Repeated fuel pump failures possibly due to winter conditions or pressure issues
Discussion in '2.5 Gen Tundras (2014-2021)' started by DIMWIT, Dec 30, 2023.
  1. Dec 30, 2023 at 5:16 PM
    DIMWIT
    DIMWIT [OP] New Member
    2014 SR5 5.7
    Question on what would cause the fuel pump to fail 4 times and need replacing. Every couple of years during winter the pump start to make a buzz sound and the truck starts hard. Unless I just leave the key on a for a while to 'build pressure'. Sometimes the truck tries to start then finally cuts off. Any idea on what could cause this over and over? It was replaced under warranty all those times just out of warranty now.
    Thanks for any ideas!
  2. Dec 30, 2023 at 7:18 PM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    Just a guess but maybe fuel filter ?
  3. Dec 31, 2023 at 6:37 AM
    DIMWIT
    2014 SR5 5.7
    No performance issues wants running though. Figured if it was the filter it would be sluggish or inconsistent while running.
  4. Dec 31, 2023 at 6:53 AM
    Pinched fuel line?
  5. Dec 31, 2023 at 7:04 AM
    DIMWIT
    2014 SR5 5.7
    Replacing the pump will last over a year with no problems, sounds or anything. Then out of no where the buzz noise comes back and hard starts happen. Not sure if it electrical thing or what. Just curious if anyone else had this issue before.
  6. Dec 31, 2023 at 7:13 AM
    CreekDweller
    CreekDweller Not so new ...
    2020 MGM 1794 TRD Off-Road
    Do you often run your tank to nearly empty of gas? If so, your pump may be subject to repeated overheating that shortens its life. The gasoline in the tank isn't just fuel, it is also used to cool your pump. Don't know if this is your situation, just a possible explanation.
  7. Dec 31, 2023 at 7:18 AM
    DIMWIT
    2014 SR5 5.7
    That would make sense but I never run under half a tank.
  8. Dec 31, 2023 at 8:50 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    OEM or aftermarket Chinesium? I would only use Denso parts for this.
    KNABORES likes this.
  9. Jan 2, 2024 at 7:12 AM
    DIMWIT
    2014 SR5 5.7
    77020-0C120 TUBE ASSY this is the model sent from a friend at the dealership. I would rather not use the same thing that has died over and over.... any ideas on something better quality maybe?
