Removing plastic bed rail cover?
Discussion in '2.5 Gen Tundras (2014-2021)' started by kevine0001, Jul 11, 2019.
  1. Jul 11, 2019 at 7:55 PM
    kevine0001
    kevine0001 [OP] New Member
    Kevin
    Any tips on how to remove the plastic cover on the sides of the bed rail? It’s the plastic cover that a shell would sit on. Thanks
  2. Jul 11, 2019 at 8:27 PM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    Howdy Kevin!
    When my ‘18 had about 3000 miles on it, I found someone had gouged it BAD in a parking lot- a deep dent in the side of the bed and the paint was scratched down to the metal.
    I was not ready to live with such a ding on such a new vehicle , so I went through the whole process with insurance and got it fixed. (Sorry for the sob story- I am getting to the point)
    I took the truck to 2 great shops in town for repair bids.
    Both included in their quotes replacing the plastic bed trim, and both stated that removing them destroys the tabs that hold them to the bed rails 90+% of the time. The shop that got the job shared with me during inspection that they did have to replace the cap because it broke when they tried to ease it off.
    So, as far as I know, there is no non-destructive way to remove those caps. You’d likely pry them off with a trim tool, but be ready to order a replacement. I believe they are around $110, if memory serves.
  3. Jul 11, 2019 at 9:02 PM
    kevine0001
    Kevin
    Thanks. I was hoping it could be replaced. The previous owner drilled holes for a ladder rack. I want to fill them and the holes in the steel before I install a shell to prevent water intrusion. Thanks again and I may end up filling them with something since you will never see the holes once the shell is on
  4. Jul 12, 2019 at 7:20 AM
    ZTundra
    ZTundra New Member
    ZACK
    Knoxville, TN
    2021 MGM Nightshade
    The plastic caps come off really easy. Start at the end of the cap closest to the cab and pull up on them. I did not take my time or anything, just pulled up from one end to the other. No tools. It took me under a minute to pull both sides.
    TelemarkTumalo likes this.
  5. Jul 12, 2019 at 7:24 AM
    kevine0001
    Kevin
    Did any of the clips or plastic pieces holding it to the bed break off?
  6. Jul 12, 2019 at 7:31 AM
    ZTundra
    ZTundra New Member
    ZACK
    Knoxville, TN
    2021 MGM Nightshade
    Not a single one. I had a Tacoma that I pulled the rails off of about a 2 years ago and no broken tabs there either.
    kevine0001[OP] likes this.
  7. Jul 12, 2019 at 7:32 AM
    LASurf
    LASurf New Member
    Los Angeles
    300k+mi 06 AC4x4
    Took them off my first gen double cab. Easy to remove, and some tabs broke, but they did snap back on (obviously the areas with the broken tabs were a little loose). However with the weight of a shell on there too I think you’d be fine.
  8. Jul 12, 2019 at 9:32 AM
    RDRunner
    RDRunner New Member
    2016 SR5 Crewmax 4x4 TSS Edition
    Bingo. I have taken mine off a few times. Easy peasy. Do exactly like this poster wrote. I did it to put clear protection film under them (you can find posts where those caps rub through the paint if you mount a tool box or have a camper shell on because the weight and the fact that the caps are just sitting on the paint causes a rub). No broken tabs either--that must be a 1st gen thing.
  9. Mar 29, 2020 at 8:49 AM
    Ebayollis
    Ebayollis New Member
    Josh
    Spruce pine NC
    2020 Voodoo limited
  10. Mar 30, 2020 at 9:42 AM
    lonelydriver
    lonelydriver New Member
    if you break em theres aftermarket ones on Amazon that are great quality and cheap.
  11. Jan 22, 2021 at 2:04 PM
    Tindraoverlander
    Tindraoverlander New Member
    Actually, I don't see any on Amazon that fit the Tundra. Or any online at all for that matter.
  12. Jan 22, 2021 at 2:21 PM
    I'm pretty sure that you can squeeze the clips from the underside of the bed rails to remove them.
