Removed fender flares, now hard to remove plastic grommets
Discussion in '1st Gen Tundras (2000-2006)' started by Breezy, Jul 30, 2019.
  1. Jul 30, 2019 at 9:49 PM
    Breezy
    Breezy [OP] New Member
    2006 Tundra SR5
    The other ones came out easy as you can see but over each wheel theres one that just won't come out. The backside is not accessible without taking it apart- which I kind of want to avoid.
    Any suggestions?
    Dannydirtyfingers likes this.
  2. Jul 30, 2019 at 10:01 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Drill it out carefully.
    OR18TRD likes this.
  3. Aug 2, 2019 at 6:12 PM
    Deslock23
    Deslock23 New Member
    2003 Tundra SR5 AC 4wd
    5100’s at 5th notch, Add-a-leaf, diff drop.
    Heat gun to soften it up & yank it? Unless you are putting the same type of fenders back on you will still need to fil those holes, and I think that plastic will give way before the metal.
  4. Aug 5, 2019 at 11:20 AM
    Breezy
    2006 Tundra SR5
    Tried drilling it out then prying mangled piece, worked out but took a while. I like the heat gun idea but would need to acquire one.... thanks for the suggestions all.
    Next step is filling the holes with bolt and washer- the trick is the back wheel wells are sealed underneath with a plaster type coating up to the metal so I can’t access the backside of the holes
    Deslock23 likes this.
  5. Aug 24, 2019 at 8:27 PM
    mttmsn
    mttmsn New Member
    2006 Tundra
    Any pictures of your Tundra without the fender flares? Also, when you took them off, did you feel like it was something you culd put back on if you decided to? Scared of commitment.
  6. Sep 4, 2019 at 5:01 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    wanting to take the flares off my 06 DC to rhino line them but wondering how hard it will be.
  7. Sep 4, 2019 at 5:13 PM
    coyote
    coyote New Member
    Some of the clips will twist out — maybe the ones that came out easy.... I use the tool like in the link above ( its sort of forked at the end ) and pry them out.
  8. Sep 5, 2019 at 10:51 AM
    Breezy
    2006 Tundra SR5
    Taking off the flares themself was pretty easy, took about 5 minutes for each. The clips are another story, as coyote mentions most of them twist out very easy. However- the clips at the top of the arc are VERY difficult to remove, along with one at bottom on the front well. I guess for added strength. I had a hell of time getting them out, I ended up drilling/prying. Good idea to protect the area around the clip while doing this- one bad move away from a big scratch in your paint... Will post some photos
  9. Sep 5, 2019 at 11:02 AM
    Breezy
    2006 Tundra SR5
    mttmsn, definitely no going back with the same clips once you take the flares off. You basically break them to take the flares off, but I think they are (the clips) easy to replace. Also- the rubber seal along the top of the flare will be damaged when taking it off- but could be put on back on if you get the right sealant/glue or whatever. I never liked the way the flares looked with the standard size tire, people who do a lift and go bigger seem to pull the look off better with the flares. I have funky holes now on the side of my truck but the profile looks better to me.
