repeating clunking coming from front end
Discussion in '2nd Gen Tundras (2007-2013)' started by SumTingWong, May 27, 2024.
  1. May 27, 2024 at 5:09 PM
    SumTingWong
    SumTingWong [OP] New Member
    2008 Green Tundra 5.7 TRD
    Has anyone had an experience with a repeating clunking noise that sounds like its coming from the front end passenger side? The clunking starts around 15-20 mph, occurs when going straight as well as turning, is pretty loud, and are uniformly spaced when maintaining the same speed. The frequency increases in tandem with the vehicle's speed. It seems to come and go. I noticed it months ago and immediately brought it into a shop; I was told by the mechanic it was a bad lower control arm. I brought it to a second mechanic who was unable to get the noise to start, but assured me my LCA's are perfectly fine. The noise has now come back and has not gone away in about a week. Any insight on what this could be would be much appreciated.
  2. May 29, 2024 at 8:45 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    If any suspension work has been done, I would get the sway bar end links checked, if you don't know, have your end links checked anyway. Also check the front sway bar to ensure the bushings have not slid out of place.
  3. Jun 20, 2024 at 6:33 AM
    mzim
    mzim New Member
    Max
    Waterloo, Iowa
    2015 Tundra DC Silver Sky
    275/65/20 Goodyear Wrangler Duratracs (May2024) Full ARH long tube system Bilstein 6112 Front +2.7" Bilstein 5160 Rear & Icon 1.5 AAL & +2.0 Shackles Fender Flares 1D6 White Knuckle sliders TRD Grille Morimoto LED Headlights with LED DRL/sequential amber switchback turns Rigid Fogs with Square TRD Bezel 4x LED bed lamps wired in OV Tune base load with iterations coming Tech12Volt remote with 2 way fobs and range extender antenna 4.88s with Auburn TRD skid plate Koyo radiator - FAILED REINSTALLED OEM Tyger tri-fold bed cover Bed mat from Boss 4x4 Front bumper spacers 0.5 inch by Boss 4x4 Pop n Lock tailgate wired in Black badging all around Classico Faux Leather Seat Covers Rough Country Floormats Halo 9 HU Underseat kicker sub JRT upgraded speakers
    I had this klunking noise for two years. Mostly while driving slow and turning, like maneuvering for a parking spot. I tried pinpointing the source with no luck. Even took it to Toyota Service. Even they couldnt figure it out blaming it on my meager 2.5 lift (Bilstein 6112s , 3rd setting). I recently took it to a local shop to get my 6112s swapped out as the old ones were leaking. They suggested an alignment as well. I went to pick up the truck and driving out of the parking lot I noticed to klunking noise was GONE. The service tech had told me my alignment was pretty far out. They did a great job aligning the front end, even better than Toyota service. Im not stating that everyone experiencing this annoying popping, klunking noise needs an alignment, just what worked in my case. But it is damn nice driving my truck with no popping sound. Hope this helps someone else.
