Removing Tow Hitch lock
Discussion in 'Towing & Hauling' started by CCTundra, Mar 20, 2017.
  1. Mar 20, 2017 at 7:26 PM
    CCTundra
    CCTundra [OP] New Member
    Seattle,WA
    2021 1794 Tundra
    Bilsteins 6112 top setting, 0.5" Coach builder shims, 5160 rear shock with 3" Coachbuilder shackle kit. RB20 Step bars, Forged TRD Pro wheels, Back flip cover, Kennwood 10" Head unit, 2JL 10" Subs, Alpine 6 channel Amp.
    so I purchased my truck about 1 month ago and the previous owner left the hitch on there with a master lock, lock. I would like to remove this lock so I can remove the lock. Any ideas on the best way to do this? IMG_6970.jpgIMG_6969.jpg
  2. Mar 20, 2017 at 7:32 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    4" grinder or a sawzall with a metal blade and some patience.
    AnonVet, Achuop, Law323 and 3 others like this.
  3. Mar 20, 2017 at 7:41 PM
    How many locks can a lock get if a lock would lock, lock?
    AnonVet, Krezz, Bear and 9 others like this.
  4. Mar 20, 2017 at 7:44 PM
    CCTundra
    Seattle,WA
    2021 1794 Tundra
    Damn, I didn't review my thread before posting it. I got a little crazy with the word "lock".
    Krezz, Bear, bigoltater and 2 others like this.
  5. Mar 20, 2017 at 7:46 PM
    CCTundra
    Seattle,WA
    2021 1794 Tundra
    I am afraid that I will cut into my hitch attached to my truck. I don't really have any tools, but I'm pretty sure Home Depot rents these tools out.
  6. Mar 20, 2017 at 7:47 PM
    I second the sawzall.
  7. Mar 20, 2017 at 7:48 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Should be easy to avoid the hitch with a sawzall and metal blade.
  8. Mar 20, 2017 at 7:49 PM
    CCTundra
    Seattle,WA
    2021 1794 Tundra
    Oh ok. I will go to the Home Depot this weekend and see what I can find. I want to get this thing removed sooner than later.
    831Tun[QUOTED] likes this.
  9. Mar 20, 2017 at 9:09 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    I was looking to buy that pin. It is not a lock. You should be able to pull the blue pin out and straighten it out so you can pull the pin out.
  10. Mar 20, 2017 at 9:20 PM
    Anyone in your area have a Cutting torch that you know?
    Easy as pie.
    Cutting wheel idea would work great as well.
    NewImprovedRon likes this.
  11. Mar 20, 2017 at 9:35 PM
    TundraDan723
    TundraDan723 Not as new as I used to be...
    2023 Celestial Silver Tundra 1794 TRD CM
    Good luck!
  12. Mar 20, 2017 at 9:40 PM
    TRDFaux
    TRDFaux Irresponsible Adult
    2014 Tundra SR5 Crewmax 4X4
    Toytec level and diff drop, Cooper STT Pro Tires, TRD Pro Grill, blacked out, debadged.
    that's not a lock, the blue part will slightly lift up and flip down so you can pull the pin out.
    Motor71, BlueBottle, TheBeast and 3 others like this.
  13. Mar 20, 2017 at 9:42 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Yea check it out a little better before you go cutting. Might not be a lock like @BlueBottle said.
    If it is the use a grinder with cutting wheel. You will have better luck cutting it.
  14. Mar 20, 2017 at 11:31 PM
    BOBONTUESDAY
    BOBONTUESDAY Grocery Getter
    2016 Limited Trd
    This is why I don't use locking hitch pins anymore. The minnesota weather and salt ceases them up. I second the sawzall or grinder. I've had to cut my own several times. It's a big inconvenience when you need to swap ball sizes and can't because the pin won't come out.
  15. Mar 20, 2017 at 11:50 PM
    Voyagermike
    Voyagermike New Member
    California
    TheBeast, mad4sax and 15whtrd like this.
  16. Mar 21, 2017 at 12:10 AM
    Abrams65
    Abrams65 New Member
    Cliff
    WV
    16 Tundra MGM SR5 CM OR/15 Corolla S
    ICI Magnum RT Steps, 18' LED Foglights
    Dremel with a cutting wheel
    Bear and rons23 like this.
  17. Mar 21, 2017 at 5:54 AM
    CCTundra
    Seattle,WA
    2021 1794 Tundra
    But I think you need to have a key for it to unlock and be able to pull out and up. I'm stuck because the guy that sold me the truck. Ever gave me the key so I have to figure out how to get this thing out. I will try to look at this once I get home from work today. Thanks for all the tips guys. :thumbsup:
  18. Mar 21, 2017 at 6:22 AM
    Grizzly660
    Grizzly660 21 Army Green Sport
    North Dakota
    2021 Army Green Sport
    20 inch XD Hoss wheels with Nitto EXO Grappler Wetokole seat covers
    Does that pin under the blue tab go all the way through? If so take a hammer and a punch and pop it out should release the whole blue part. Just an idea and might be less work than cutting/grinding
  19. Mar 21, 2017 at 6:42 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    There is no lock. Loook at the video that @Voyagermike posted.
    15whtrd, Voyagermike and Relentless like this.
  20. Mar 21, 2017 at 7:16 AM
    csuviper
    Broomfield, CO
  21. Mar 21, 2017 at 7:16 AM
    csuviper
    Broomfield, CO
  22. Mar 21, 2017 at 8:41 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Smash it with a hammer. How strong can a $5 lock be? Otherwise, $13 at harbor freight
  23. Mar 21, 2017 at 8:46 AM
    Crewmax Chris
    Crewmax Chris Paper Airplane Enthusiast
    Lewiston, ME
    2013 Tundra SR5 DoubleCab
    Good buy at HF too! Mine's lasted about 13 years and I think when I bought it online it was $9.99. I only use it about every week in the summer cutting stuff on race cars...
    Law323 and joonbug[QUOTED] like this.
  24. Mar 21, 2017 at 8:49 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Lol. One time they had them on sale for $4.99. I bought like 8 of them. I just started giving them away. Still have 2. :)
  25. Mar 21, 2017 at 8:50 AM
    Crewmax Chris
    Lewiston, ME
    We JUST got a store nearby and its really dangerous (much like this forum) for keeping money in one's wallet!
  26. Mar 21, 2017 at 8:51 AM
    CCTundra
    Seattle,WA
    2021 1794 Tundra
    Awesome!!! Thanks guys for all the help. I love this forum man. :bananadance:
  27. Mar 21, 2017 at 9:27 AM
    DevilSquid91
    DevilSquid91 New Member
  28. Mar 21, 2017 at 9:28 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    That doesn't look like a lock, it's like others said, pull up on the blue sleeve and pull down. If it's stuck, try getting a flathead and prying it up, still sticking, tap around with a hammer to loosen whatever's seizing it up and try prying it up again. If all fails, sawzall or grinder.
    Don't forget safety glasses and don't sit in front of the yellow/orange debis flying out....hot metal flecks in the eye SUCK!!
  29. Mar 21, 2017 at 9:34 AM
    TheBeast The Beach
    Tundras.com to the rescue !
    Krezz, Voyagermike and Law323 like this.
  30. Mar 21, 2017 at 9:39 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I like the BFH idea the best!!
    Law323 likes this.
