Replacing headlight sockets
Discussion in '1st Gen Tundras (2000-2006)' started by Kris2003, Mar 2, 2018.
  1. Mar 2, 2018 at 2:22 PM
    Kris2003
    Kris2003 [OP] New Member
    Hi all,
    could use some help on this. been kicking my but for some time...I had to replace my headlight sockets because the driver side socket burned out. I cannot seem to find the right wiring sequence. I replaced the socket with the three prong dorman type socket. The wires are green, black, and red.........
    My wiring is red/green, red/blue, red/yellow on the driver side and red/green, red/blue, and red/white on the passenger side..
    Am i looking too hard at this or what? Can someone tell me the right way to hook it up. I even put a meter on it but I think it was backwards..My brights came on when dim switch was on and dim when it should have been brights.
    I appreciate any help.
    Thanks,
    Kris
  2. Mar 3, 2018 at 7:34 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Top image is the passenger side, driver is the lower. Disregard the wire colors on your new plugs and just match up the truck colors to the correct pins.
  3. Mar 3, 2018 at 7:50 AM
    Kris2003
    Thank You so much!!!
  4. Jul 4, 2018 at 1:01 PM
    Landman500
    Landman500 New Member
    joseph
    2016 Tundra double cab limited try off road
