Replacement Tail lights
Discussion in '2nd Gen Tundras (2007-2013)' started by oldscout1001, Sep 22, 2020.
  1. Sep 22, 2020 at 7:01 AM
    oldscout1001
    oldscout1001 [OP] New Member
    2008 Radiant Red Toyota Double Cab SR5 TRD Off Road
    I need to replace the driver's side tail light on my 08 Tundra. I've made this simple task really more difficult then it should be. I've seen tail lights on Ebay that are listed as factory OEM but they're also listed as halogen or LED which I know mine is not. I just want to make sure it matches the other light. I've also considered this as a good opportunity to replace both with nice aftermarket blackout/LED or something. Are there any companies you would highly recommend for after market lights? I know there's a lot of cheap no name crap out there that I want to avoid.
    Thanks in advance.
  2. Sep 22, 2020 at 7:08 AM
    War Machine
    War Machine SSEM # 5 3MW
    It’s hit and miss with aftermarket brands. I’ve had these on my 2011 Tundra for nine years with no issues.
    Spyder Auto Toyota Tundra Black LED Tail Light https://www.amazon.com/dp/B004VTZVR8/ref=cm_sw_r_cp_tai_.tGAFbJHGCT1P
    The same lights are listed cheaper under another brand name, but don’t know what the difference is.
    For 07-13 Toyota Tundra Pickup Truck Black Bezel Rear LED Tail Lights Brake Lamps Replacement Pair https://www.amazon.com/dp/B01LX3VG7F/ref=cm_sw_r_cp_tai_UuGAFbAFX0HJ1
  3. Sep 23, 2020 at 12:00 AM
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
  4. Sep 23, 2020 at 1:58 AM
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
