Removing the grill
Discussion in '2.5 Gen Tundras (2014-2021)' started by ed155, Apr 4, 2014.
  1. Apr 4, 2014 at 6:37 AM
    ed155
    ed155 [OP] New Member
    hi, i want to buy another grill to replace on my 2014 dbl cab TRD 4x4. probably this one : Smittybilt M1
    I want to know if somebody know how to remove the old one.
    Thanks
    Eric
    PS: sorry for my bad english, i'm french canadian
  2. Apr 4, 2014 at 7:37 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    This is from @invsblduck on another forum
    "There are 3 clips in the middle and two hooks/prongs on the ends:
    Lift up on one of the lower corners to unseat the hook and pull it out, then just give a firm pull to unseat the rest of the clips down the line (you don't remove the clips, they're attached to the grill).
    The hooks on the corners looks like this:
    They fit into square holes in the body panels above the bumper, and they're facing DOWN towards the ground (hence lift up):"
    MotoTundra likes this.
  3. Apr 5, 2014 at 10:34 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Post up pics when you get the new one!
  4. Mar 2, 2019 at 9:19 AM
    Haggis777
    Haggis777 I.L.J.C.M.L.
    SW Michigan
    2015 Silver SR5 TRD Tundra Canadian Model
    LEDs interior & exterior, stubby antenna, Bak-Flip cover, 285's, AGM battery, block heater, Pine tree air freshener
    https://youtu.be/RP7NyHGTIkw
    I used this video to replace my stock lights to LEDs on my 2015 SR5. Excellent explanation with visual to remove and replace your grill!
