Replaced the starter, still not working.
Discussion in '2nd Gen Tundras (2007-2013)' started by NickyP, May 2, 2019.
  1. May 2, 2019 at 10:29 AM
    NickyP
    NickyP [OP] New Member
    2007 4.7 Tundra SR5
    I replaced the starter in my 07 Tundra 4.7 SR5. it’s still making a single click sound and not turning over. Anyone know what it could be?
  2. May 2, 2019 at 10:34 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Did you check the battery?
  3. May 2, 2019 at 10:38 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Load test battery. Make sure terminals and clamps are clean, bright metal, and tight.
    Have you tried barring the engine over manually?
    NickyP[OP] and GNTundra like this.
  4. May 2, 2019 at 11:05 AM
    TheBeast The Beach
    does the truck start with a battery charger ?
  5. May 2, 2019 at 11:07 AM
    woah62
    woah62 Resident Evil
    2017 Sunset Bronze Mica Tundra SR5
    Maybe check the battery.
  6. May 2, 2019 at 11:10 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    I hope u checked the battery first before changing ur starter
  7. May 2, 2019 at 11:11 AM
    woah62
    I've heard changing the starter on the newer Tundra can be a chore.
  8. May 2, 2019 at 11:12 AM
    TheBeast The Beach
    +1. oem Batteries on Tundra are known to fail often.
    You will change batteries multiple times before the starter on a Tundra. I think i'm on my 3rd Toyota battery. Still sticking to it since the warranty keeps covering it :)
  9. May 2, 2019 at 11:14 AM
    Porschetech29
    Porschetech29 New Member
    Francis
    Rancho Cucamonga, CA
    2008 white double cab 4x4
    Also check to make sure the engine to chassis ground is good.
    If all else fails perform a voltage drop test of the B+ cables to make sure there is not high resistance in the circuit (poor connection or corrosion).
  10. May 3, 2019 at 9:51 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Could be ignition switch, it’s cheap and easy to install, just remove your key cylinder.
    NickyP[OP] likes this.
  11. May 4, 2019 at 1:02 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Also, if the starter is aftermarket it could be a piece of shit Chinese reman unit. I regularly get bad ones out of the box.
