Replacing bed rail cap
Discussion in 'General Tundra Discussion' started by TommyTundra, Jun 22, 2021.
  1. Jun 22, 2021 at 3:15 PM
    TommyTundra
    TommyTundra [OP] Oh God the anger’s changing me
    Long Island NY
    2019 PRO
    I have a ARE fiberglass tonneau cover on my 2019 PRO. Im removing and selling it tomorow. Im replacing it with a Diamonback HD. My problem is this. The ARE cover I assume wasnt aligned correctly by the previous owner and it was rubbing the body right where the plastic bed rail and tailgate caps meet the body. Now it has multiple wear spots right down to the bare steel. I was looking to replace the bed rail and tailgate caps with something that will extend down the body an inch or so to cover the wear spots. Then I was considering having a spray in liner place remove the caps and sprayline just over the edge to cover the wear spots. Anyone have this issue or any advice?? Im open to all suggestions. Thanks guys
  2. Jun 22, 2021 at 3:26 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Pictures will help get you a better solution. What you proposed sounds good without seeing it.
  3. Jun 22, 2021 at 3:36 PM
    TommyTundra
    Long Island NY
    2019 PRO
    Will post pics in a bit. Finishing up at work then go out in the rain
    Saltyhero13 likes this.
  4. Jun 22, 2021 at 4:27 PM
    TommyTundra
    Long Island NY
    2019 PRO
  5. Jun 22, 2021 at 6:44 PM
    2mchfun
    I used to buy some bed rail cap material on a roll from jc Whitney years ago. I think Amazon has similar stuff. Just google rubber bed rail cap material or similar.
  6. Jun 22, 2021 at 7:26 PM
    15whtrd
    15whtrd Mr. Blonde
    My personal solution would be to take the plastic caps off, go have the area linexed just beyond where the paint has rubbed through. Then install your old caps or get some new ones and snap them down on top of it. Probably hardly notice it. I actually wish I had removed my caps when I got my bed sprayed so they could do an over the rail lining job. Then put my caps back on.
    itsallgood101, Skew12 and 2mchfun like this.
  7. Jun 23, 2021 at 12:55 AM
    TommyTundra
    Long Island NY
    2019 PRO
    Thank you all for the advice. There is definitely no rust yet. The last pic looks like it but its the lighting and the reflection of my shirt. I think im going to Linex it and then reinstall the plastic caps. Thanks again
    15whtrd and 2mchfun like this.
  8. Jun 23, 2021 at 12:31 PM
    clarkritchie
    clarkritchie New Member
    Is there an aftermarket bed rail + tailgate cap? I've looked but haven't found one.
  9. Jun 23, 2021 at 1:35 PM
    TommyTundra
    Long Island NY
    2019 PRO
    Nothing i saw either. So im just gonna do the Linex and pht the old bed rails back on
    15whtrd likes this.
  10. Dec 9, 2021 at 7:22 PM
    970KOM
    970KOM New Member
    James
    18 TRD
    I’m in the same boat but can’t find any aftermarket rail covers that would hide it.
    Please let us know how the caps fit back on after lineX.
    I’m worried the caps won’t snap back on with the thickness of the lineX.
  11. Nov 16, 2022 at 6:45 PM
    SeanO86
    SeanO86 Live Slow. Die Whenever.
    2018 SR5 Tundra TRD Off Road - Cement
    Fox 2.5 w/Resis +1 CB Shackles SPC UCA Alcan 750lb springs - +1" lift 3" Front : 1.65" Rear to level Toyo ATII 35s Icon Six Speed +25 offset Wheelers Superbumps Chrome delete ARE Z Topper w/ Thule rails Pinsu Topper rack RTT - Tepui Autana Ruggedized 3
    Did this wind up working?! I have the same issue and a linex shop said they wouldn’t recommend doing it because the oem
    Bed rail cap clips wouldn’t fit back in the holes properly since you’re effectively adding a few millimeters height.
    Thanks!
  12. Nov 17, 2022 at 1:07 AM
    TommyTundra
    Long Island NY
    2019 PRO
    I honestly cant tell you. I have never used the OEM clamps. They are still in the factory packaging
  13. Nov 17, 2022 at 6:43 AM
    SeanO86
    But did you line x and put bed rail caps back on? If so how did you secure the bed rails? Do you have any photos of your solution? Sorry for all the questions; Would love to see how you did this.
    I’m not familiar with the clamps. All I know is that the oem bed rails have tiny plastic clips Built in. Are those the same ones you’re referring to.
  14. Nov 17, 2022 at 6:49 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Line x is probably the most realistic and cheapest solution.
    SeanO86 likes this.
  15. Nov 17, 2022 at 9:18 AM
    SeanO86
    Yeah I agree! But my only concern with that is the bed rail caps going back on properly after line x is put on. There are clips on that plastic bed rail cap and slots on the metal bed rail … the thickness of the line x may interfere with it going back on right.
    or are you saying just use line x and forget about putting the bed rail caps back on entirely?
