Removing front sway bar benefits
Discussion in 'Suspension' started by Jwood562, Apr 18, 2020.
  1. Apr 18, 2020 at 11:37 AM
    Jwood562
    Jwood562 [OP] New Member
    2013 Tundra 4x4
    3" Suspension lift 18" method roost 35x12.5x18 ridge grapplers 2020 sequoia LED headlights
    So I have seen a few references about removing the front sway bar having benefits.
    Is that for any type of lift or just in general.
    I have 6112s at top setting and 1.5” shackles in the rear. I was under my truck yesterday doing my brakes and was tempted to remove it but I thought I would get some real advice from the forum first.
  2. Apr 18, 2020 at 12:05 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Let's the front suspension act completely independent so you don't get any cross talk when you hit a bump and arguably allows for more "flex". Down sides are you lose corner handling. Usually people who go offroading pull it. On solid rear axle vehicles usually the consensus is a rear sway bar to assist cornering, and no front away bar to fully utilize the fronts independent handling, and the rear sway bar will help stiffen the rear end and force the front to flex more.
    15whtrd, Mountun Goat and BlackSheep like this.
  3. Apr 18, 2020 at 12:09 PM
    devdomski
    devdomski New Member
    Devin
    South Jersey
    2018 SR5 CM 4x4
  4. Apr 18, 2020 at 12:12 PM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    Do it if you're lifted. I pulled mine a week or so ago. I'm not going back. For what it's worth I don't take corners at mach speed.
  5. Apr 18, 2020 at 12:21 PM
    Muddog
    Muddog New Member
    Bay Area California
    Kings front and Rear BMC Sliders 17s on toyo 35s
    When I lifted mine on 35s there was a rub so I removed it. Like you, I was concerned with corner holding, etc. But after driving with it off for more than a year I really haven't noticed body roll. Granted I don't drive my 7000lb truck like a teenager but I in real-world driving I would say its not a biggie. especially if you are already changing suspension and tires.
    JCBerb, BlackSheep and HBdirtbag like this.
  6. Apr 18, 2020 at 4:55 PM
    devdomski
    Devin
    South Jersey
    2018 SR5 CM 4x4
    What lift?
  7. Apr 20, 2020 at 1:20 PM
    Muddog
    Muddog New Member
    Bay Area California
  8. Apr 20, 2020 at 1:24 PM
    CavBluTundra
    CavBluTundra CavBluisdabomb
    Howard
    2018 TRD Off Road Limited
    Should it come off if you use the 6112's only for leveling??
  9. Apr 20, 2020 at 1:24 PM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    Mine has been off for 4 years, no problems, took a freeway exit at 80mph still stable enough but then again it’s not a race truck. You’re not gonna roll over like many people believe after taking off the sb, that’s the driver’s fault. Sway bars are for cars, no more bobble heading in the truck, plus it’s a bit smoother.
    EN2TUNDRA and Mountun Goat like this.
  10. Apr 20, 2020 at 1:34 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Anti-roll bars are for trucks... I would not drive one without them mounted front & rear.
    15whtrd, AggiePhil and Mountun Goat like this.
  11. Apr 20, 2020 at 1:51 PM
    phabej
    phabej New Member
    NO LONGER HAVE A TUNDRA... Waiting
    just don't do this.
    personally, i like having mine, haven't taken it off road and I sure go fast around those onramp off ramp that's circle like. LOL
    YardBird, Black Wolf and Rex Kramer like this.
  12. Apr 20, 2020 at 2:24 PM
    2Tall
    2Tall New Member
    Chance
    South MS
    2020 Super White CM SR5 4x4
    I’m running 6112s on the top setting up front and decided to pull mine off today. Definitely made for a smoother ride on a rough and bumpy, pothole filled road near my house. There’s not a huge difference in body roll to me so far, but I’ve only drive a couple back roads so far. Try it, and if you don’t like it put it back on. Hardest part is removing the skid plate.
  13. Apr 20, 2020 at 2:35 PM
    Rex Kramer
    Georgia
  14. Apr 20, 2020 at 2:43 PM
    HBdirtbag
    HBdirtbag New Member
    Walnut Creek, CA
    2017 limited cm
    probably my favorite thing I did to the truck. MAde it drive much better all around (on road and off)
  15. Apr 20, 2020 at 2:44 PM
    Rex Kramer
    Georgia
    Farm tractors drive great without a front sway bar.
