Replacement rear leaf packs
Discussion in 'Suspension' started by WRO, Nov 28, 2023.
  1. Nov 28, 2023 at 8:58 AM
    WRO
    WRO [OP] New Member
    Ryan
    2019 Tundra
    Lift, bumpers, etc
    On my tacoma, I ran OME rear leaf packs and really liked them.
    I haul a 24' boat from time to time and spend alot of time off road on Moderate trails and whoops.
    I have a decked and dog box (150lbs) in my truck bed most of the time.
    What is a good replacement leaf pack?
  2. Nov 28, 2023 at 9:06 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
  3. Nov 28, 2023 at 9:12 AM
    +1 on Alcans. Lew will get you set up.
  4. Nov 28, 2023 at 9:59 AM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    I had OME on previous vehicles and always liked them too.
    I have a similar load as you, decked with a fiberglass topper. I still have stock springs with the RAS system, HD, cranked up to having both washers slide in snuggly. Ended up getting all the rear height back plus about 1/4". Ride is very good.
    Goal on this truck is to not lift it, so i was hesitant on just tossing on a set of OME rear leafs. This solution seems to be working very well so far.
  5. Nov 28, 2023 at 10:31 AM
    WRO
    WRO [OP] New Member
    Ryan
    2019 Tundra
    Lift, bumpers, etc
    I have a 3" lift currently so that ship has sailed.
    _none_[QUOTED] likes this.
  6. Nov 28, 2023 at 11:55 AM
    AndrewMT34
    AndrewMT34 New Member
    Andrew
    ID
    2017 TRD Pro
    Stage 8 Icon Decked Durobumps U-bolt Flip Kit
    I have the stage 1 icon RXT pack. With a fiberglass topper, decked, and 2 gunner kennels with ~40lb shorthair and griff I sit dead level. I will likely reconfigure the spring pack to be stage 2, or upgrade to the Deaver U748 to get some rake back. The icon leaf pack is a bit squeakier than the deavers I had on my Tacoma. I've seen a fix that involves lining the leafs with bicycle inner tube, so I may try that first.
  7. Nov 28, 2023 at 8:04 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Love my Deaver U748 packs. My truck is a fat pig and they handle it all day.
    Standard load is my ARE canopy, bedslide, a box full of basic tools and gear in the bed, and a 50 liter Dometic full of cold ones.
    I tow regularly, whether it is a 20’ flatbed weighing as much as 7,600# or my 25’ travel trailer.
    I have about 55K miles on the springs now and they’re still beautiful. Mostly on the road, but I don’t hesitate to bomb through some rough roads or mild whoops.
