Removing TRD stickers
Discussion in '2nd Gen Tundras (2007-2013)' started by Wisconsin Bill, Feb 8, 2015.
  1. Feb 8, 2015 at 10:30 PM
    Wisconsin Bill
    Wisconsin Bill [OP] New Member
    Bill
    07 Tundra Dbl TRD
    in the plans!!!
    So after much thinking about plastic dipping, I've decided instead to remove all the badges as well as the TRD decals. I see no problem with using fishing line to remove badges. I would like some suggestion as to removing the TRD stickers on rear bed quarters.
  2. Feb 9, 2015 at 12:14 AM
    tat2ude39
    tat2ude39 MYota
    Robert
    San Tan Valley, AZ
    2021 Tundra SR5 Crewmax ~ ARMY GREEN
    Hey Bill... Welcome to the site! Where about in WI are you? I've lived there 40 years, I'm now in AZ for past 5. I was in New Berlin 11 years prior to moving. I graduated from Antigo High in 88.
    So to your question, I'll be doing the same thing probably on Tuesday. After watching several YouTube videos, I'm thinking the heat gun will work best and a set of plyers for badges, be careful pulling though! And heat gun with small pick or pin to start the corner pullup of decal. Here's the video I found most useful. (note: although lenghtly, very informational) Good Luck.
    Tundra805 likes this.
  3. Feb 9, 2015 at 7:33 AM
    On my last Tundra, I used a blow dryer and gently waved it over the decal - which allowed me to peel it off.
    Wisconsin Bill[OP] likes this.
  4. Feb 9, 2015 at 2:38 PM
    Wisconsin Bill
    Bill
    07 Tundra Dbl TRD
    in the plans!!!
    Hey Robert,
    We're in the Madison area. Thanks for the link :).
    tat2ude39[QUOTED] likes this.
  5. Feb 10, 2015 at 10:02 PM
    sonns904
    sonns904 New Member
    Orlando fl
    2011 white crewmax
    Heat gun? Yall weren't worried about the paint?
  6. Feb 10, 2015 at 11:58 PM
    Relentless
    Relentless Eric @Relentless Fab Vendor
    Eric
    East of the Sierras(Reno), Nevada
    '14 Crewmax TRD 4x4> '15 Duramax SLT
    Just a few, more to come
    Heat gun is fine, just don't sit in one spot. If it's getting uncomfortably hot to the touch, you're probably getting things too hot, at least in my experience
  7. Feb 17, 2015 at 5:33 PM
    Use a blow dryer and stroke over it
  8. Feb 17, 2015 at 9:56 PM
    JROCK915
    JROCK915 Trust noone, and be prepared!
    Jeremy
    Palm Desert, CA.
    2011 Trail ready SR5
    Icon 1.5" leaf pack, w/ Pro Comp 1" block Rear Pro Comp SS shocks ToyTec/Eibach coil overs, on Pro Comp SS shocks, SPC UCA AFE Stage II C.A.I, and throttle body spacer N-Fab nerf bars N-Fab RSP front bumper with Hella Optilux 30" LED bar, and Hella Optilux 4" (2) HID driving lights Federal Couragia 33x12.5x20, wrapped around 20x9 Fuel Boost Fender flares Spyder LED tail lights (smoked out)
    Has anyone had any "ghosting" issues? I wanna debage the whole rig, but heard some bad stories about ghosting. Especially in 2nd Gens.
  9. Feb 17, 2015 at 11:27 PM
    tat2ude39
    tat2ude39 MYota
    Robert
    San Tan Valley, AZ
    I actually debadged my truck last week. All I used was a standard plyers to pull off the TUNDRA stamps and 4X4 tailgate stamp, a small 90 degree pick to start, and flat head screwdriver for 5.7L badges. Finger roll the adhesive away. WD40 to remove adhesive reside. Any ghosting and final reside can be removed by using a rubbing compound/polish (lots of elbow grease/several applications)
    JROCK915[QUOTED] likes this.
  10. Feb 18, 2015 at 6:37 AM
    JROCK915
    Jeremy
    Palm Desert, CA.
    Ok. Thanks for that. I was gonna try the hair dryer and fishing line trick. Good to know about the WD40. It didn't do any harm to your paint?
  11. Feb 18, 2015 at 9:08 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    I would say the hair dryer / fishing line and the WD 40 are two different stages of removing the badges/stickers.
    Use the dryer and fishing line to get the badges off, or just the dryer for the stickers, and then use the WD 40 to get the glue residue off. The WD 40 will not do much if the sticker is still on the truck.
    JROCK915 likes this.
  12. Feb 18, 2015 at 1:14 PM
    I rolled the residue off with my fingers, and then used "Goo Gone" to get it all off. No ghosting.
    NueveTundra and JROCK915 like this.
  13. Feb 18, 2015 at 5:11 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
    @Sean266 , and paint issues with the Goo-Gone? That was my 1st choice.
  14. Feb 18, 2015 at 5:39 PM
    tat2ude39
    tat2ude39 MYota
    Robert
    San Tan Valley, AZ
    No issues w/ WD 40...
  15. Feb 18, 2015 at 5:43 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    No issues with goo-gone
    T-Rex266 and JROCK915 like this.
  16. Feb 18, 2015 at 5:53 PM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    Why no pictures!!!!!????
  17. Feb 18, 2015 at 6:59 PM
    tat2ude39
    tat2ude39 MYota
    Robert
    San Tan Valley, AZ
    Not much to see with debadging, but I like the look. Gives the appearance of more color... Makes the canvas seem bigger!
    GODZILLA and JROCK915 like this.
  18. Feb 19, 2015 at 9:30 AM
    Newp...
  19. Aug 28, 2021 at 2:24 PM
    jamiehrvl
    jamiehrvl New Member
    Jamie
    2019 TRD PRO Tundra
    The 3M Adhesive eraser wheel was worth all $44.
    Removed emblems with plastic detailing tools, and removed two sided tape underneath with wheel. No hair dryer no shadows.
    Used hair dryer to get the red and black TRD Pro decals off, and eraser wheel for residue.
  20. Aug 29, 2021 at 3:59 PM
    jbrnigan
    jbrnigan New Member
    Midwest
    2007, 5.7L, 4x4, Crewmax,
    You don't say what color your truck is. Some colors are more susceptible (dark colors) to ghosting than others. You won't really know until you remove a decal (hair dryer, heat lamp, goo gone, WD-40 etc). You can always replace the decal if the ghosting is more obvious than you expect. FWIW.....last year, the "Tundra" badge on my left front door(14 year old truck) became "detached" after going through a carwash. The 3M attaching tape was still on the door. I used WD-40, Goo gone, an eraser wheel, lots of rubbing.......anyway, as the tape residue came off the door, so did the underlying paint finish. I ended up ordering new badges and replacing instead of removing. (the badge on the right front door came off with just a slight "tug" with my fingers)
  21. Aug 29, 2021 at 4:15 PM
    jamiehrvl
    Jamie
    2019 TRD PRO Tundra
    Super white.
    Probably could get away with no shadowing even after many years, but every thing I’ve read says the longer you wait the more susceptible it is to shadowing. Darker vehicle probably can’t wait too long to take them off of that is the look someone wants.
    The eraser tool was just really nice compared to the gooey mess that comes with wd40 or goo gone. At least in my experience.
