Removing the back seat
Discussion in 'General Tundra Discussion' started by avi8r2009, Jan 30, 2019.
  1. Jan 30, 2019 at 9:12 AM
    avi8r2009
    avi8r2009 [OP] New Member
    Jack
    2018 Black Tundra
    I've got a 2018 Tundra CrewMax and I'm planning to take a road trip.
    I want to create a bed in back of the seats and want to see if anyone out there has ever removed (and replaced) the back seat.
    Welcome your experience and ideas.
  2. Jan 30, 2019 at 11:07 AM
    You can remove them. They unbolt from the floor
  3. Jan 30, 2019 at 12:53 PM
    g6t9ed
    g6t9ed Novice Tundra Modder
    2017 Black CrewMax 1794 4x4
    Also, be aware of the one threaded screw that different from the rest when you put your seats back in.
  4. Jan 30, 2019 at 12:59 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Instead of removing the back seats why don’t you use something like this?
    seniao likes this.
  5. Jan 30, 2019 at 1:00 PM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Btw, I had to remove both back seats to install my sub box and it was fairly easy. A 1-man job.
  6. May 30, 2019 at 6:13 AM
    jmdaniel
    jmdaniel Spending too much time here...
    Leander, TX
    2018 Tundra CrewMax SR5, 1977 FJ40
    DSI Conversion, including 6" ProComp lift, Fuel Assault Rims, ProComp tires, SunTek protective film, BAK Revolver X2 tonneau cover, Bedrug bedmat, OEM Audio+ Reference 500Q
    How heavy are the seats? I see some folks recommend two people, so as not to scratch anything...
  7. May 30, 2019 at 6:27 AM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    They aren’t really that heavy, more awkward weight than anything. If you have a second set of hands, I’d definitely use them to avoid puncturing / scratching anything.
    15whtrd and jmdaniel[QUOTED] like this.
  8. May 30, 2019 at 6:34 AM
    19TRDPRO_FL
    19TRDPRO_FL New Member
    Paul
    Parkland, FL
    2019 Tundra TRD Pro
    Audio: Pioneer 8200NEX Infinity Kappa complete speaker package 4 Channel Kenwood amp 5 Channel Kenwood amp 10 inch JL Audio W1 shallow mount sub X 2 Readylift Pro Plus 4in lift (6 total) 22x12 Fuel Sledge wheels 35x12.5R22 Nitto Ridge Grapplers LED bar in hood scoop LineX step rails
    After the sub box install, I must have removed these dang seats 10 times!!! Just be mindful of the spike, as it will put a hole in your carpet.
    KnuckleHD[QUOTED] and jmdaniel like this.
  9. May 30, 2019 at 6:37 AM
    jmdaniel
    Leander, TX
    Thanks! I have a load of Noico to install and a new OEM Audio+ system to throw in this weekend, and will get the wifie to help me get that rear seat out w/o damaging anything.
    KnuckleHD[QUOTED] likes this.
  10. May 31, 2019 at 9:56 AM
    Heff
    Heff New Member
    2017 Tundra Limited
    Really? I was not aware that one was different. Which one?
  11. May 31, 2019 at 10:26 AM
    Idaho Tundra
    Idaho Tundra New Member
    Josh
    Boise ID
    2015 crew max 4x4 5.7L
    295, 70, 18 KM3’s, 18" Vision Rockers, K&N Intake, Bilstein 5100's, Decked System, Leer Camper, Van Tech Roof Rack,
    did you build your own box?
  12. May 31, 2019 at 10:42 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    yep, the little one is no problem for one person the larger one is a little awkward go back in but it can be done
    jmdaniel likes this.
  13. May 31, 2019 at 1:17 PM
    g6t9ed
    It's been a while since I've had to remove mine, but I believe it's the 60 bench seat's front facing middle screw. You'll notice the difference as only one screw has a wider thread pattern than the rest.
    Sorry I couldn't be of more help but I promise, you'll notice the difference when you're taking them out.
  14. Aug 18, 2019 at 7:01 AM
    cornwall325
    cornwall325 Work in Progress
    2018 Tundra TRD Offroad Limited Crewmax
    Just removed my rear seat for Wet Okole install. The bolt that’s different on mine is on the 60 seat that is the passenger rear most bolt. Not a bad job to remove and install but I hope I don’t have to do it again just to put on seatcovers.
  15. Aug 18, 2019 at 7:46 AM
    Mr Swervlin
    Mr Swervlin "Yes....In Dee Face"
    O H I O
    2017 Silver Sky limited TRD Crewmax
    Line X bed liner Window tint AVS in channel vent visors Paint protection wrap Husky front & rear floor liner ESP Crewmax rear storage Console organizer and tray TRD shift knob TRD rear sway bar Thule exporter pro 500 Color matched door handles, side mirrors, and grill surround VLEDs interior/reverse/cargo Driver side grab handle 10" BAmuffler Trd pro headlights
    Get some help for the 60 side. It can be done by yourself but, no sense in scratching or ripping your truck up. Don't ask me how I know this.:anonymous:
    Migraine and jmdaniel like this.
  16. Aug 18, 2019 at 12:50 PM
    jmdaniel
    Leander, TX
    I did it myself 75% of the time, (3 outta 4), taking out and putting back, first for sound deadening, second for installing my OEM Audio+ system. It can be a one man operation, if you take your time.
  17. Oct 6, 2020 at 9:45 AM
    Honair
    Honair New Member
    120 pounds. Leather... 2017 1794 Tundra. I took em out and weighted them.
  18. Oct 6, 2020 at 10:02 AM
    Welcome from NY.
    Start a thread and introduce yourself. ;)
  19. Jul 15, 2021 at 8:38 AM
    seniao
    seniao New Member
    Santi
    Buford, GA
    2019 Silver Sky Metallic SR5 Double Cab
    TRD Pro Head Lamps Spray Bed Liner Side steps Peragon Tonneau cover
    How did you end up liking the OEM Audio+ system. I think that’s the one with the subwoofer under the seat right? Any rattling or extra noises from the plastic enclosure?
    jmdaniel[QUOTED] likes this.
  20. Jul 15, 2021 at 9:47 AM
    jmdaniel
    Leander, TX
    I love it! The subwoofer actually bolts to the back wall of the cab, on the drivers side, to a fixed nut that Toyota puts in as part of the build. No rattling at all, the only thing I hear from back there is when I have had riders in the back seat, and the seat belt wasn't put back in that little clip on the sidewall of the cab. I soundproofed my doors and back wall before I pout the system in, and it's pretty sweet!
