Removing adhesive after debadging
Discussion in 'General Tundra Discussion' started by jaredmillerdvm, Mar 3, 2019.
  1. Mar 3, 2019 at 10:30 AM
    jaredmillerdvm
    jaredmillerdvm [OP] Mods will never end!!
    Anderson, SC
    2018 MGM CM SR5 TRD Off Road 4x4
    Rough Country 3in leveling kit, SCS Ray 10s, 295/70/18 Toyo Open Country AT2 Extremes. TRD Shift Knob, Console Safe, Driver Side Grab Handle, WeatherTech Laser Measured Floor Liners, Katzkin Heated Leather Seats, Remote Start, TundraTex Frac Harness, Radio Vinyl Inlays, LED Interior Lightening. MGM Color Matched Hood Bulge and Surround, 18% Tinted Front Windows, 90% Ceramic Windshield Tint, 5% Banner, AntennaMast Stubby Antenna, Predator Step Bars, Skid Plate with Integrated Step, Line-X Spray in Bed Liner, Blacked Out Badges, Mirrors and Door Handles, Black Bedside Decals, Bak Revolver X2 Tonneau Cover, Swing Case Tool Boxes, DIY Tailgate Lock, Deck Rail System, Recon Smoked LED Tail Lights With LED Reverse Lights, Smoked Vinyl Wrapped Cargo Light, LED License Plate, Cargo, and 3rd Brake Lights, Dirty Deeds 8" BAMuffler, Black Powder Coated Front and Rear Bumpers, TRD Rear Sway Bar.
    what is the best solution to removing adhesive after removing badges?CE1E1121-2C75-4966-B3BC-87F402AE1A0F.jpg
  2. Mar 3, 2019 at 10:32 AM
    ifishinxs
    ifishinxs New Member
    Bob
    Cedar city, Utah
    2015 Tundra limited
    None! I tow a boat weekly
    Wd40 and a heat gun!
    jaredmillerdvm[OP] likes this.
  3. Mar 3, 2019 at 10:33 AM
    Yotatundraaah
    Yotatundraaah My tundra stays hungrry
    Southern CA
    2016 Silver Sky Tundraaaah
    Kings suspension Built Right ufc 295/70-18 Toyo AT2 18" XD bully wheels Baja designs foglights Baja designs ditch lights Rago fabrication ditch brackets Tiger auto rock slider Extang solid fold 2.0 cover Read more....
    Goo gone
    But keep in mind it will take a about 10-15 mins each.
    Good luck and let me know if it worked for you
  4. Mar 3, 2019 at 10:48 AM
    dumbassdave
    dumbassdave Member
    Dave
    2016 Crewmax Limited
    With that amount to left, I'd pick at off. That's a lot of crap for goo gobe to try and sort out.
    040Tundra and jaredmillerdvm[OP] like this.
  5. Mar 3, 2019 at 10:50 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Heat gun and roll it off with your fingers
  6. Mar 3, 2019 at 10:53 AM
    Yotatundraaah
    Southern CA
    Goo gone + roll with your fingers + heat gun + roll with your fingers then repeat lol
  7. Mar 3, 2019 at 10:54 AM
    Yotatundraaah
    Southern CA
    You wont feel your fingers for the next couple days or so :laughing:
  8. Mar 3, 2019 at 10:57 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
  9. Mar 3, 2019 at 10:58 AM
    Mnorris1206
    08 tundra
    I would do all the above first I'm sure it will come right off with out having to us a erase wheel .Because your truck is still so new .
  10. Mar 3, 2019 at 10:58 AM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    Many automotive parts houses sell adhesive remover.
    Test in a small place on the paint first. Then spray left over adhesive and use a blow dryer just to worm up the area, to much heat will be your enemy. Use a credit card style tool to remove the adhesive. Inspect the tool, (scrapers edge first.) then go at it.
    Obviously be very carfule not to scratch the painted surface. Try to
    use your thumb to roll the adhesive residue off if nesseary.
    Hand polish the area with your pick of a product. Post your finish product photos. Good luck
  11. Mar 3, 2019 at 11:32 AM
    jaredmillerdvm
    Anderson, SC
    Thanks everyone. Heated it up, sprayed windex and goo gone and let it sit. Then used a plastic spatula thing and it came off easy. No scratches that I can tell. Got some good help rinsing all that shit off.....her aim is a little off tho! 3707DEE6-7F32-4C40-B8D8-0FDEB0421F0E.jpg
  12. Mar 3, 2019 at 11:36 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Nah, she's just ahead of you cause you're taking pictures. She's got work to do and moved on to tires/wheels. Looks good!
  13. Mar 3, 2019 at 11:37 AM
    jaredmillerdvm
    Anderson, SC
    It looks so much better with the V8 and SR5 badge off!!
    jewsNbrews and TheBeast like this.
  14. Mar 3, 2019 at 11:40 AM
    TheBeast The Beach
    it does.
    I was gonna suggest Whizz wheel on Amazon but looks like you good ;)
  15. Mar 3, 2019 at 11:55 AM
    Inquiringone
    Ter
    NorCal 408
    It's great to see you had a helper. Children of the future need to know how to do things. Great job
    :D
  16. Mar 3, 2019 at 12:21 PM
    jaredmillerdvm
    Anderson, SC
    82F8923C-D126-4F1D-9A47-07C6E9E6E92A.jpg Thinking about color matching handles and mirrors, what’s the consensus out there?
  17. Mar 3, 2019 at 12:24 PM
    Goo Gone, heat gun, elbow grease
  18. Mar 3, 2019 at 12:25 PM
    Color matched is good but black looks good on MGM..
  19. Mar 3, 2019 at 12:26 PM
    Do it, but mine are black, what I like
  20. Mar 3, 2019 at 1:13 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    It's a good break up of solid color. Black handles and mirrors, otherwise everything blends with all color match in my opinion.
  21. Mar 3, 2019 at 1:13 PM
    realtorblake
    realtorblake Tundra Thunda
    Redneckistan... aka Cypress, TX
    2019 Crewmax Platinum 5" Zone lift Fox 2.5 /OME suspension 12.5x35x18 ProComp's
    If you go that route
    If you go that route, I'll buy the black door hardware and the mirror caps if they are also black.
  22. Mar 3, 2019 at 1:20 PM
    undermyvoodoo82
    undermyvoodoo82 New Member
    '19 Crewmax Limited TRD
  23. Mar 3, 2019 at 1:22 PM
    undermyvoodoo82
    And I color matched my crewmax mirrors and handles but I had chrome...
  24. Mar 3, 2019 at 1:25 PM
    TheGreyTundra28
    TheGreyTundra28 New Member
    2018 Grey Tundra Sport
    Dirty Deeds 10 budget exhaust, Roof rack, 52" windshield, Truxedo Tonneau, and Line x Bedliner
    Looks like you got it! Nice ride btw. Keep the contrasts of black mgm imo. Unless you really want the mgm murdered look.
    For the future I used fishing line and a hairdryer for debaging. Then goo gone to touch up small sticky areas.
  25. Mar 3, 2019 at 1:29 PM
    RiggsTRD
    RiggsTRD New Member
    Josh
    Arizona
    2017 CM TRD metallic grey
    Dirty deeds exhaust, Bullydog tuner, Bilstein 6112/5100, airlift air bags, SCS ray 10 with 295/70/18 ridge grapplers ,TRD Pro grille, debadged
    I used 3m adheisive remover and heat. but like others said your thumbs will be shot!!!! had blisters on both thumbs after I was done but well worth the pain
