wire of this: https://www.crutchfield.com/p_575RFIF2SW/Rockford-Fosgate-RFiF2SW.html?tp=1694&omnews=7843632 and the two striped wires on the adapter I grounded to the truck.
    Pudge, V10Ace[OP] and Y0TA PR0 like this.
  4. Sep 12, 2018 at 9:29 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
  5. Sep 12, 2018 at 10:14 PM
    Duneflyer
    Duneflyer MGM is the light at the end of the tunnel
    Darren
    Yuma AZ
    2017 1794 edition Crewmax 4x4
    Nitro 4:88 gear package with locker in rearend, Procomp 6" lift, mid travel arms, with devers on back, Fox 2.5 coilovers
    I put 2 kicker dual voice coil 2 ohm subs behind my seats.. and changed the amp. Sounds killer .
  6. Sep 12, 2018 at 10:27 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    You got any pics?..and which amp?
  7. Sep 12, 2018 at 10:37 PM
    Duneflyer
    Darren
    Yuma AZ
    I'm actually selling the box and subs as we speak. I upgraded to the JL audio sub box kit .still using the same amp
  8. Sep 12, 2018 at 10:39 PM
    Duneflyer
    Darren
    Yuma AZ
    This is what I just replaced the kickers with
  9. Sep 12, 2018 at 11:13 PM
    Cfincke
    San Antonio
    If you have a crew max, you can fit full size subs in a box behind the rear seats. I have 2 JL 10" W1 subs in a ported box. you cannot fit the giant/deep subs, but there are multiple full size subs that will fit.
    Jai LI, Y0TA PR0, saybng and 2 others like this.
  10. Sep 13, 2018 at 5:45 AM
    V10Ace
    Salem, Oregon
    '21 TRD PRO
    Knew you guys would come through with some good info! I have the DC cab and just want enough bang to make my mirror shake. Thanks again guys
  11. Sep 13, 2018 at 6:24 AM
    V10Ace
    Salem, Oregon
    '21 TRD PRO
    Where did you mount the second amp? I think I'm gonna copy your setup. I'm pretty audio/electrical illiterate but I'm sure I can handle this myself
  12. Sep 13, 2018 at 6:56 AM
    Duneflyer
    Darren
    Yuma AZ
    I mounted my amp under the rear passenger seat in front of the Jack. Just cut the carpet.. cutout a section of styrofoam and fits beautifully .I left the carpet there.. just folded it back.. cut styrofoam.. then when done folded it back over to hide everything
    saybng likes this.
  13. Sep 13, 2018 at 7:13 AM
    saybng
    Gary
    Ventura CA
    How did u wiring it up?..
  14. Sep 13, 2018 at 11:48 AM
    Badbadleroybrown
    Eric
    It is right behind the sub box against the back wall. It fit perfect in that spot without having to cut anything.BBD07E1F-FADE-4CF9-97DC-AEFDEDDE68E1.jpg
    V10Ace[QUOTED][OP] likes this.
  15. Sep 13, 2018 at 8:28 PM
    Pudge
    CT
    Cheap here
    1 ohm and 2 ohm available $89 shipped.
    Instill don't know what to get 1 of 2 ohm.
    I think 1 would be better if not adding an amp. And I think it could be wired as 1 or 2 ohm depending on how you connect each voice coil.
    https://www.hifisoundconnection.com...CWRT81-Limited-Quantities-KIC13-40CWRT8-D1-RS
    https://www.hifisoundconnection.com...00W-RMS-2-Ohm-DVC-Car-Subwoofer-KIC16-43CWR82
  16. Sep 13, 2018 at 8:30 PM
    V10Ace
    Salem, Oregon
    '21 TRD PRO
    Pudge[QUOTED] likes this.
  17. Sep 14, 2018 at 8:21 AM
    Pudge
    CT
    Ordered the 1 ohm version. I'll be the Guinea pig lol. Will report back
    GodlessPro and Duneflyer like this.
  18. Sep 14, 2018 at 8:24 AM
    Duneflyer
    Darren
    Yuma AZ
    I'm curious how it will sound. I gutted my stock sub stuff for lots more bass. My stock sub and box is hanging out in the garage .