  16. Apr 20, 2020 at 2:47 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yeah...not sold on taking mine off
  17. Apr 20, 2020 at 2:49 PM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    and this is a good article....why i've got upgraded sway bars on all my other cars....but definitely not my tundra.
    I know plenty about how suspension works, have aftermarket suspension on all my vehicles (including setups i've had custom valved, custom spring rates for, etc). Have owned plenty of cars that have seen a race track. Will never put the sway bar back on my tundra.
    Any good driver will properly know how to properly handle their vehicle with or without. Any stupid driver can completely ruin a vehicle with or without.
    devdomski likes this.
  18. Apr 20, 2020 at 2:49 PM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    it's a 10 min job. Take it off, see what you think....don't like it put it back on.
    BigsToy, AggiePhil, KMG and 6 others like this.
  19. Apr 20, 2020 at 2:58 PM
    devdomski
    Devin
    South Jersey
    2018 SR5 CM 4x4
    Why are some of you making it seem like you’ll die if you take it off. If you don’t know how to drive then you shouldn’t be messing with your suspension at all, and probably shouldn’t have a license. The very first sentence of that article talks about taking corners fast. We drive full sized trucks. Immediately I know that article doesn’t apply to me. If you are a capable driver, however, then I don’t see any harm in removing it and trying it out to see if you like it or not. It’s all just personal preference.
    BlackSheep likes this.
  20. Apr 20, 2020 at 2:59 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  21. Apr 20, 2020 at 3:00 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Criticizing someone to exercise caution instead of pull stock suspension components off without fully understanding why is like laughing at someone who refuses to jump off a bridge because they saw someone on YouTube do it.
  22. Apr 20, 2020 at 3:01 PM
    devdomski
    Devin
    South Jersey
    2018 SR5 CM 4x4
    Like I said, if you don’t know how to drive you shouldn’t be messing with your suspension in the first place.
    Samoan Thor and Rex Kramer like this.
  23. Apr 20, 2020 at 3:02 PM
    motoryder
    motoryder ^^ I probably crashed after that pic
    Rancho Cucamonga, CA
    2500HD AT4
    I just took mine off last Saturday because:
    1. I wanted to clean off the 30# of dirt on top of the skid plate between the engine. It was an easy enough job to take it off.
    2. I was curious how it would handle.
    3. What else am I going to do, thanks to the 'ronies.
    Initial impressions when taking driveway entrances on a diagonal are that it handles bumps like this way smoother. I need to take it in the dirt though to get a better comparison of how it was before. I'd get rocked on washboard type stuff where the whoops were not completely perpendicular to the truck and that was super annoying. Motorcycle in the back would be really stretching the tie-downs! I can see it handling those situations much better now. Driving normally seems a tad more "wobbly" maybe? Overall though, i'll leave it off for a while and see how it goes. If I end up needing to tow anything it will go back on for sure. I think it would definitely feel unstable while towing anything with significant weight.
    HBdirtbag and devdomski like this.
  24. Apr 20, 2020 at 3:06 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Lol. Ok dude.
    devdomski[QUOTED] likes this.
  25. Apr 20, 2020 at 3:15 PM
    devdomski
    Devin
    South Jersey
    2018 SR5 CM 4x4
    Just like you should only jump off a bridge if you know what you’re doing. Not because you saw someone else do it on a forum.
  26. Apr 20, 2020 at 3:19 PM
    Rex Kramer
    Georgia
    Driving a full size truck safely at a higher rate of speed on twisty roads requires skill, experience and anti roll bars.
    15whtrd, ZPMAN, Black Wolf and 2 others like this.
  27. Apr 20, 2020 at 3:22 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Don't worry man I ain't doing anything I don't want to
  28. Apr 20, 2020 at 3:25 PM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    I bet I’d out drive you without sway bars
  29. Apr 20, 2020 at 3:48 PM
    Rex Kramer
    Georgia
    I'll take that bet.
  30. Apr 20, 2020 at 3:55 PM
    motoryder
    2500HD AT4
