Replace or ignore missing front wheel / disc brake dust shield
Discussion in '1st Gen Tundras (2000-2006)' started by ktundra, Sep 20, 2020.
  1. Sep 20, 2020 at 5:49 AM
    ktundra
    ktundra [OP] rust be damned
    Lex
    NJ
    06 Tundra DC Limited 4WD
    Bilstein 5100
    Mine are completely disintegrated by rust.
    It will be a huge chore to try and remove the factory bolts. How important is it to replace them?
    Will brake and metal dust just accelerate the rust throughout the front end?
  2. Sep 20, 2020 at 6:50 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    The brake shield is there to keep larger objects, like rocks, from getting stuck between moving brake components. If you don't off-road much or where there is rock, it should not be a problem to leave as is. It doesn't really stop any water, dust or dirt from getting anywhere just larger objects. Probably will be ok as is.
  3. Sep 20, 2020 at 5:38 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    I concur. Mine were all but gone when I rebuilt the front end. I couldn't justify spending 170 bucks on new ones, so I'm going without.
    ktundra[OP] likes this.
  4. Sep 20, 2020 at 6:33 PM
    ktundra
    Lex
    NJ
    Bilstein 5100
    Thank you for confirming @N84434. Mine will remain without dust shields!
  5. Sep 20, 2020 at 8:49 PM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Like Johnsonman said, if you're not doing any serious rock crawling, it should be fine.
  6. Aug 17, 2022 at 6:54 AM
    Svengalicanada
    Svengalicanada New Member
    2010 rcsb 4x4 4.6l
    Old thread I know , but ....what about gravel roads? And dont forget our front brakes dont sit close to the inside of the rim or even center they are just behind your valve stem because of our 60mm offset. you would think some type of solid hubcap for the OUTSIDE would be standard if this was an issue??
    I can see them being more important for older drum brakes then discs which somewhat clean themselves.
    Some claim the dust plates have vents to help cool your brakes.well I'm not in a nascar race and I'm not slamming my brakes on every couple hundred feet to turn left.! I also dont live in a mountainous area. I can't see brakes heating up being an issue for me.
    Thoughts anyone..???
  7. Aug 17, 2022 at 7:49 AM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    I would think the same rules apply. I've been down just a couple gravel roads over the last 2 years with my truck and have not experienced anything remotely close to a problem with gravel getting lodged in the calipers.
    Brake cooling via the dust shield.... Meh.. Probably not. I would think that running without would be better in that instance.
    Svengalicanada likes this.
  8. Aug 17, 2022 at 8:34 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I went without, but when I had to have the hub off for a new bearing, I went for a new shield (~$70 as I recall)
  9. Aug 17, 2022 at 9:57 AM
    Svengalicanada
    2010 rcsb 4x4 4.6l
    Yup..think I'll break off what's left of mine and go without till I need new hub bearings.
    Thanks for the input !
    N84434 likes this.
  10. Aug 17, 2022 at 10:02 AM
    Svengalicanada
    2010 rcsb 4x4 4.6l
    Looking at your pic w666 makes me wish they had the bolts facing the other way and it was 2 pieces..then you'd only have to likely take off the caliper to change it
  11. Aug 17, 2022 at 10:39 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    You can buy a new one and make it a two piece.
    HAL69000, N84434 and w666 like this.
  12. Aug 17, 2022 at 11:21 AM
    w666
    Maryland
    Had I not been "lucky" enough to need a new bearing, I would have done just that...split the OEM shield in two, then fasten it in place. The only challenge is to secure the outsides of the splat so it doesn't rattle around.
  13. Aug 18, 2022 at 8:26 AM
    HAL69000
    HAL69000 New Member
    2004 Double Cab 4WD
    I have a spindle out right now and am not bothering to replace.