  16. Nov 17, 2022 at 11:59 AM
    MadMaxCanon
    You have a point, I dont think you can do away with the bed rail caps if you are using the diamondback. I have it too and dont see a way for it to seal up properly without the caps.
    NewImprovedRon likes this.
  17. Nov 17, 2022 at 1:03 PM
    TommyTundra
    Long Island NY
    2019 PRO
    I have a diamondback and you definitely need to re-install the bed rail caps. I didn’t go the Linex route. I used some Raptor liner from a previous project. I went with two light coats. I pulled the tape immediately after spraying and then let it dry. I then used a few 1/2 copper fitting brushes to clean out the slots and holes for the plastic clips on the underside of the bed rails. I also bought new bed rail caps because a few of the plastic clips broke during removal. Sorry no pics of the job in progress but I will take a few of the completed job tomorow in the light.
    SeanO86 likes this.
  18. Nov 17, 2022 at 4:42 PM
    SeanO86
    thanks man! Much appreciated. ideally I take a similar route. Would love to see how it turned out whenever you have time to send pics.
    yeah definitely want to use the bed rail caps again. I’ll buy new ones. I’m getting a GoFastCamper in a few weeks and it lines up / seals nicely flush on top of the bed rail caps.
    MadMaxCanon[QUOTED] likes this.
  19. Nov 5, 2023 at 7:23 AM
    Oori
    Oori New Member
    Oori
    2012 Tiundra Double Cab
    Where are you all getting new bed rail caps? I have a 20121 Tundra double cab 6.5" bed and cannot find them anywhere. Any help is appreciated. They ar going under a Super Pacific. Thanks.
    floridahawk likes this.
  20. Nov 5, 2023 at 8:55 AM
    Bradleybb
    Bradleybb New Member
    Georgia
    2021 CM TRD OR
    Transmission cooler TRD REAR SWAY RCI front skid
    Ebay has for 2.5 gen less than 100$ for pair ,not as perfect as Oem but close enough compared to oe price $175 each
  21. Nov 5, 2023 at 9:09 AM
    Willard
    Willard New Member
    2024 F250
    I had a diamondback hd on my 2020 for a couple years and the weight and/or clamping force of the cover combined with the movement of the bed sides when you hit bumps causes it to flex. Eventually the paint under the plastic bed rail caps where they sit on top of the bed sides will also wear through.
    Removing the plastic caps and doing linex or similar is definitely a good option. You should also run a bead of silicone under the caps before putting them back on, especially at the front corners near the cab. This is the main water entry point with a diamondback cover.
  22. Nov 5, 2023 at 10:02 AM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    When I took my bed rail caps off for installation of my DiamondBack SE, I placed PPF underneath them to protect the paint on the bed rails. You can trim the PPF right up to the bed rail caps and you can't even see it. The shims that DiamondBack includes with the tonneau cover kit keep the bed rail caps from compressing/deforming when you bolt down the DiamondBack center section. I placed some 40 lbs. bags of bird seed on the 4 corners of the cover before I adjusted the locking rods and don't have any leaks.
  23. Nov 5, 2023 at 10:29 AM
    Oori
    Oori New Member
    Oori
    BradleyBB, I have a 2011 Tundra. Do you 9or does anyone) know if the Gen 2.5 cap will fit on a Gen 2?
  24. Nov 5, 2023 at 11:07 AM
    Bradleybb
    Georgia
    2021 CM TRD OR
    No
  25. Nov 5, 2023 at 2:17 PM
    Oori
    Oori New Member
    Oori
    No it won't fit? Or no you don't know? If you know that it won't fit I'm curious if you know the difference between those two versions. I asked because I just bought a super Pacific that they say fits on all Gen 2 tundras, but if there's a difference between them it would be good to know. Thanks again for your help.
  26. Jan 30, 2024 at 12:00 PM
    floridahawk
    floridahawk New Member
    I hate to drag this old thread back up, but I’m having the same issue as this guy. I have a 2012 with a 6.5 bed. I want to take the bed rail caps off and clean out underneath them, but I’m afraid the clips will break and I’ll be SOL. There are countless bed rail caps for sale on eBay, but they are all labeled for 2014-19. Anyone know if those have the same clip positions as the 2012?
  27. Jan 30, 2024 at 12:05 PM
    831mic
    831mic 2016 DC TRD PRO
    California
    '16 DC TRD PRO
    I ripped mine off thinking I was going to replace them because they were pretty beat up. I ended up putting them back on because it's out of budget at the moment. I ripped maybe 2-3 clips off, total (both sides). It all went back on w/o a problem and stays where it should be.
    floridahawk[QUOTED] likes this.
  28. Jan 30, 2024 at 12:16 PM
    floridahawk
    Thanks, that makes me feel better about pulling them. I went to the dealership after exhausting eBay and parts websites and they quoted me $199 per side :eek2:
  29. Jan 30, 2024 at 12:24 PM
    clarkritchie
    I also broke a few clips when I removed mine a few years ago, and it hasn't been an issue. I would still like to swap them for something other than the plastic ones due to the fact that they compress so much when clamped...