  19. Sep 14, 2018 at 8:29 AM
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    I'm interested in your results. Any plan for using that fluffy stuff that makes that enclosure seem bigger? Complete audio noob, so sorry for wording that like an idiot.
  20. Sep 14, 2018 at 8:33 AM
    V10Ace
    Salem, Oregon
    '21 TRD PRO
    I ordered the 1ohm and an inline amp as well. Will install end of next week hopefully. Not sure if 2nd and 3rd gen share some OEM box/sub?
    Pudge likes this.
  21. Sep 14, 2018 at 9:00 AM
    Pudge
    CT
    I actually thinking about getting some. Idk what its called either. anyone know?
    I'm gonna try with no amp. Nice we have 2 different tests going on
    GodlessPro[QUOTED] likes this.
  22. Sep 14, 2018 at 11:25 AM
    silverhack
    silverhack New Member
    Sacramento, CA
    2018 CrewMax Inferno
    From what little I have learned from googling, it looks like you can buy the 1 Ohm Kicker and since it has dual voice coils you can make it either 1 Ohm or 2 Ohm based on if you wire the two coils in parallel or series.
    If you buy the 2 Ohm Kicker you can wire it to be 2 Ohm or 4 Ohm (for the same reason).
    So I’ll buy a 1 Ohm and try it out as well!
    There are two of the Kicker CompRT 8” shallow-mount 1 Ohm subs:
    40CWRT81 (older model)
    43CWRT81 (newer model)
    V10Ace[OP] and Pudge like this.
  23. Sep 14, 2018 at 12:04 PM
    Twinky
    07 double cab work horse
    Polyfill is popular. Can get it at wallmart.
    If i remember right, 1 pound per cubic ft of volume. Could of been half a pound per cubic ft.
    Pink insulation works the best, but only for a sealed box ofcourse.
    Edit
    Fyi for those thinking about going with a 300 watt sub. The soundqubed s4 (4 channel amp) is only about $150.
    Its underated but will do easy 150 watts per channel. Thats your sub stage bridged for 300 (probably will do 325-350) and 150 watts per front door.
    One of the few amps that has bandpass crossovers too.
    Its a seriously bad ass amp and is hands down the best budget gem on the market.
  24. Sep 14, 2018 at 12:35 PM
    Pudge
    CT
    So I can just use regular pink fiberglass insulation? I have that
  25. Sep 14, 2018 at 12:42 PM
    Twinky
    A single 1 ohm dual voice coil (dvc) can be wired to present a .5 ohm load (parallel), or a 2 ohm load (series).
    2 dvc 1ohm subs can be wired to 1ohm load (series parallel) or a 4 ohm load (series).
    Parallel lowers the original ohm load and series raises the ohm load. Series parallel will present the original ohm load. That only applies when using two dvc subs and there is a certain way to do it.
  26. Sep 14, 2018 at 12:46 PM
    Twinky
    Yep. 1 pound per cubic ft of internal volume. Theres a little wiggle room there, of course. But to much and you will start to see diminishing returns.
  27. Sep 14, 2018 at 12:48 PM
    Pudge
    CT
    Thanks. So I ordered a single 1 ohm dual voice coil. How would you recommend working it. I am not adding an amp but simply connecting existing speaker wire. And what is series and parallel? Sorry for dumb questions, it's been a long time since I messed with car stereo
    Thanks man.
  28. Sep 14, 2018 at 12:54 PM
    Twinky
    How much mounting depth are yall working with? The selection of 8 inch subs these days are awesome, and still around that same price range.
  29. Sep 14, 2018 at 12:55 PM
    Pudge
    CT
    Stock sub box on crewmax witb JBL
  30. Sep 14, 2018 at 1:10 PM
    Twinky
    Ill find a pic that will explain it much better than i can type it out. You'll totally get it when you see it.
    Bottom left of the one is the way you want to wire a dual 1 ohm sub. The stock amp and sub i believe was wired at a 2 ohm load.
    The top left sub wiring config is parallel. Its simply daisy chaining the positive to the next positive terminal.
    The bottom left one (the method youll use) is a series wiring config. Wiring starts off normal like you can see. But the then you just run a wire from the second positive to the second negative terminal.
    Thats also from kickers site with some explaination.
    Edit
    Ignore the "4ohm" thats writen on bottom left wiring con fig in the pic. The pic is just for reference.
