Removing Catalytic converters 2001 Tundra
Discussion in '1st Gen Tundras (2000-2006)' started by Bird42, Jan 9, 2018.
  1. Jan 9, 2018 at 7:24 PM
    Bird42
    Bird42 [OP] New Member
    Utah
    Pro Comp Wheels, Pro Comp 2.5" level kit, Nitto Grappler G2 Tires.
    Does Anybody know if removing the cats kicks a check engine light? And also would it make it impossible to pass smog/emissions?
  2. Jan 11, 2018 at 3:50 PM
    mudslinger79
    mudslinger79 New Member
    Christopher
    Williamsburg, Va
    2006 Double Cab, Phantom Grey Pearl
    Leveled. 16x8 Pacer 164 wrapped in 295-75-16 General AT2. Flowmaster exhaust. K&N Cold air intake.
    Yes to the check engine light and yes you WILL fail emissions testing as you will have no emissions on the vehicle.
    NewImprovedRon and Bird42[OP] like this.
  3. Jan 14, 2018 at 2:03 PM
    SnowroxKT
    SnowroxKT New Member
    Kyle
    Alaska
    Possible, yes. There are ways of not having it trigger a check engine light but these are for "offroad only" since having a catalytic converter is a federal law I believe for road vehicles. You won't pass emissions or a smog test unless the techs are dumb, or, you are paying them to be dumb.
    Bird42[OP] and mudslinger79 like this.
  4. Jan 21, 2018 at 8:02 PM
    WhiskeyPapa
    WhiskeyPapa New Member
    I have a set of cats from an 04 that might help
    Darkness and Bird42[OP] like this.
  5. Jan 31, 2018 at 9:40 PM
    Bird42
    Utah
    Thanks guys. I ended up taking it into a muffler shop instead of doing it myself. They said that i shouldn't remove the cats because it would kick a light and the truck wouldn't run properly because the engine needed the back pressure at its current tuning. Thanks for the answers though guys.
  6. Feb 1, 2018 at 8:17 AM
    Mike's Custom Toys
    Mike's Custom Toys New Member
    Of course a muffler shop will say that. If you get the downstream o2 simulators it will be fine. Backpressure is not factored in tuning its incoming air. We have done cat delete's on everything including S/C Third gens with headers. It will defenitly get louder.
    Filthyphil and Mountun Goat like this.
  7. Feb 11, 2018 at 4:42 AM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    It was nice before 1996 when you can just gut out your Cats and get away with it. Jap cars mostly because they run clean already. So one thing I hope to learn hear is how to put dual exhaust on a 2000, V8 and be able to gut the cats. If I have to leave them, then at least dual exhaust with some more flow. I don't know about you guys, but I'd rather breath gas fumes than Sulfur. Isn't Everything living made from carbon, so go figure.
  8. Feb 12, 2018 at 11:45 AM
    SnowroxKT
    Kyle
    Alaska
    Get some 02 simulators or if you want to be really ghetto you could attach the 02 sensors somewhere outside of the exhaust stream.
  9. Feb 13, 2018 at 8:52 AM
    zombie
    paul
    Rhode Island
    2007 Black DC 4x4
    Thanks, I will look into those.
  10. Apr 27, 2019 at 1:31 PM
    Mightyjoe
    Mightyjoe New Member
    Joe
    04 tundra double cab. 4.7 sr5
    Yes I was wondering about deleti g my cats, I have p0420 code. What to do,
  11. Apr 27, 2019 at 4:09 PM
    Aerindel
    Aerindel New Member
    Montana
    Many states do not have emissions testing. Yes, you will throw a light unless you modify your o2 sensor circuit.
  12. Apr 27, 2019 at 8:01 PM
    Pennrunman
    Pennrunman New Member
    2000 Tundra 4 X 4 Limited and TRD
    None
    My service engine light is on due to the catalytic converter, but since it is a 2000, there is no state emissions requirement here in Massachusetts on vehicles that old; so it has passed inspections the past 4 years... no issues...
  13. Apr 27, 2019 at 8:56 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Have you tried swapping O2 sensors?
    Mightyjoe[QUOTED] likes this.
  14. Apr 27, 2019 at 8:57 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    O2 simulators will help to trick the computer, but if a smog guy happens to notice on a visual you'll get busted.
  15. Apr 28, 2019 at 3:52 AM
    Mightyjoe
    Joe
    Yeah I had my 02 sensors changed so they r new
  16. Feb 8, 2020 at 8:46 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Has anyone gutted their cats? I remember I busted the honey comb stuff out of my old 93 Toyota pickup but don’t know about these 4.7 trucks.
  17. Feb 9, 2020 at 1:06 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    i plan on running no cats.. i ran no cats in my tacoma with o2 simulators. truck was alot happier. but it was louder too. no real benefit to running catless with stock exhaust manifolds though.
  18. Feb 9, 2020 at 2:09 AM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    Uncle Tony says back-pressure is a myth...
    https://www.youtube.com/watch?v=A2G1EOB4P3w
    Darkness likes this.
  19. Feb 9, 2020 at 4:01 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    That's a great video -- he explains the process very well. But note what he says at 4:30 about the importance of velocity. A larger, more free-flowing exhaust doesn't necessarily net more power or efficiency. The same is true on the intake side. Velocity and timing of the intake & exhaust charge are the real art of tuning.
  20. Feb 9, 2020 at 5:39 AM
    Professional Hand Model
    Hand Protectors
    I did a ton a meditations on tuning back about 2 years ago. From what I remember, Toyota has a code on our ECU that won’t allow tuning. I wish we had that code as it seems easier (le$$) to do a tune than do all this exhaust work.
  21. Feb 9, 2020 at 5:47 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    You can tune a 2nd gen ECU, but you can't tune a 1st gen.
    Sad but true... that's why I have left the intake & exhaust on my '02 stock.
    I did replace the cracked exhaust manifolds with JBS shorties, but most say that's not an upgrade.
  22. Feb 9, 2020 at 5:48 AM
    Hand Protectors
    What did your honeycomb stuff look like when you busted it out? Did your truck run any different afterwards?
  23. Feb 9, 2020 at 5:53 AM
    Rex Kramer
    Georgia
    Uncle Tony is correct if we are talking about pre-ECU engines, but the situation changes when an ECU is in control and back pressure something you do not want to eliminate on a Tundra.
  24. Feb 9, 2020 at 6:03 AM
    Hand Protectors
    Only benefit I can see of deleting cats, on the performance side for our trucks, is the ability to use racing oil which has high levels of good stuff for our engines. Racing oils will damage catalytic convertors because the ‘good stuff’ clogs them up.
    Whothefat likes this.
  25. Feb 9, 2020 at 8:20 AM
    Filthyphil
    Phil
    It looked like if you take a piece of cardboard and hold it vertical and looks down into it and you can see all the ridges. Or just like grey honey comb chunks once I busted it all out. The truck seemed to be louder and on that particular truck I did pick up about 1mpg.
  26. Feb 9, 2020 at 3:08 PM
    Hand Protectors
    A tad louder? Or real loud louder?
  27. Feb 9, 2020 at 5:16 PM
    Filthyphil
    Phil
    Well I had a flowmaster 40, but I would rate it a tad for sure but nothing crazy.
  28. Feb 9, 2020 at 5:23 PM
    empty_lord
    05 rollover special
    05-06 have been cracked. But that’s the only ones I know of.
  29. Feb 9, 2020 at 5:42 PM
    Rex Kramer
    Georgia
    Cracked by whom?
  30. Feb 9, 2020 at 6:09 PM
    empty_lord
    05 rollover special
    Orange virus apparently has cracked those Ecus.
