Replace ReadyLift 3/2 with this setup?
Discussion in 'Suspension' started by Tundra234, Jun 3, 2019.
  1. Jun 3, 2019 at 2:49 PM
    Tundra234 [OP] New Member
    Looking at replacing my 3/2 with this to keep the same lift height.
    Toytec Boss coils at 3"
    Toytec Boss rear shocks and 1.5 shackles with Toytec 1/2 inch axle shims (blocks) to get the 2" in the rear.
    Do I need any shims (size and how many) for the front for any lean or adjust the coil to even it?
  2. Jun 3, 2019 at 4:24 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    I have the toytec boss coilovers with 700lb springs. They're set at 3.5". No lean. You won't need shims cause you can adjust them. I'm planning the boss rear shocks this summer. I removed the front swaybar, rides soo much better.
  3. Jun 3, 2019 at 4:28 PM
    I thought 3" was the max recommended on the Toytecs? You run 1.5 shackles in the rear?
  4. Jun 3, 2019 at 4:40 PM
    Berdine
    Binghamton, NY
    I have the rough country blocks that came with my 3/2 lift. I also added a carrier bearing drop from boss 4x4s
