Replace brake drums?
Discussion in '1st Gen Tundras (2000-2006)' started by RR60, Feb 13, 2020.
  1. Feb 13, 2020 at 10:09 AM
    RR60
    RR60 [OP] New Member
    2003 SR5 Tundra long bed
    Was going to take the wheels off and paint the rear brake drums. But would need the wheels off for a couple days for first the primer then paint to dry.
    But is it worth it just to replace the brake drums? Do they ever need to be replaced. If so is there a good aftermarket.
    Truck is 17 years old and been very dependable and dont mind putting a little money into it occasionally.
    And plan on keeping the truck 10 more years whatever it takes.
    Any thoughts
    Thanks
  2. Feb 13, 2020 at 10:12 AM
    15whtrd
    15whtrd Mr. Blonde
    Sounds like it would be much easier to just get new drums and shoes now while you have it apart. That way you could have the new drums painted and ready to go with minimal downtime of your truck. Although it couldn’t hurt to take them off now and inspect to see if you were going to need a new brake cylinder or if your axles are leaking or anything.
    SprinterAE86 likes this.
  3. Feb 13, 2020 at 11:30 AM
    noahrexion
    noahrexion New Member
    Washington
    2005 4WD DC
    Bah...
    Just paint them on the truck. Grab some news paper and wrap/mask everything you don't want paint on - use tape for the rest (wheel studs...etc). Rattle can it all black, leave it for few hours and then bolt the wheels back on. You can always roll up paper and stuff into cracks if you care (drum:backing plate). Done deal.
    02goes and Aerindel like this.
  4. Feb 13, 2020 at 12:06 PM
    Professional Hand Model
    Hand Protectors
    I wire brushed, washed with dish soap, dried them, and primed/finish coated my rear drums in a half days time. It was a nice weather day.
    I used ceramic high temp primer and Rustoleum Gloss as a finish.
    Wire brush the mating surfaces really well.
    Put some anti-seize on the wheel mating surface prior to bolting them back on the drum.
    15whtrd likes this.
  5. Feb 13, 2020 at 1:41 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    When the drum gets scored or worn, you can have them machined, if they have not reached the max diameter. So yes, they eventually will have to be replaced.
    15whtrd and 02goes like this.
  6. Feb 13, 2020 at 5:24 PM
    02goes
    02goes New Member
    2002 Tundra Limited 4X4
    Ya know competent places (which includes believe it or not old school small gas stations that still repair vehicles) always put new brake drums on the machine. If their even the slightest out of round, they obviously get turned to being true because they are on the machine. It's not a slam install and forget about it job as auto parts places make it to be. So if you buy brake drums from a auto parts place that also does auto repair, tell them to ck/true the drums. Why, saves from premature brake pad wear, and at the worst guess what it would be. Brake shudder.
    Again, even when new, have the drums turned. They are never true. It's minute, but the pros do it to eliminate any reason for premature brake wear and shudder.
    PCJ and 15whtrd like this.
  7. Feb 13, 2020 at 5:31 PM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
