Removing tow package?
Discussion in '2nd Gen Tundras (2007-2013)' started by bthompson12, Apr 19, 2019.
  1. Apr 19, 2019 at 11:34 AM
    bthompson12
    bthompson12 [OP] New Member
    Bruce
    GA
    22’ Blueprint SR5 4x4
    Hey guys has anyone removed there tow package to re paint? I moved up to Wisconsin from Alabama and in the last two years my tow package has started to rust. I was thinking about removing and re painting or possibly getting it lineX’d or some equivalent. If you’ve done it post pics. I went through the search thread but didn’t locate anything. I’m not sure how hard it will be to remove
    Thanks for the help guys
    Bruce
  2. Apr 19, 2019 at 12:04 PM
    Wiscdave
    Wiscdave New Member
    Northern Wisconsin
    19 Tundra Sport
    Old ride 13 RW BA budget, 3/2 lift JL W7
    Just clean it up and paint with rustoleum...that's what I always do. Hate the rust up here.
  3. Apr 19, 2019 at 1:14 PM
    lewi3069
    lewi3069 New Member
    2017 Crew Max 4x4 Sunset Bronze
    I sprayed the underbody/frame with Amsoil HD Metal Protector. If you take it off prep well and re paint the coat it with Amsoil or like you should be set.
    OBXTundra likes this.
  4. Apr 19, 2019 at 3:46 PM
    Dr_Al
    Dr_Al New Member
    Al
    Shouldn't be all that hard to remove. The hitch itself will just be bolted onto the frame and the wire harness should have a connector somewhere under the bed.
    15whtrd likes this.
  5. May 7, 2019 at 12:05 PM
    DesertRoads
    DesertRoads Telecom Guy
    Utah's West Desert
    2005 DC SR5 V8 4WD LSD & TOW PKG
    LED Lights Galore. Mostly Stock
    I wore eye protection and a respirator and brushed off with a wire brush, then sprayed with Rustoleum. But like everyone else said, I've sure it's easy to unbolt and paint.
